1995 Crew Cab Fab... - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-01-2011, 03:54 PM   #101 (permalink)
LOGANSTANFORTH's Avatar
Member # 140580
Originally Posted by FORDTECHGURU View Post
DAMN, just caught up on this one, glad you found the fuel issue, thats why we convert them to electric pumps..
alot of work here, prolly missed it, but, why did you use the idi instead of a 95-97 stroke?
Ive had nothing but problems with the electric pumps I have had on the truck I'm working on...I plan on going back to the stock mechanical pump...
1996 DODGE 2500, 4X4, CUMMINS, 370'S, 5GSK, MACK PLUG, STUDS, SFI FLEX PLATE, DERALE DEEP PAN, EMS HUB KIT WITH 35 SPLINE INNER AND OUTTER MOSER AXLES, WARN GOLD LOCK-OUTS, 3 IN. LEVELING KIT, DUAL EDELBROCK REMOTE RESERVOIR SHOCKS, ROUGH COUNTRY STEERING STABILIZER, STEERING BOX BRACE.
LOGANSTANFORTH is offline   Reply With Quote
Old 05-01-2011, 07:27 PM   #102 (permalink)
Marines deleted mine
Pt_Ranger_V8's Avatar
Member # 84339
send me your e-pump, and I'll send you my mechanical pump
If you didn't mount the fuckin' pump on the frame rail, you'd be golden
The definition of irony:
Originally Posted by gee whizz View Post
your retarted.
Originally Posted by southernfriedcj8 View Post
I love the erection pics!
http://www.pirate4x4.com/forum/attac...1&d=1334801294
Yeah, Janelle R Becher is a cunt
Pt_Ranger_V8 is offline   Reply With Quote
Old 05-02-2011, 03:17 PM   #103 (permalink)
Member # 188637
Nice truck. I would have got a powerstroke donor for sure IDI is weak.
4x4powerstroke is offline   Reply With Quote
Old 05-02-2011, 03:51 PM   #104 (permalink)
Member # 84339
Show a powerstroke for $1400 (complete truck) and I would to
your retarted.
Old 05-15-2011, 06:08 PM   #105 (permalink)
Member # 84339
Minor update...
Got the wiring done for my trailer brake. Now I need a rear bumper, and a front bumper, and some tube to do my radius arms.
i've swapped axles over to some donor axles that are 3.55's. Since I'm driving with it mostly, and not towing, this will work better for me. At 60, I'm running about 1600 rpms
One question though, can I bend my radius arms inward to clear the tires? Basically, put a 'v' or notch in the main arm about 16" behind the axle. I figure that I would bring the top of the radius arm down to that point, and plate in between them.
My other thought was to bring the main arm straight back, then leave a section out where the tires would rub. Plating on the inside *should* take care of any strength issues, right?
your retarted.
Old 05-22-2011, 04:29 PM   #106 (permalink)
Member # 84339
Critique my idea.
I plan to build bent beam radius arms - I need every inch of turning radius I can get
Here is my idea, kinda mocked up with pieces of scrap I have floating aroudn in the garage. Yes, that's one of my 'little helpers' sporting her 'boy haircut' in the background
The plan looks like to put a ~15* angle in each end of my radius arm lower. I'll bring the upper section of the arm back to the bend, and I *in theory* will gain a couple more degrees my turning radius, as well as not lose any strength on the arms.
The radius arms are going to be 2" .250" wall square tubing, plated with 3/16" plate.
your retarted.
Old 05-23-2011, 07:40 PM   #107 (permalink)
Member # 84339
here's a sketchup of what I'm thinking.
Looks like the arm bends inward about 5" or so, and the top axle eye will actually sit a little higher that the frame mounting point.
critiques? Or should I just say fuckit and build it?
your retarted.
Old 05-23-2011, 07:52 PM   #108 (permalink)
5BrothersFabrication's Avatar
Member # 177573
Or just buy a set from Duff's. Unbreakable.
_____________________________________________
I don't roll on Shabbas, dude.
Ranger truggy, 4.0, np435/205, spooled D44/9", Duff arms & 4-link, Bilstein coilovers, full hydro steer, and 37" Iroks
My build: /forum/ford/991042-rockstar-ranger-build.html
5BrothersFabrication is offline   Reply With Quote
Old 05-23-2011, 08:17 PM   #109 (permalink)
Member # 84339
does Duff sell a set to mount coils to a D60 using Ballistic coil mounts?
your retarted.
Old 05-24-2011, 08:59 PM   #110 (permalink)
Member # 177573
Adaptability is key here. You can buy the arms, use the buckets (modified?) and track bar mounts. Duff's sells the wedges and multiple degrees of c-bushings. Hope that helped!
My build: http://www.pirate4x4.com/forum/showthread.php?t=991042
Old 05-24-2011, 09:45 PM   #111 (permalink)
Member # 84339
It saddens me that you haven't read the thread
your retarted.
Old 05-24-2011, 09:58 PM   #112 (permalink)
Member # 140580
I ended up forgetting about drawing fuel through the stock sending unit and pick-up in the tank. I drilled a hole in the bottom of stock tank where the sump is at and I put a bulkhead fitting in it with an elbow and a barb and ran all new Goodyear hose from Fleet Pride from the rear tank to the valve, got to put new rubber lines from the front tank to the valve now, if the front tank sucks air tomorrow I will do the same with it...
Old 05-25-2011, 09:38 AM   #113 (permalink)
Member # 84339
interesting.
I'm curious to see how well that works out for you. I would be scared of putting a hole in the bottom of my fuel tank for sure though
your retarted.
Old 05-25-2011, 11:37 AM   #114 (permalink)
Member # 84339
welding up my mounts from Ballistic today. They look .
Now I need some nickel rod to weld the tube to the pumpkin, and maybe to stick the brackets to the pumpkin. I *think* I won't have to though. I might end up trussing the axle anyway *shrug*
your retarted.
Old 05-25-2011, 06:07 PM   #115 (permalink)
Member # 84339
Hmmm...
After some more headscratchin, beer drinkin', and figurin' it's been decided...
I need a shop
Seriously, If there's anyone in Vegas that has some shop space I can rent for a few days, preferably with 220/110 available, I'd be appreciative. I *really* want to put this under the truck before I weld anything together solid, on the arms.
I can do the moutns to the axle, and I'm pretty sure I can get eevrything close without pre-positioning the axle, but it would make me happier to do it the right way.
your retarted.
Old 05-28-2011, 04:19 PM   #116 (permalink)
Member # 84339
got the axle brackets welded on.
You can see where I had to trim 1" out from the DS leaf mount. I've VERY impressed with the fit/finish of the Ballistic brackets.
Next up is rebuilding crap on this axle. New ball joints, new seals inside, new bearings outside, and new seals for the hubs. Probably new brakes too
your retarted.
Old 07-07-2011, 01:07 PM   #117 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Pics/vid of the IDI installed and running?
MT4Runner is offline   Reply With Quote
Old 12-20-2011, 12:13 PM   #118 (permalink)
Member # 84339
Bumping this back up. Finally, got my upper buckets tacked together. Planning on welding these to the frame where the show tower sits right now, then moving the shock tower directly behind them. The lower shock mount will be on the top of the radius arm.
Critique my build - do you think these mounts will need more triangulation?
your retarted.
Old 12-20-2011, 07:26 PM   #119 (permalink)
Member # 187456
If you have the room I'd run a gusset down the side(s) or tie them into the shock mount. You cant have anything that handles the load of you heavy ass deisel too strong.
BTW-I just read through the whole build and I will concure that fuel lines/pumps SUCK!
Had the same problem when I swapped the frame on my Tj. Would run then would stumble and die. My problem was wiring though....after trying for 13hrs to fix it
[QUOTE=bigford;10609690]On a side note:
I remember telling my second ex wife " My truck comes first, then my job, then you " I never liked that woman. [/QUOTE]
EricsGreen98Tj is offline   Reply With Quote
Old 12-20-2011, 07:59 PM   #120 (permalink)
Member # 84339
Well, the shock tower is going to be mounted directly behind it. I'll probably bolt the tower to the frame, then weld it all together. I'm debating about running a gusset down to the frame both front and rear, I just don't know how big to make it. That part might have to wait.
I got the radius arms coped tonight for the Ballistic joint (rear) and the 4 poly bushings (front). I'll try and get them all tacked together this week. I'm planning on swapping this axle the week after Christmas.
your retarted.
Old 12-20-2011, 10:26 PM   #121 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Is the bucket too narrow front to back? Will the springs rattle in the bucket either on a rough road or when the radius arms droop?
How about some 1.25" OD DOM for tube gussets going front and back?
Old 12-20-2011, 10:44 PM   #122 (permalink)
Member # 84339
If I had some, and a way to bend it....
Maybe we can get something bent up in the desert
your retarted.
Old 12-23-2011, 04:33 AM   #123 (permalink)
Member # 91447
Glad to see this project is still coming along. Cant wait to see the progress next week!
97 Ranger......gonna do something with it. still trying to figure out what though.
metalmacguyver is offline   Reply With Quote
Old 12-24-2011, 10:18 AM   #124 (permalink)
Member # 84339
Couple of pictures.
The 3" joint is from Ballistic, and is a pile of shit
I'm gonna run it for now, but I'm probably gonna replace it with something from RuffStuff in the future.
I'm EXTREMELY disappointed in the Ballistic joints though. Threads are all fucked up, and continually recutting threads when you spin the nut in and out
Anyway. It looks like they'll fit in with little no bends on my radius arms - I was thinking I would have to wrist them (still might) to clear my tires.
More pics to come.
your retarted.
Old 12-24-2011, 04:29 PM   #125 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
what coils are you gonna use?
i would kinda like to use a coil spring shock combo for my 3 link but i havent really found anything cheap thats up to the task of supporting the 7.3 powerstroke. idk how much lighter the idi is tho
jeep is getting a new home!
NEW PROJECT ON THE HORIZON!!!
E-350
12 valve cummins, 2006 F350 axles, 6" lift and 37's
FordX4-offroad is offline   Reply With Quote
