Are dana60 and dana 50 hubs the same - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-07-2010, 02:53 PM   #1 (permalink)
Member # 173381
im trying to find a 86 f-350 dana60 srw hub and rotor asembly but only listing they got is a dana 44hd and the people at the parts department only knows what the computer is telling them. so my question is can i use and dana50 hub and rotor from the same year instead? i know the locking hub will fit but i was just wondering about everything else. let me know what you think thanks much appreciated.
87bronco11 is offline   Reply With Quote
Old 11-07-2010, 03:22 PM   #2 (permalink)
Tonka Truck Driver
fatboyf150's Avatar
Member # 115381
Send a message via Yahoo to fatboyf150
how about search. this was just talked about, so it should be easy.
What happens in the Cooking Forum, stays in the Cooking Forum.
www.facebook.com/kenneth.rivenbark
fatboyf150 is online now   Reply With Quote
Old 11-07-2010, 06:56 PM   #3 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
Yes it will work
'91 k3500, 454, 4speed, 42" R-1's no lift
'97 z-71, 3" BL, 38" tsl radial, 454/th400
'97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool,
34/10.50/16 ltb
Red Chevy is offline   Reply With Quote
Old 11-07-2010, 10:21 PM   #4 (permalink)
SMC
SMC's Avatar
Member # 8941
Yup. The Dana 50 TTB hubs will bolt directly to a D60. Just be certain you have a D50 hub! If your hitting the wrecking yards, the easiest way to tell if your looking at a D50 is the u-joints. The D50 has circle clips on the outside of the u-joints. The D44HD has the clips on the inside of the yoke, so the u-joint caps are flush with the yokes.
What will swap: The hubs, lockouts, brakes, bearings, seals.
What wont swap: The knuckle, the spindle.
Thats it
I have never seen such a ruthless bunch of people til i came on pirate... - hawkins1
SMC is offline   Reply With Quote
Old 11-08-2010, 10:25 AM   #5 (permalink)
Member # 72879
I have 50 spindles on my 60. IIRC they are just a hair shorter.
79 f350 408 435 twinstick205 d60 sterling welded 38.5boggers
03 RAM 3500 qc/sb 4x4 5.9 mild 48re
bossman79 is offline   Reply With Quote
