06 f250 4x4 auto locks wont work? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-15-2010, 12:08 PM   #1 (permalink)
Member # 166375
Question 06 f250 4x4 auto locks wont work?
Hey yall, I did a quick search but no luck, I have a 06 ford f250 4x4 with the auto hub locks. when I engage the switch the lights will come on but will not engage the front diff, I can manually lock the hubs and they work fine, Is this a sensor or I have heard "o"rings, Thanks for any info...
bigrigrockrunner is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 01:28 PM   #2 (permalink)
section525's Avatar
Member # 14692
Send a message via AIM to section525 Send a message via Yahoo to section525
Does your AC blow out your defroster? Check that and report back.
1975 Ford Bronco
section525 is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 01:41 PM   #3 (permalink)
Member # 162933
what? ac? have you ever had the front seals serviced?
nut up or shut up
blacker is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 02:04 PM   #4 (permalink)
section525's Avatar
Member # 14692
Yeah, the solenoid that controls the vacuum going to the auto hubs also controls the AC vac controls. So if one goes out.. the other will too.
1975 Ford Bronco
Old 08-15-2010, 02:54 PM   #5 (permalink)
unit dude
FORDTECHGURU's Avatar
Member # 104639
Originally Posted by section525 View Post
Yeah, the solenoid that controls the vacuum going to the auto hubs also uses the same source as the AC vac controls. So if one goes out.. the other will too.
fixed it for ya..
he is asking you that to see if you have source vacuum, the a/c defaults to defrost and the vacuum pump is a common failure point, so is the solenoid, so are the seals...
FORDTECHGURU is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 02:55 PM   #6 (permalink)
Member # 166375
A/C blows good and where its supposed to, I have not6 had the hubs serviced, I just bought this truck and have a few bugs to work out
Old 08-15-2010, 03:05 PM   #7 (permalink)
section525's Avatar
Member # 14692
Originally Posted by FORDTECHGURU View Post
fixed it for ya..
There you go!
Sounds like you're having the same problem I chase every winter on my '04. I know that solenoid going out is the most common problem. It happened on my Dad's '07 at about 19k miles.
I've cleaned and rebuilt my hubs with new o-rings. Still don't work. So... let me know if you come up with a solution.
FTG.. have any advice?
1975 Ford Bronco
Old 08-15-2010, 05:05 PM   #8 (permalink)
Member # 4176
Follow through this link and see if it helps
http://www.guzzle7pt3.com/nblube.php
StoopidMonkey is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 06:37 PM   #9 (permalink)
Havok450's Avatar
Member # 138949
Send a message via MSN to Havok450 Send a message via Yahoo to Havok450
My buddies '02 had a similar problem. his ac didnt work from the time he bought his truck used, but his vacuum lines had dirt clogged in them somehow. He cleared the lines and they started working again... my .02
My friend hates Chevy, but owns 2, wtf
Havok450 is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 07:21 PM   #10 (permalink)
unit dude
Member # 104639
if you have source vacuum and the indicator lamp shows 4x4 it means the system thinks it is working and the t-case has shifted, the solenoid recieves a command from the module and either applies 7" or 14" to unlock or lock the hubs, it works like a ballpoint pen, click it once and it locks, click it again and it unlocks, difference is it gets 7" to unlock and 14" to lock. the solenoid has to deliver the right amount of vacuum and the hubs have to hold it, if you have a vacuum gauge or pump, test the vacuum from the solenoid to see if it is working as described, next pull a vacuum on each wheel seperately and see if it holds, it should, common issues are, fitting in knuckle is plugged, vacuum leak inside knuckle, solenoid failure, or external leaks...
Old 08-15-2010, 09:01 PM   #11 (permalink)
1sicbronconut's Avatar
Member # 37866
I see external leaks the most, broken flex lines at the knuckle or a melted line by the RH exhaust manifold. A longer term external leak will also burn up the vacuum pump in time.
"Diamond plate is the off road equivalent of an Adam's apple on the newly divorced woman who just drank you under the table at TGIFridays."
1sicbronconut is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 09:25 PM   #12 (permalink)
Member # 166412
Warn premium manual locking hubs can save you a lot of headaches from vacuum issues but I don't believe it could be a vacuum issue if you've got air blowing from somewhere other than the defrosters. (as a previous poster mentioned) It's got to be some other type of issue.
7.3 rocket is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 11:04 PM   #13 (permalink)
section525's Avatar
Member # 14692
I've checked for cracked hoses at the knuckles and while I was there I pulled off the lines to check for vac by just listening. I didn't know about the 7# and 14# thing. I'll have to put a gauge on it. Thanks.
1975 Ford Bronco
Old 08-15-2010, 11:35 PM   #14 (permalink)
jasonmt's Avatar
Member # 3236
Around here it is not uncommon to blow up the locking hubs when it is -30C and colder and you rely on the automatic locking portion instead of the manual.
Warn does not make lockout hubs for the 05+ SD's with 35 spline outer shafts.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 11:53 PM   #15 (permalink)
Member # 4176
That article i posted says its generally the knuckle seal is usually the culprit.
Old 08-15-2010, 11:57 PM   #16 (permalink)
section525's Avatar
Member # 14692
That's the exact article I used while servicing my hubs last winter. As much as I was hoping that was my problem... it wasn't.
1975 Ford Bronco
Old 08-16-2010, 12:42 AM   #17 (permalink)
EODguyJake's Avatar
Member # 45359
Unless you REALLY want to keep your auto locking hubs (with their plastic guts), Summit has the Mile Markers on sale for $95, down from $165. Pretty damn good price, I ordered some yesterday. If you do decided to go that route, definitely double check that they work for your 06. There was some discussion about whether or not those hubs fit the 05 and up rigs on one of my Super Duty forums. Don't know if it got answered or not. Just a suggestion.
Initial Success or Total Failure-EOMFD
EODguyJake is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 11:30 AM   #18 (permalink)
Member # 162933
ok first off ford tech guru listen to him everyone else that says their friends buddy's cousin had the same problem and that the solenoid is the most common its not. simply put your seals are a service item and if not installed correctly with a dealer seal driver to will not have auto hubs simply put. being your truck is an 06 they probably havent been done ever because dealers fail to upsell them. get your seals checked. to all the other super duty owners out their with auto hubs. just because you already did the seals does not mean that you did them right. just as the 05+ front ends the 99-04's need the proper depth set as well. its the same post on every 4x4 site out there 40 times a year.
nut up or shut up
Old 08-16-2010, 11:31 AM   #19 (permalink)
Member # 162933
pin holes in the vac lines are the 04- present f150's from the rh ex manifold
nut up or shut up
Old 08-16-2010, 12:20 PM   #20 (permalink)
unit dude
Member # 104639
or battery acid
Old 08-16-2010, 08:35 PM   #21 (permalink)
Member # 37866
As far as I know there are no aftermarket hubs for the 05' and newer Super Duty's Trucks Can someone prove me wrong?? Thought I saw some listed once but can't seem to find them now
Old 08-16-2010, 09:04 PM   #22 (permalink)
jasonmt's Avatar
Member # 3236
The only people that will tell you that the Warn/MM etc. locking hubs for an 04 down will work on a 05 plus (outside of an 05 Excursion) are the ones who have never worked on a 05 plus front axle.
Old 08-17-2010, 12:19 AM   #23 (permalink)
EODguyJake's Avatar
Member # 45359
That's why I didn't make the positive statement that they would work for an 06. I kinda remembered there was some discussion about it while I was typing that post, so I made sure to CMA by throwing the "double check" in there. I figured someone in here would see it and clarify. You da man.
