Kyle M's Booger reconstruction..... - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-13-2010, 04:19 AM   #126 (permalink)
Member # 104229
Nice!
Hey again, looks good, were you on the gas lines around our places? couple of those spots strike my memory. Nice weather ah? I got stuck scouting ice fishing spots with my brother. I have vacation starting the 21st . maybe hit tin cup? ramble over
PROFABBY
PROFABBY is offline   Reply With Quote
Old 12-13-2010, 06:51 AM   #127 (permalink)
Member # 104229
doubler
SO, what's the specs. on the transfercases? been thinking of these lately.
PROFABBY
Old 12-14-2010, 08:21 AM   #128 (permalink)
86 slo-vo's Avatar
Member # 148322
Originally Posted by Kyle M View Post
Good to know....we will see. Found a box local to me, offered the guy 100, he told me 150...maybe I can get him to split with me.
Kyle, I've got the short bed off my truck... If you come and get it, you can have it...
Would be a good reason to hit TB with us
94 ranger, d35 8.8, 4.10's detroit locker/truetrac, duff long arm, chevy 63's 36 sx's
86 slo-vo is offline   Reply With Quote
Old 12-14-2010, 01:47 PM   #129 (permalink)
Kyle M's Avatar
Member # 165077
Naw, they were up to tin cup. Hit me up if you wanna go.
The cut doubler case is a 1350M and the full back base is a 1354M.
I would love to come down a wheel with ya and pick up the bed...kinda long drive but we will see
Maybe next spring??
93 RANGER 4D'S/V8/TONS
Kyle M is offline   Reply With Quote
Old 12-14-2010, 02:25 PM   #130 (permalink)
Member # 174901
awesome build dude looks awesome
shooterdude199 is offline   Reply With Quote
Old 12-14-2010, 02:34 PM   #131 (permalink)
86 slo-vo's Avatar
Member # 148322
if its still around come get it....just better hope i dont get excited and build a trailer out of it lol
Old 12-19-2010, 03:13 PM   #132 (permalink)
Kyle M's Avatar
Member # 165077
Alright, went wheeling yesterday, get to test the winch out a few times...and I finally found an issue(knew it would be eventually) but I poped my front drive shaft out, time for a long travel slip or just limit the droop, or both I was climbing a hill and I caught some air going up it, came down and heard flop flop flop...looked out and saw no tire spin, but it was an easy fix.
My truck broke...
my buddy freezing, fixing it for me
So on to the temporary solution
I have never checked how much engagement I have in my front shaft, it just never gave me any issues until now. But after seeing it apart I saw I had very little and since I pushed my axle forward about 1.5" I almost need to lengthen it too. Plan is to make a new one when I do the doubler so I just need something to work now. So I was in the garage and just happened to have a couple front shafts laying next to each other, one out a Ranger, the other out of and Explorer.
bottom one is the Explorer one, the top one is the Ranger one. Notice a difference between them?? I did...
the explorer slip area is about 1.5" longer. So my plan is to swap the front slips around and hopefully I will extend my shaft about 1.5", which will give me more engagement and should be a good temp solution until I limit it and build a new shaft. Here is the shaft on my truck as it sits now
Old 12-20-2010, 01:50 PM   #133 (permalink)
nobearsyet's Avatar
Member # 131741
good thinking, kindsa like using a dodge auto trans driveshaft when you put a manual trans cummins in a ford.
Paging Jake Andrews, where you at buddy?
nobearsyet is offline   Reply With Quote
Old 12-28-2010, 05:10 PM   #134 (permalink)
Kyle M's Avatar
Member # 165077
Some work done, changed steering up a little.
You get the idea, but it is all 3/4" heims, with 3/4" bolts. The pitman arm is still cooling at work so it isn't on, but it will be a 5/8" bolt in double shear. The tube is 1.5" dia 1/4 wall DOM. All the gussets and tabs are 1/4"
I also swapped the Ranger slip out for the Explorer one, seems like it is gonna work.
Old 01-03-2011, 07:05 PM   #135 (permalink)
Kyle M's Avatar
Member # 165077
its junk right?? Fawk it, I'll still update
Steering did great saturday, no isses.
Something broke in the front pig...and I developed a funny squeak.
Good news, locker is fine, everything looks to be in place.
Bad news, ring gear is broke.....F'n yukon gold.....
and I figured out my squeak, not sure how I made it driving around not noticing this...
My brake line running down the radius arm, split in 2, did it on some rocks. My brake was dragging since it wasn't connected anymore. Maybe I need to figure out something better for that, normally it runs on the inside towards the top of the arm, something must made it twist/rotate down..... Funny I didn't lose my brakes, least I had something going for me!
Still, lots of fun, got one vid of me getting some body damage, nothing else to show really
[YOUTUBE]gpcWtt8iZrk[/YOUTUBE]
Old 01-03-2011, 10:55 PM   #136 (permalink)
Forever being built
wahlstrom1's Avatar
Member # 94308
I'd run the line where you had it again, but tack weld some small angle iron on top of it to protect it, and hold it in place (isolated against rubbing of course).
Originally Posted by Rocky View Post
Never thought I would ever get excited about a backsplash or faucet, but I never had a sink with a front diff before either....
wahlstrom1 is online now   Reply With Quote
Old 01-04-2011, 07:06 AM   #137 (permalink)
nobearsyet's Avatar
Member # 131741
Even better yet run it like you had it with a little piece of channel layed on top of it so it's protected on all sides.
Old 01-04-2011, 07:27 AM   #138 (permalink)
Member # 104270
Hey man I haven't seen this thread in a bit since I was in northern Kent which the internet is still new and scary there... Truck looks good bummer about the ring gear, is it under warranty? Love the double shear pitman arm.
Fueled by Hate, caffeine, and sometimes whiskey.
My Junk.
http://www.pirate4x4.com/forum/showt...229&highlight=
br0nc0xrapt0r is offline   Reply With Quote
Old 02-06-2011, 12:26 PM   #139 (permalink)
Kyle M's Avatar
Member # 165077
Alright, I think it has been long enough, time for an update!
Well after waiting 4 or so weeks to hear back about my warranty on my gears, unable to get ahold of anyone to find out what the fawk was going on I decided to just go ahead and buy the stuff to build the HP 44. So I ordered up new gears and carrier, then picked up some 1.5" dia DOM for a new tie rod, some weld in bungs and a few other odds and ends an got started last weekend. Still don't know about the LP gears, but o-well, maybe I can sell them if I ever see them again.
Anyway, finished it all up today, looks good and drives good too.
here are the pictures!
full width...little off center, bout 3/4", shoulda spend more time centering it. I might have the adjustment in my heims, other wise I can shorten my track bar to fix it, O-well, it'll still wheel the same. The front is about 2" wider overall than the rear, I will run it this way for a while.
New to me HP
Limit straps I just put on, 18" long
My fix for my brake line guard, 1" angle. Looks good IMO and should work great.
Then just a few so we all remember how it looks....beat and bruised
Next on the todo list is put the explorer axle under it, inboard the springs, lose the blocks. I ordered a 8.8 ruffstuff diff cover and axle swap kit. I am also in process of making some new spring hangers. Gonna start this in a few weeks.
Thanks for looking!
Old 02-06-2011, 12:30 PM   #140 (permalink)
86 slo-vo's Avatar
Member # 148322
New to me HP
Thanks for looking!
Looking good Kyle.
Old 02-06-2011, 06:56 PM   #141 (permalink)
nobearsyet's Avatar
Member # 131741
looks good man.
Old 02-07-2011, 12:12 PM   #142 (permalink)
Kyle M's Avatar
Member # 165077
Thanks guys
Old 02-23-2011, 04:25 PM   #143 (permalink)
Kyle M's Avatar
Member # 165077
Little shot of things to come....
Old 02-23-2011, 04:27 PM   #144 (permalink)
Kyle M's Avatar
Member # 165077
New sliders, here they are
Old 02-23-2011, 04:30 PM   #145 (permalink)
Kyle M's Avatar
Member # 165077
here is a shot of my new to me FW 8.8
Just gotta decide if I'm gonna nut up and buy the Dutchman axles or just redrill mine 6 lug......
Then I did this last weekend
Ooops, not again!
Old 02-23-2011, 10:28 PM   #146 (permalink)
Member # 125261
Nice build, I like it. Another mentioned this earlier in the thread and I will again. Work on those radius arms some more! I have seen a few brake built like yours and seen several pics online as well. Dont want to take a chance with your little co-piolit in there!!! I would suggest sleaveing them and filling in the "C" area with some plate. BTW, great flex from a streetable rig! Good Luck.
Redbeast9 is offline   Reply With Quote
Old 02-24-2011, 08:34 AM   #147 (permalink)
zachis4wheeling's Avatar
Member # 41212
Send a message via AIM to zachis4wheeling
Good to see some more Michigan boys on here, rockin the Rainjuhs.
I just got inside from working on mine....outside in the 14 degree weather = the SUCK.
I used to live in Traverse City, and a lot of your wheeling pics at Twisted Trails and the snow wheeling pics look familiar. I miss it up there so much. Quite a bit of wheeling, without a really long drive.
Did you redo any of your wiring harness or reroute any of it under the hood when you swapped bodies?
SUPPORT YOUR LOCAL FIRE DEPARTMENT
zachis4wheeling is offline   Reply With Quote
Old 02-24-2011, 02:49 PM   #148 (permalink)
Kyle M's Avatar
Member # 165077
Your right, I should......but I don't feel like doing it, lol. One of these days I will probably get around to it.
Thanks!
Lots for Rangers in this area. And, I am ready for SPRING TIME!!! SIck of this cold, non motivating weather.
Yeah, I wheel at Twisted Trails and ROcks and Valleys mostly, fun places to go.
As far as wiring, the only thing I 'had' to do was move the battery since the hoops were in the way. The body swap, and harness swap was plug and play. It was a 93 into a 93.
Thanks for looking!
Old 02-24-2011, 03:27 PM   #149 (permalink)
ShinerTV's Avatar
Member # 174339
Fuggin jealous factor 10!
ShinerTV is offline   Reply With Quote
Old 02-28-2011, 05:21 PM   #150 (permalink)
Kyle M's Avatar
Member # 165077
LOL, thanks
Got some goodies today...
Then I made these after work today, spring hangers for the inboarded 63's
I also acquired some T case parts today to help with the doubler intermediate shaft (no pictures yet)
