Member # 107491
1990 460 heads what manifold to run for carb?
so my buddy has a 1990 460 with no intake and he is putting it in a 1954 ford f100 and wants to put a 4 barrel carb with an after market intake. he has a intake for a 460 but the ports dont line up on the intake runners. Dose any company make an aftermarket intake that works with the newer centerbolt valve cover heads?
Cactus Farmer
Member # 168243
No. 460 EFI heads use a completely separate intake manifold design and port location and nobody makes an carb manifold for one. He will need to swap over to the earlier carbureted heads, or adapt the EFI manifold to work with a carburetor. The EFI heads and intake are not bad for factory pieces, and if he is willing to take the time to adapt it to a carb and port a little it should be a strong runner.
The 90 model 460s had a -7 cc valve relief on the pistons, and the best thing would be to find some smogger D3VE (73-86) heads and bolt them on. That should give him about 9.4:1 compression and allow him to run on pump gas. The D3 heads are the cheapest and most widely available 460 head, and with a decent port on the exhaust side they will wake that engine up. Have your buddy visit www.reincarnation-automotive.com and pay the 25 bucks for membership, it has step by step instructions and pictures of how to port 460 heads without fucking them up. It also has good information on the fuel injection engines as well.
-Dave Last edited by Dr.Danger; 02-12-2011 at 01:15 AM. |
there is a company that makes adaptes for the efi heads to work with carbed intakes..
http://www.pricemotorsport.com/html/...ter_plate.html
My friend hates Chevy, but owns 2, wtf |
Fawkin Fordhead
Thay also make a carb flange to bolt on in place of the upper intake: http://www.pricemotorsport.com/html/body_cs-460efi.html
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
