Member # 16680
dually sterlings are like sasquatch?
lots of people mention them, but its hard to find any hard data on width, My SRW sterling, out of a 90 f250 is like 65" wide. Id like to find a sterling dually since its supposed to be wider, but does anyone KNOW what the width is on a sterling dually?
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club |
Member # 71891
shoot i could have measured the 2 i found last weekend. i'll remember to put that on the list for my next junkyard run.
95 ford bronco, 351W - one tons, 38's, lockers, no discernible driving ability 93 F250, 7.3T, ZF5 |
Member # 10063
I don't think there is such an animal, is there? I thought the dually trucks got Dana axles (70s or 80s).
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] |
Member # 16680
thats all I found at the local yard. older than say mid 80 had what looked like 70s
Pickup duallys are relatively rare 85-97, 4x4 ones before about 96 weren't even factory built, they were aftermarket outfitted SRW trucks.
No Dana axles in 87-97 trucks other than F450/Superdutys with the 10 lug 80. Pickup dually 10.25's are out therem they just aren't common. C&C dually axles are pretty much SRW axles with different brakes, spring perches and shock mounts. Everything I have found points to the DRW axle being 5.75 or 6" wider than a SRE one.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... [URL="http://www.pirate4x4.com/forum/showthread.php?t=853402&highlight="]Build[/URL] Last edited by 82F100SWB; 02-12-2011 at 07:59 AM. |
Member # 37866
The only dually steerlings I've ever seen were in odd ball goverment trucks that had 5.4L engines in them, these are 1999 and up trucks.
RIP Ein the wheeling Corgi |
Cactus Farmer
Member # 168243
With chebbys, you can learn everything there is to know in about a week. With Fords, as much as you think you know about them, you learn something new and different every day it seems.
-Dave |
#11 (permalink) | |
Member # 68844
ΜΟΛΩΝ ΛΑΒΕ .308 Winchester: Turning cover into concealment since 1952. |
#12 (permalink) | |
Member # 3236
99-04 F-450's still used a D80 rear, 99-04 F-550's used a Dana S135 rear. 05+ F-450's use a Dana S110 with the 2011 F-450 PU's using a D80 again as well. 05+ F-550's use a Dana S110 with a higher weight capacity than the 450's and later (~08+) F-550's could also be had with a Dana S130 with the max tow and/or max payload package.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE] Last edited by jasonmt; 02-10-2011 at 08:55 PM. |
#13 (permalink) |
Member # 143867
the cab and chassis trucks used narrower dually axles i believe, however for standard dually pickups the left shaft is 41 1/8" and the right is 38 1/2". i haven't measured mine overall.
here's some good info, it doesn't say what is what but i had to figure out the shaft lengths when i snapped one http://www.sixstates.com/products/ca...=AXLELD&page=5
F-350 cclb dually, 6bta, rtoo9513, divorced twin stick np205, arb 10.25 rear with 2nd gen gears, KMA front bumper, warn m15000 hydraulic winch, connex 4800, wilson 5000 antenna, wilson cell phone amp, lowrance baja 540c gps, scanner, premier power welder, onboard shower, 235/85/r16 BFG MT's |
#14 (permalink) |
Member # 104586
Dually Sterling
I measured one on sunday, I was by my self but it was 72.5 plus or minus 1/2'. It was a 91 f-350 chasi cab 2wd 10.25 Sterling. My 90 f-350 4x4 rear is 3's total narrower than the front so I'm looking for wider.
#15 (permalink) |
I mentioned nothing about a F450/SuperDuty(there was no 550 at this point in time, thats 99+) of that era being 4x4, only that the 10 lug trucks had D80 rears, and were the only F-truck of that era to have a Dana rear.
A 1990 FSuperduty Crew SRW 4x4 with a W is a hard pill to swallow. Soley due to their GVWR they were all duallys. From the factory they were 2wd, reg cab, DRW cab and chassis, 460 and diesel only. I have Ford brochures and other refrence material to back that up. A F350 crew srw 4x4 with a W and ZF would have been custom order, and is very believeable though. Either it was badge engineering or something customized well after it left the factory.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... [URL="http://www.pirate4x4.com/forum/showthread.php?t=853402&highlight="]Build[/URL] |
#16 (permalink) |
I just textd my buddy but he didnt drive his in today. Its an 87 dually that he made 4x4. It had a 3.55 dually sterling in it, but he swapped it out for a 94 model 4L10 sterling. I will get pics and measurments next time I see him.
If you have a mullet and play video games, your not tellin me shit ![]() 68 F350 CC project 72 F350 CC for parts 79 F150 with tons on coils 88 F350 truggy 90 F350 beater truck 96 F250 CC DD |
#17 (permalink) |
MASTER TECH
Member # 54844
i have a 97 crew cab 4x4 drw. the rear axle is a 10.25 and is around 72". i have yet to get an exact number. but it is wider than my 95 f250 by a lot. i have measured a cab and chassie axle that was at the jy. it was the same as a non drw. 65 or 67
my truck from what i can tell is factory. it is a drw on the vin and had a bed at one time, flatbed now . from what i have read the dealer must have installed it. ill get pics if you fuckers want them
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy /forum/ford/544813-update-pics.html |
#18 (permalink) | |
Member # 83920
Actually, you made mention of a 10 lug d60, which was probably a mis-type, but it would lead one to believe you were discussing a front axle, because nobody would believe you were talking about a 10 lug D60 in the rear of an F450........
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. |
#19 (permalink) |
Whoops... Need more sleep I guess... LOL
#20 (permalink) |
Member # 87058
What exact measurements are needed. I have a 1991 C/C dually in the shop right now. I already have a bunch of measurements wrote down because I was looking at using this axle and/or hoping the axle shafts would fit into a 35-splinr rear 60 but I think they ended up being pretty far off. I don't have axles/hubs on so WMS to WMS will have to be a guesstament, but I could give you just about any other point of reference. I can confirm they have huge brakes, and mine came with new drums and shoes. I'll bet that was a chunk of change there.
#21 (permalink) |
Member # 87058
Found it! Apparently I did get wms before tearing apart.
1991 cab and chassis wms to wms = 68" spring perch c/c = 40-1/2" axle length = 37-3/8" (mounting face to end of spline) spline length = 2" Last edited by JGVABronco78; 02-12-2011 at 05:58 PM. |
#22 (permalink) |
MASTER TECH
Member # 54844
im sure mine is wider than 68 - off to find a tape.............
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy http://www.pirate4x4.com/forum/showthread.php?t=544813 |
#23 (permalink) | |
Member # 158981
can't remember when the sterling started 85 or 87 or when in the 80's but all three models i posted would have had the same thing i posted in the 90 model up to a '95-96ish i know. from there up don't know but would bet the samething. there are 2 Sterling rear ends as far as the width they are f250 -f350 srw and cab and chassis = the same narrow rear and dually that has bed with fenders. = the wide rear the wide rears are 4'' wider they have to be cause the inter tires would hit the bed. the part of the dually in this pic ya see has the wide rear end in it. and its a '93 f350
#24 (permalink) |
Member # 158981
and then theres a wide dana 70 because i have one. thats the same width as the wide sterling. thats going under a '79 ford truck to make a dually truck with a bed and fenders. with out spacers or custom wheels. hence the 4''s wider.
