What converter should i use in my c6??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2010, 12:28 PM   #1 (permalink)
Member # 161739
Ok i have a 79 bronco. I am swapping in a 1970 ford thunderbird 429. It is going to mostly be for mud and some trails. The motor is all stock for now. But in the future want to build it up a little. I have 4.10s and running 36s. i was just seeing if any one knew if the t-bird converter or the bronco one would be best to use. Oh the bronco had the 351m. Thanks for any help.
robn69 is offline   Reply With Quote
Old 10-24-2010, 02:50 PM   #2 (permalink)
Member # 109675
For mud the stock bronco would be the best it has a higher stall. One is 1200 and the other is 1800.
bigwhitebus is offline   Reply With Quote
Old 10-24-2010, 02:56 PM   #3 (permalink)
Member # 171833
ya but that t bird one is brob wut ur gonna need cause of the crank hole dia is i think 1.85 and the one outa the bronc might be a 1.375...check it out b 4 u go and put it together ...Jordan
BlueBitch is offline   Reply With Quote
Old 10-25-2010, 07:47 PM   #4 (permalink)
Member # 161739
Ok thanks for the help guys.
