3 link questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-16-2010, 12:55 PM   #1 (permalink)
150
Member # 167647
3 link questions
so im about to build a 3 link on my 89 150 that is a daily driver. I have been researching alot on what joints to use but have found alot of different answers. so i figured that since it is a daily driver i should go heims and bushing instead of all heims. But if i went heims and bushing should i put the heims at axle end or frame end? And will bushings limit flex much more then having all heims? Thanks in advance
150 is offline   Reply With Quote Quick reply to this message
Old 11-16-2010, 01:10 PM   #2 (permalink)
Member # 56027
Send a message via AIM to GIJoe4500
from everything i've read, the bushings should be on the axle side. Also, if the bushings do limit your flex at all, it won't be enough for you to notice... that is.. if your suspension is designed properly.
GIJoe4500 is offline   Reply With Quote Quick reply to this message
Old 11-16-2010, 05:07 PM   #3 (permalink)
150
Member # 167647
ya i was thinking axle side but i have heard a couple people say differently.
I have been watchin your 3 link start on here and why arent you running the upper link on the drive side off of the pumpkin? There is nothin in the way on that side besides your drive shaft but if it is high enough it shouldnt be a problem?
Old 11-16-2010, 05:27 PM   #4 (permalink)
Member # 45530
bushings closest to the frame (closest to the driver) and I would go with johnny joints or a ballistic joint instead, but thats just me....
Panthers65 is offline   Reply With Quote Quick reply to this message
Old 11-19-2010, 10:16 AM   #5 (permalink)
jenks's Avatar
Member # 118119
x2 plus you can rebuild them.
[COLOR="Red"][B]Yet another TJ build[/B][/COLOR]
jenks is offline   Reply With Quote Quick reply to this message
