#101 (permalink) |
Member # 147891
i talked to him yesterday with that being said. a few months ago he told me his new 231 to 205 kit was a week out and he was waiting on the shafts so i sold my 31 spline shaft i had and adapter plate and clocking ring to regain some money to buy his new kit and lost money on it. from what he told me all he has done on them is the prototype and don't plan on doing thing for a long time he says his money maker is in the jeep 231 23 spline he don't plan on doing anything else unless he has free time . even if he does produce them i am not giving him my money, im going to pay some one else to produce the kit for me thanks for nothing Duffy you are not a man of your word
to every one out their when he tells you he is going to have something done don't believe him you may be waiting for months before you realize he not going to do it. |
#106 (permalink) |
Member # 107406
this is really pissing me off, I've had my 205 amd 1356 ready for 3 months waiting on this mystery product to magically appear. Anyone have any updates? Can't get through to Duffy and I want one damnit!!
#107 (permalink) | |
Member # 147891
he should be able to make the bw adapters sorry for the big pixs photo bucket wont let me resize from my phone this my wifes np231 to ford 205 the way it is done the 231 remains in the stock location. ![]() ![]() ![]() ![]()
#108 (permalink) |
Member # 107406
Why not just order the 1356 Strong Box and bolt it in. Been following these threads and kit developments for a while now and finally reached a guy who can/will do it. Jacob@behemothdrivetrain.com
He had a roadblock on the 4340 hardened (new) shafts from another vendor who was supposed to supply them. He found another supplier, scrapped the idea of re-splining shafts, and is back in business. I just ordered the 1st one off the line . No phone tag, JB weld, shifter mods, or chopping up cases.... for about the same price as the kits... just bolt it in. I'll start a new thread with pics and action shots once I get it in.
#110 (permalink) |
Member # 70258
I just talked to Duffey and ordered the 1356/205 kit with the short shaft. (I already modded the 205 to run the shift rails out the back)
He also sells the longer shaft if you are wanting to still shift the 205 out the front like it comes from the factory. He was easy to talk to and went over fitting the block plate. I'll post up pics and an update as soon as it gets here.
1987 Samurai 5.0/ 14 bolt/ hp60 welded with 38.5 sx's on h1's C6/1356/np205 108" wb |
#114 (permalink) |
Bronco D20! The standard 1350/54 kit you make now is too long to fit in an extended cab ranger with the fuel tank in its stock location. Plus twin stick would be killer!
Seen a couple guys fab them up with welded/resplined shafts. A new 1 piece shaft would be the ticket!
91 Ranger - One tons, 3 link, air shocks, 40's....under construction Last edited by WildStyle; 02-04-2012 at 08:55 PM. |
#115 (permalink) |
Member # 127650
If you make a 1356-bronco D20 kit it could have a decent market in the Early Bronco crowd. Lots of people are putting in zf 5spds or 4r70w's and paying $400 for an adapter to use the D20. The 1356 would take the place of the adapter and add an extra low range.
#116 (permalink) |
Member # 70258
The 1356 Doubler came in the mail last week or the week before. It was packaged well and the machine work looks top notch.
I am locating a 1356 right now. Once I have it I will post up an update with a few pics.
#118 (permalink) |
Member # 173066
I was running his 1350/1354 kit before my v8 swap and was happy with. I bought his new 1356/205 kit (the long one) and will have it finished up soon. Im just finishing the little details with my 5.0 swap and I will be able to test it out. Just like his last kit, good quality and simple. I had to cut the front off the longer of the two shift rails on the 205 and making some shift linkage takes a little work but its not rocket science...
#119 (permalink) |
Member # 110063
I have the short version of the 1356/205 from duffy. Good quality stuff. I got the aluminum case 1356 so i could weld in the patch plate after cutting the case in half. I did have to run the shift rails oit the back side of the 205, but it wasn't too bad and it saved me a couple of inches worth of rear driveshaft.
Sent from my SCH-I500 using Tapatalk 2
66 Bronco, 289, NP435, 1356/205 doubler, long arms, f-100 rears, stretched to 101", 42's, 60 front, shaved 14 bolt rear, full hydro...yada yada, bla bla bla. |
#120 (permalink) |
Member # 72598
Thanks guys, the shifter is one of the things I was wondering about with the long kit. I could run the rails out the back, but I didn't want to if I didn't have to. White Trash, you said you had to mod your shifter, are you using a twin stick on the 205?
#121 (permalink) |
Member # 173066
twin stick... I just cut about an inch off the front shift rail so it would clear the adapter plate for the 1356 and made linkage. The rear shift rail fits with no cutting. Now both shift rails are the same instead of the front rail being a little longer. I was going to do the rear shift swap but Im lazy so I ordered the 2" longer one and out came the cut off wheel.
#122 (permalink) | |
Member # 72598
