best intake? 347 stroker - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-25-2010, 03:33 PM   #1 (permalink)
Member # 123663
hey guys i'm curious on what intake i should run on my 347 stroker right now i have a professional products air gap style from my last combo in my truck but i think there are better intakes out there, well here is the combo
Truck
89 f-150
33x12.5r15
4200lbs
Motor
dss 347 kit with .040 over pistons (349 actual ci)
10.39:1 compression
trick flow twisted wedge as cast 190cc heads (unported)
Cometic Head Gaskets and 7/16ths arp head bolts
comp cams gold rocker arms (the ones with the 7/16ths stud) 1.6:1
comp cams 280hr
Valve Lift: In: .56 Ex: .598
Duration @.050 In. 224 Ex: 230
Ad. Duration In. 280 Ex: 286
Comp Cams Magnum Roller Lifters and the springs they said to use
Quick Fuel 750 Mechanical Secondary Carb
MSD E-Curve Dissy with Taylor wires Blaster II Coil
1 5/8ths primary tube headers with a 2.5in collector and 2.5in exhaust with summit welded mufflers exiting before the axle no H or X pipe
K&N 14x3 air cleaner with a K&N filter plate on top
NOS 125hp spray plate
AOD
performance built locally by eds transmissions
Lentech Street Terminator valve body
cutsom stall converter don't know the stall speed yet but i think it's gona end up around 3500-3800rpms
3rd and OD still lock up the converter
Diffs
D44ttb (yuck) 4.56 gears open carrier
8.8in 4.56 gears trac lock set up to be almost like a spool with extra clutches and different clutch pattern
1966Tbird is offline   Reply With Quote Quick reply to this message
Old 06-25-2010, 03:43 PM   #2 (permalink)
Member # 115381
Send a message via Yahoo to fatboyf150
f/i or carb?
[COLOR="Lime"]What happens in the Cooking Forum, stays in the Cooking Forum.[/COLOR]
fatboyf150 is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 01:36 AM   #3 (permalink)
Havok450's Avatar
Member # 138949
Send a message via MSN to Havok450 Send a message via Yahoo to Havok450
carb
My friend hates Chevy, but owns 2, wtf
Havok450 is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 09:25 AM   #4 (permalink)
dgfordman's Avatar
Member # 70242
we've been having really good numbers out of the parker funnel intake on our 347 sprint car motors. they are decent priced as well. just throwin that out there.
dgfordman is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 09:50 AM   #5 (permalink)
Member # 130992
those are knockoffs. you cant get the real parkers anymore. he did have a couple recently but they werent machined. they are like 500 bucks if you can get one, not 250.
id get a Performer RPM or something like that. you dont have a lot of cam so im assuming you wont be going much over 6000 rpm.
79 F250 410/T18/205/D60/D60 CHI Heads Roller 39.5
92 W250 5.9/G360/205/D60/D70 s362 5x.016's 33
JBradley500 is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 04:24 PM   #6 (permalink)
dgfordman's Avatar
Member # 70242
they may be knock offs but they flow really good numbers out of the box. better than victor jr's or super victor jr's. we've tried about 6 different intakes and the "knock off" parkers are what we keep goin back to.
Bunch of Ford parts with too much power.
fucncrawlin
Old 06-27-2010, 04:47 AM   #7 (permalink)
Member # 107761
Weiand Stealth.
'75 Bronco with assorted parts
ken75ranger is offline   Reply With Quote Quick reply to this message
Old 06-27-2010, 05:27 PM   #8 (permalink)
unit dude
FORDTECHGURU's Avatar
Member # 104639
ported rpm or ported stealth, your not gonna beat them, the funnelweb wont take over till 4500 up..
FORDTECHGURU is offline   Reply With Quote Quick reply to this message
Old 06-30-2010, 10:35 AM   #9 (permalink)
Member # 123663
thanks for the feedback guys really appreciate it i think i am going to go with the weiand stealth intake and get it ported, who would you guys recomend to get the intake ported? does it really need to be ported?
Old 06-30-2010, 02:38 PM   #10 (permalink)
unit dude
Member # 104639
no, it will run fine, but, the heads flow more than the intake, so, to see the full potential of your heads it will need to be ported. think of it as 20-25 more hp...
