Transmissions compatible with the 6.9 mechanical diesel engine
I found a 6.9 mechanical diesel in a mid 80's f250, I asked about purchasing or trading for the motor, the owner said it needs a tranny, the only tranny I could find to use with it is the nv4500. What other transmissions could I use with this in my 79 f250 4x4. Is the the bbf c6 transmission compatible?
Thanks guys Loren
My friend hates Chevy, but owns 2, wtf |
Fawkin Fordhead
The NV4500 is not a factory app for the IDI's. It is not BBF pattern.
What will work is any Ford truck 4 speed, as the T19 bellhousing will bolt to a 18 or 435. The diesel C6, The E4OD, and the ZF 5 speed. Any Ford diesel transmission up until 97 will bolt to the engine.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
Cactus Farmer
Member # 168243
I believe all 6.9 and 7.3 bellhousings up to 03 are the same, with the exception being that a dowel pin or something doesn't line up on the newer ones, but from what I have heard it has been done. As far as the bolt holes go I'm not aware that they changed anything.
-Dave |
Member # 86041
Only the top two bolts of the BBF belhousing match the IDI belhousing.
It can be made to fit by modding the 4 bottom holes and dowel pins.
1994 F350 IDI Turbo Diesel, 43's, 4:88's, BW1356, ARB's F&R, Propane, 16.5 F Winch, 12K R Winch. |
h
Hey everybody, thanks for the replies, everything I found pointed towards nv4500, thanks for correcting that part, I'd like to swap that 6.9 into my 79 f250 4x4, so if this trade goes through ill be searching for a diesel c6
Member # 192237
I can't seem to find an answer on this, do the top 2 bolts have the right location to put the input shaft of the trans into the pilot bearing straight? I'm having trouble measuring this on the parts I have.
#7 (permalink) | ||
i win diesel!!1!
Member # 158768
web wheeler 4 life. Quote:
Member # 192237
Cool beans. Got a BBF bell for an NP435 and a 7.3 IDI going into a '90 ranger. The other 4 holes looked as though they could either be lined up easily, or the adapter plate/block bolts countersunk into the plate, then the bellhousing bolts relocated and new holes tapped in the adapter plate.
Just needed the bit o' info about the top 2 holes. Thanks. Last edited by [486]; 04-23-2012 at 06:03 PM. |
Fawkin Fordhead
Do you have an actual 460 bell, or a M/400 one? if it's a M/400 part, you will probably have the same problem with the flywheel/pressure plate hitting the bellhousing hitting the inside of the bell. If you have an actual 83+ 460 juice clutch bell, it is the exact same casting as the idi part, just drilled differently
Member # 192237
Hm, it does look kinda shallow near the top. Are the bolts in the same location either way? If it'll line up then I can just cut out the interfering part and make a sheetmetal cover.
The trans it came on was from '71, the bottom 4 bolts don't line up to bosses, and was sitting on a trailer by the time I got it, so is there an easy way to ID it? |
#12 (permalink) | ||
i win diesel!!1!
Member # 158768
