I had a thread with all this info on Pirate but cannot find it so I am reposting here
Hey! You can have your cake and eat it too for under $200.00
I just finished the ram assit in my 99 Ford. It has an 8 inch lift with 37 inch Nittos. The Ford Super Dutys are notorious for walking all over the road when lifted. Mine was rediculous. I even had a dual stabilizer setup on it.
First of all let me say I replaced my Power Steering Gear Box and Power steering pump. If yours are good then use them. You could do this whole setup for about $150-200.00. I must take a second to thank Joe Wade for mock-up design of the ram and running down fittings for me. I am glad you got to learn on mine. I hope we get to do yours soon, if I am around.
Step 1
Red Head Steering Gear.com in Washington $275.00 (I think)...You don't need to replace yours if it is still good, but if you buy a new steering gear box, spend the extra $100 and buy one of these rather than a remanufactured one. I took this apart as soon as it arrived on my door step to drill and tap it. I was very tight with incredibly strict tollerances. Aparently not too many people have drilled out the boxes on their Super duty's. I could not find info on it anywhere. I sent Scott at rockstomper.com a picture of my gear box and he gave it his best guess on where to drill and tap it. He even took the time to draw arrows on my picture and E-mail it back to me. I attempted to drill it myself. I drilled pilot holes and then stepped up my drill bit sizes. I do not have a vise on my little drill press. Once I got up to half inch, the drill bit began binding and throwing the Gear box across the room. It bound so hard it broke the 1/2 inch drill bit and drew the gear box across the shop into my tool box. So I did what any intelectual would do in his garage; I held it tighter and tried again. That wasn't very smart. I almost lost a thumb. So I called a couple machine shops here in Salem, and found Electric Motor and Machine Company. They charged me for a half hour, ($30) and did it on the spot. He told me to tell you all he probably would require you to drop if off next time. Once I had it drilled out, I called Red Head Steering Gear and asked them how to put the gear box back together. They were a little surprised that I had taken a brand new box apart, but were happy to oblige. They were more than helpfull in answering all of my questions on the couple occasions I called to make sure I got it all put back together properly. In short, you really cannot mess it up if you only remove the piston and worm gear whole, then put them back in whole. They only go together one way. I was a little nervous though since I had never taken a steering gear box apart before, let allone tried to figure out how to do a ram assist setup. Side note here...I drilled mine out for 3/8 inch because I was not sure how this steering gear box was going to act. I could not find any info on someone doing a Super Duty yet, nor could I find out any flow charts for that gear box. I ended up using all 1/4 inch lines and fittings. Don't waste your time going larger than quarter inch when you drill and tap. You won't need it. Drill your box with an NPT tap. National Pipel Threads are tappered, and lock in better for a good seal with these high pressure lines.
Step 2
Power Steering pump...$60 Schucks, use your existing one if it is good. There is really no need to buy another one; go to West Texas Offroads' website and read the instructions on drilling out the little piston in your pump. It takes about 5 minutes. Also buy a 6 or 8 inch piece of radiator hose and use a hose clamp to attach it to the top of your power steering gear box to make the reservoir a little bigger. When you turn so the ram is completely closed, it forces the fluid back into your power steering pump. If you don't make the reservoir a little bigger, it will blow it out the cap. My fluid rises and falls about three inches in my reservoir as I turn the wheel lock to lock. I cut the reservoir off the old one and crammed it into the top of the radiator hose I added so I could put the stock power steering cap in it when I was done. It is also worth noting West Texas Offroad has a kit you can buy to do this. I think it was in the neighborhood of $400 for the ram fittings and lines. This is not a bad way to go considering the time I spent trying to figure out exactly what fittings to buy and running to fluid connectors across town a few times until I got it right. You would either have to send your steering gear box to them to get drilled and tapped, or do it yourself.
Step 3
Surplus Center.com... Get your Hydraulic ram, lines, and fitting from these guys. They are cheaper than you can find locally usually. As far as the sizes to go with; For the Ram I went with a 1.5 inch dual acting ram with a 3/4 inch shat and 8 inch throw. It was about $82 from Surplus center. Pretty sure it was Item #9-4410-08. You don't want to go bigger, or it will be slower. This is bad for on road applications. If it is mostly for off road, you may want to look at a 2 inch ram. I am telling my ram worked out perfect. I can turn my tires lock to lock at idle in the parking lot with one finger. For lines and fittings, they are all 1/4 inch NPT. That stands for National Pipe Thread. Keep that in mind if you have to run for fittings locally. NPT fittings are tappered. If you put a non NPT fitting on there, You will have serious issues because they will wallow out your holes in your gear box, or you won't even get them to start in the hole. I used one 36 inch line and one 48 inch line. They are a little long, but I plan on air bags with more lift in the future. Measure your to see what you need. You will also need three 90 degree male to female fittings and one coupler male to female. This was my setup. Yours may vary.
Step 4
Bolts, This depend on where you mount your ram. We ended up putting a longer bolt in for my pan hard bar and ran the ram on the back side of that. Joe fabbed up a nice little plate to bolt the ram to my tie rod with three u-bolts, then we tack welded it in place just to make sure it did'nt move, (only after we knew it was all working properly).
Step 5
Change your lines around. I am half kidding here, but It is hard to know which line to run to which side of your gear box. Like the guys at West Texas Offroad said; "If it binds, switch your lines". When I started up the truck the first time, I could not turn the wheel at all. This means the lines are switched. I simply swapped the lines real quick, and nothing happened. Now I was concerned. Then Joe said the Power steering pump sounded a little noisy so I checked it. sure enough it was low. I advise you to have an extra quart of fluid to put into your system when you hoock up the ram. Once I topped it off, it worked smoothly. I was amazed at how easy it turns. We ran it down the highway and there is no travel at all in the front end. I even let go of the wheel over a groovy section of road and the truck tracked straight and true. I could not even let go of the wheel on a smooth portion of road before without my truck switching lanes at will.
I am telling you not to waste your money on a dual steering stabilizer kit if you lift your truck. You need to do a ram assist. Ironically the ram assist setup is cheaper than the dual stabilizer kit I took off.
