79 Crew build. - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-13-2011, 09:18 PM   #101 (permalink)
5BrothersFabrication's Avatar
Member # 177573
Sorry to hear about your dad. What are you doing with all your donor trucks? I'd like to get that cab off the 2wd bed-donor truck.
5BrothersFabrication is offline   Reply With Quote
Old 02-21-2011, 06:32 PM   #102 (permalink)
Member # 104943
All my donors get stripped of any good parts and i sell the rest. I already sold the truck the bed came off of.
So i got the hubs rebuilt for the rear and calipers on and it mounted along with my overloads. Also got my fuel tank today. Welded in the bung for the return line and put a couple coats of acid etch primer on it and ill prime and paint it tomorrow.
I might still have to put a 3" block on the rear before its all said and done with.
crazyredneckanyhow is offline   Reply With Quote
Old 04-05-2011, 03:03 PM   #103 (permalink)
Member # 115833
Any updates? trucks looks
98.5 dodge 2500 CTD , 87 LWB Suzuki samurai
87 Suzuki samurai R.I.P
zukitoon is offline   Reply With Quote
Old 04-05-2011, 05:43 PM   #104 (permalink)
Member # 104943
Ive got a bit done. Ill try to get some pics after bit.
Old 04-06-2011, 02:23 AM   #105 (permalink)
Member # 56456
Originally Posted by Ibuildembig View Post
Weld the front on a street truck?
Not like you drive with the hubs locked in.
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205
Fordman500 is offline   Reply With Quote
Old 04-06-2011, 01:32 PM   #106 (permalink)
Member # 103437
What happened the rear shackle flip and the orange hubs u pictured earlier?? love the build looks tits!!! I wish i could have a project like that Keep up the great work!!! I just got a 79f150 and this build is great inspriation for me
angelfly is offline   Reply With Quote
Old 05-02-2011, 04:38 PM   #107 (permalink)
Member # 104943
Ok all you cork snugglers i finally had time to go get a new memory card for the camera. Not alot of pics because most of what i got done fits into the engine pics. Anyhow. Other than the alternator and belt the motor is done. Trans crossmember is in along with the trans. Still working on the transfer setup. Heres a couple pics of the motor. Note the shiny importish turbo elbow. Stock pull offs on ebay were $80-100 plus shipping. Guy in vegas had this for $40 shipped. Im not a big fan but it was in my price range.
So heres the trans xmember. I solid mounted the trans to the xmember and bushing mounted it to the frame. Also had to do a cutout for front dshaft placement.
Also tucked up real nice. Only got about 1" hanging below the frame.
Heres a pic of how it sets now. Waiting on new windshield gasket to get here.
And heres a couple paintjob pics
Old 07-21-2011, 04:45 PM   #108 (permalink)
Member # 104943
Got a little more done. Downpipe is in along with the tcase side mount. Also got the tcase shifter done. Cab is back where it needs to be. I still have to do a little floor work for the tcase shifter. Looks like ill need some heat wrap for the downpipe.
Old 07-21-2011, 04:46 PM   #109 (permalink)
Member # 104943
Couple pics of my hydro clutch conversion.
Old 07-21-2011, 04:48 PM   #110 (permalink)
Member # 104943
So heres the throttle setup. Pedal is from a 88-96 chebby truck and the cable is from a 70s f-series with a 300 I-6. Also took the plastic crap linkage off the pump and made this from heims.
So as far as the radiator goes. I modified the stock rad cradle to fit the 93 dodge radiator. Heres the lower plate and the uppers i made. Uses the stock cummins rad hoses
Lower IC mounts.
Random turbo shot and small glimpse of how i loomed the wires.
Old 07-21-2011, 04:49 PM   #111 (permalink)
Member # 104943
Oh and theres this.
Old 01-27-2012, 02:45 PM   #112 (permalink)
Member # 104943
Ok so ive got this thing together and took it for a drive today. Ive got a couple of problems i need advice on. Both are suspension and steering related. Ive got real bad bump steer and some death wobble. Ive already been told to put a trac bar on it even though it has leaves. Would that be my best option? And with the bump steer i have crossover and highsteer so i thought that shouldnt be a problem. But it shakes pretty hard.
Old 01-27-2012, 03:04 PM   #113 (permalink)
Banned
Member # 158768
post a pic of your steering if you can. i have a few ideas but need to see it before i am sure. or text or fb me a pic.
p.s. dirty jew
fatdan460 is offline   Reply With Quote
Old 01-27-2012, 03:16 PM   #114 (permalink)
Member # 104943
Old 01-27-2012, 03:21 PM   #115 (permalink)
Banned
Member # 158768
it's probably because your cheap ass only put 2 bolts on the steering box
i'll get at you later tonight about it. gotta head to town.
Old 01-27-2012, 04:19 PM   #116 (permalink)
73 ford guy's Avatar
Member # 54530
How are your kingpins? And if you Havnt yet,put a couple 1/8 thick washers under kingpin caps. Make sure all suspension bushings are new and maybe even rubber cab mounts. O and tires. That might be your biggest issue. Make sure they are properly balanced. I'd start there as most stuff is new anyway I'm guessing.
73 F-250 44's,428,twin sticked 205,60 fr,70 rear,ARB/Detroit,crossover high steer/hydro assist,winches
73 ford guy is offline   Reply With Quote
Old 01-27-2012, 06:12 PM   #117 (permalink)
Member # 104943
Everything in the front is new including the springs. Cab bushings are new poly. Tthe highsteer arms are the springless ones and are adjusted as tight as i can get them.
Old 01-28-2012, 03:50 PM   #118 (permalink)
Member # 104943
So the front springs are moving side to side a quite a bit so it looks like a trac bar is needed. What about this kit? Get the inside mount frame bracket and the centered axle bracket. Mount the axle side to the pass side spring plate. Also with this being a leaf sprung truck does the trac bar need to be parallel with the drag link the same as a coil sprung truck?
http://www.ruffstuffspecialties.com/catalog/PANKIT.html
Old 01-28-2012, 04:11 PM   #119 (permalink)
Member # 54530
I Already mentioned on FTE a panhard doesn't do shit. Had one.. Useless
Hydro assist that bitch
Old 01-28-2012, 05:25 PM   #120 (permalink)
Newbie
Member # 182450
Is there a reason you have both the high steer and the factory tie rods in place?
SBCWelder is offline   Reply With Quote
Old 01-28-2012, 05:36 PM   #121 (permalink)
Member # 104943
I just had the factory tie rod in there to line everything up. Its gone now.
Old 01-28-2012, 07:25 PM   #122 (permalink)
EricsGreen98Tj's Avatar
Member # 187456
Sub'd.
Looks DAMN GOOD man....I like it. ALOT!
Looking for a hydraulic FORD 4 speed bellhousing and the clutch fork. PM me with any leads please.
EricsGreen98Tj is offline   Reply With Quote
Old 01-28-2012, 08:01 PM   #123 (permalink)
ffdustyw's Avatar
Member # 25517
Send a message via Yahoo to ffdustyw
WHOA!!!! Fucking badass build! I would buy this from you for a tow rig in a heartbeat! Hadn't seen this build before.
97 Dodge 1500 Dueces, OEM spool/ARB, 54" Baja Claws, 16" Coilovers, Atlas II 3.8:1, PSC Full Hydro, Hughes Engines 408c.i. F.A.S.T/46re with 48re internals
Kodiak Dodge Build:http://pirate4x4.com/forum/showthread.php?t=702415
Dodge,Duck, Dip, Dive, & Dodge
ffdustyw is offline   Reply With Quote
Old 01-28-2012, 08:42 PM   #124 (permalink)
Member # 104943
Says the guy running rockwells and 54s. Ill take that compliment lol. thanks.
Old 01-28-2012, 08:46 PM   #125 (permalink)
Member # 104943
I guess i should update this a little bit. I ended up using a cut down factory bed. Took 12" out of the front of it. Also built a rear bumper and ive started on the front.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
