Will M5OD-R2 internals swap into a M5OD-R1 Case?
Why' I have a a 3.0 ranger motor and want to put in a 203 to dana300 doubler, The only way to do this is to have 31 spline output shaft that the R2 has.
This is for a modified buggy so Clearance is not an issue, The only issue is the bellhousing on the 3.0 Ranger motor. that is why I need to keep the trans case.
Thanks
Thanks
