D44 Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-07-2010, 07:49 PM   #1 (permalink)
Member # 163632
D44 Question
I got a 5 lug HPD44 and I would like to convert it to a 8 lug, would all need to do is swap out the hub n rotors?
Ds88Z71 is offline   Reply With Quote
Old 12-07-2010, 08:21 PM   #2 (permalink)
Member # 164826
www.google.com
conversekidz is offline   Reply With Quote
Old 12-07-2010, 10:20 PM   #3 (permalink)
SMC
SMC's Avatar
Member # 8941
Your SOooo fawking helpfull, conversekidz.
You need to swap out the hubs, rotors, lockout's and most likely the brake calipers. Your best bet is to get the package deal from a wrecking yard via Chevy trucks. They had 8 lug d44's and 10 bolts for years and are plentiful in the bone yards. The hub out can be swapped over. As well as d44 HD TTB's via 90's ford f250's. There are conversion kits online as well.
I have never seen such a ruthless bunch of people til i came on pirate... - hawkins1
SMC is offline   Reply With Quote
Old 12-08-2010, 05:37 AM   #4 (permalink)
OX
Member # 3113
If your converting to ford 8 lug, you also need the spindle as the inner bearing is larger than the std 5 lug solid axle D44. Also need caliper brackets in addition to calipers, as HD44 uses twin piston calipers like the D60.
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
79 Bronc XLT, 400/C6/404 Mogs/42 roks
OX is offline   Reply With Quote
Old 12-08-2010, 06:36 AM   #5 (permalink)
Member # 53223
chevy outers is what i did on my hp44 in my 79 f250, it was an extremely easy swap and it was actually cheaper than rebuilding the ford outers. Thats the route i would go. You need everything balljoints out, including the stub shaft off the axle
Monster67 is offline   Reply With Quote
