C6 problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-15-2010, 08:33 PM   #1 (permalink)
Member # 99055
C6 problems
hey everybody
im helping a friend finish up a TJ build he started long ago. hes running a 302 with a c6 tranny. one day we were driving down the road after test driving it, and all of a sudden it was like the brakes locked up. we slow down and find that the tranny has shifted into first, and is now stuck in first gear. we can get it to drive fine in first and it has a lot of pick up, but cant get it to shift into second unless we manually put it in "D" or "2" and then it bogs terribly and makes no power
any suggestions or does it sound shot. a friend was thinking vacuum line. tranny fluid is full and doesn't smell burnt
iwishihad1 is offline   Reply With Quote
Old 06-15-2010, 08:51 PM   #2 (permalink)
Member # 9152
Originally Posted by iwishihad1 View Post
hey everybody
Drop the pan and look for chunks of clutch springs.
Why kill them with kindness when you can use an axe?
78bronco460 is offline   Reply With Quote
Old 11-08-2011, 07:32 PM   #3 (permalink)
Member # 99055
sorry to bring this up from way back when, but friend is finally getting serious about fixing the tranny.
Now if we pull the pan and see clutch springs is it easier to rebuild it, or just find a used C6 somewhere.
Ive never been inside a transmission (auto, or manual), but I can pick up on stuff relatively quick
Old 11-09-2011, 12:33 AM   #4 (permalink)
Cactus Farmer
Dr.Danger's Avatar
Member # 168243
If there ever was a transmission to rebuild, the C6 is it. Any beginner can probably put one together successfully, using almost no special tools. They are very stout as is in stock form, and it won't break the bank to make it a little stronger.
That being said, finding a used one in the junkyard will probably not be a problem. Do whatever is more convenient.
-Dave
Dr.Danger is offline   Reply With Quote
Old 11-09-2011, 08:07 AM   #5 (permalink)
Member # 111711
I built mine by myself with basically no special tools in one night. They really aren't hard at all. Just keep up with exactly where everything goes.
jeepyj027 is offline   Reply With Quote
Old 11-09-2011, 04:45 PM   #6 (permalink)
Member # 40162
Check the vacuum line going to the modulator on the passenger rear of the transmission- maybe try a new modulator too before going to the big step of rebuilding the transmission. I had a truck that was acting just like that a few years back, and it was the vacuum line had popped off up at the manifold.
If it does need rebuilt, like the others said, it is pretty damn simple. There used to be a VCR tape available to walk you through the process.
"Time you shut your cake-hole, YOKO!!!"
wyldstallyn73 is offline   Reply With Quote
Old 11-09-2011, 05:15 PM   #7 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
my E4OD went out in my f350. i wanted to do it myself but school wont let me... so i dropped 2 G's on it for a local shop to rebuild it
if you have the time and no money, seems practical to diy
jeep is getting a new home!
NEW PROJECT ON THE HORIZON!!!
E-350
12 valve cummins, 2006 F350 axles, 6" lift and 37's
FordX4-offroad is offline   Reply With Quote
Old 11-09-2011, 05:53 PM   #8 (permalink)
Horsepower Junkie
huff75's Avatar
Member # 173427
Not to Hijack but does anybody have a reccomendation on a rebuild manual for the C6???
Haynes, chiltons, others???
Also I have seen a rebuild DVD. Has anyone seen it? Is it worth a shit? Just wanting somthing with as much detail as possable and C6 specific. Not a generic, covers 10 other transmission manual. Thanks!
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress
The Making of a Turd: Huff's Green Turd
huff75 is offline   Reply With Quote
Old 11-09-2011, 09:14 PM   #9 (permalink)
Hardcore Web Wheeler
Whitetrash303's Avatar
Member # 102426
The first one I did I used the video. Very detailed, went flawlessly. I actually have the VHS right here. There is a phone number on it but no web adress. 1-888-785-2604 Video #1206 Ford C-6.
If you want to build for performance search in here a bit. I remember a thread about using E4OD guts to build em tougher. And I made a thread years ago about a poormans shift kit.
The Answer to 1984 is 1776
Whitetrash303 is offline   Reply With Quote
Old 11-10-2011, 08:31 AM   #10 (permalink)
scooter141's Avatar
Member # 82838
Yes!!!!!!
ATSM (auto trans service manual). Oriellys can order them if you can talk to someone that has a brain and gives a shit......
If they cant help you call
Blumenthal Transmissions
(405) 232-9557
301 S Western
Oklahoma City, OK 73109
They keep themin stock.
Seem like it was around $40 but worth every penny. Best manual out there ! ! !
DRUNKEN ROCK BRIGADE
Bronco II,Rockwells,5.0L H.O.,C-6,203/205,44's.
scooter141 is offline   Reply With Quote
Old 11-10-2011, 10:41 AM   #11 (permalink)
Newbie
PowerStrokeTim's Avatar
Member # 55462
Originally Posted by scooter141 View Post
Yes!!!!!!
X2! I got one of those to help a friend build the 46re in his jeep. Worth the cost for sure.
2003 F250: 6.0 PSD, 6spd, 35" tires, Tow rig/DD
1978 F150 Truggy: 351M with GM TBI, 4spd, ARB'd 60, 4 linked 14bolt rear, 42 TSLs
1967 Fairlane GT: worked over 390FE, factory 4 speed, cage, etc.
PowerStrokeTim is online now   Reply With Quote
Old 11-10-2011, 12:28 PM   #12 (permalink)
Cactus Farmer
Dr.Danger's Avatar
Member # 168243
I haven't used them before but I heard the www.badshoeproductions.com videos are pretty good.
-Dave
Old 11-10-2011, 05:00 PM   #13 (permalink)
Horsepower Junkie
huff75's Avatar
Member # 173427
Thanks guys! I will get one. I may get the video too.
