Member # 32565
Super duty panhard bar
I have a 2000 F-350. My question is if I switch to a high steer set up do I still need the panhard bar. Or will I still run into bump steer problems if I remove the panhard bar
Bump steer is a result of the panhard and the drag link being at different angles and lengths. So, if you change the angle of the drag and make it different than the angle of the panhard, then yes you'll get some type of bump steer. How much? Hard to tell from my laptop.
If you remove the panhard, you'll probably experience a worse case of wandering or tracking of the front end. Since it keeps the front axle from shifting side-to-side. . I have never experimented with this scenario, so this is just a guess. But I would think removing the track bar will hurt handling more than having it a few a degrees off from the track bar. You could look into raising the axle mount, thus keeping them closer to the same angle after going high steer
'91 F-150,ext cab, no bed, shortened WB , 5.13s, D60s locked f&r, leaks a lot |
Member # 32565
Doesn't the leaf springs keep the axle from wandering? I always wondered the reasoning for a panhard bar on a leaf spring suspension. Granted it's a lot older but my 76 3/4 ton chevy doesn't have a panhard bar and it seems to handle just as good as my F-350
#5 (permalink) | |
Member # 152532
#6 (permalink) | |
skullfuckery
Member # 29016
you all ready have an inverted y steerign system so what ever effect you have with the crossove/high would be the same as you get with the i/y system now. take you track bar off and see how it does.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Member # 167672
While you can get away with removing it. It is far from safe and your performance will suffer. It will walk and wander put consdierable lateral stress on the leafs and their mounts. All around a bad idea. Worse yet on a heavy vehicle like a SD.
High steer onthe other had is a excellent idea. You wil be able to dependign on hieght of lift go back to a stadard pitman arm which will greatly reduce stress there. Of course clearnce will be better as well. Bump steer will be greatly reduced/eliminated. Steering effort will also improve. Add a ram assist steering and you will have the best all around steering and control. All nicely up over the axle and out of the way. |
