#76 (permalink) |
Member # 187917
Nice looking rig! have any plans for the 4.0? Theres a shop in canada that does strokers and performance parts for them I bought some stuff off of him for my 3.0 ranger. Tom I think his name is www.moranav6racing.com check i out! Good job with the truck man!
#82 (permalink) | |
finally rightside up
![]() I can't go much lower and still clear the D60 pumpkin against the oil pan. I already had to move the steering box up 2-3" to clear. |
#84 (permalink) | |
![]() the forest service green is mine. ![]() ![]() http://rides.webshots.com/album/581646961xhfnvx |
#85 (permalink) |
Member # 171332
I have no fucking idea what any of that shit meant, but ok. Lol
I was asking because I HIGHLY suggest investing in a doubler no, so you only have to make drive shafts once. Take it from someone who learned the hard way... |
#86 (permalink) | ||
![]() Thats how our trails are rated I should have a 4+ and it would be a 5+ if I had a winch. (and had a smidge more experience) Quote:
#87 (permalink) |
Member # 171332
Is your truck a stick? With an auto, you'll likely be fine. The doubler was the best mod I ever made to my truck. The Ex is auto, so the doubler required much better brakes. The ranger was manual and after 8 hrs of wheeling, the clutch would be slipping like crazy. After the doubler, it was all cake
#88 (permalink) |
Member # 171332
Ok, now it all makes sense. Just the way you said it had me all confused. Seams like every park I have been to, whether it's national OHV are maintained by the Forrest service, or private property, they all seem to have different ratings. I just never heard anyone rate their rig accordingly.
#89 (permalink) | |
party wagon
Member # 202878
![]() and i still dont have a doubler
jeep is getting a new home! NEW PROJECT ON THE HORIZON!!! E-350 12 valve cummins, 2006 F350 axles, 6" lift and 37's ... |
#91 (permalink) | ||
I am on my 3rd front shaft after this...yours is still crazy. I can't imagine mine after a bed bob and doubler though
#92 (permalink) |
Member # 171332
Auto is where it's at. For front shafts, since they are lock in hubs, just cut and reweld the front shaft. You won't ever be going fast enough to feel any unbalanced vibrations. Those brakes will hold the ranger no problem. When you get the doubler though, it may be tough holding 1st gear in low low going Down a steep grade. The builder of the Explorer went with Hydroboost once the doubler was installed.
That's kind of cool people up there rate everything by numbers. In So Cal, everything was shapes. Moab was colors. The rubicon was, well, word of mouth. I didn't start seeing numbers until this last trip to Black Mountain, where everything was rated similar to what you were saying. thanks for the comments. Mine is in pieces right now, with poweplant still undecided. Since I still have a lot of work to do on the truck that doesn't involve the poweplant, I'm knocking things out as I go. Are you planning on caging it? |
#94 (permalink) |
Member # 171332
Just be careful and you will likely be fine without a cage.
My explorer has been flopped on its sides multiple times (only once by me) and it still doesn't have a cage. Although that is the next investment. |
#95 (permalink) | |
Back trail ratings isn't moab on the 10 scale+colors? Last edited by cdawall; 04-12-2012 at 08:24 AM. |
#97 (permalink) | |
Member # 81680
I would highly suggest coming out and watching some real live 5 - 5+ action. There is a reason why all the 5+ rigs look like raisens! have Todd make you some rock sliders and a skid plate that goes from diff to diff before you go out, will save alot of pain and suffering down the road! Last edited by axleater1; 04-12-2012 at 12:28 PM. |
#98 (permalink) | |
As for beadlocks I should be fine for now the tires are all tubed so I don't have to worry as much about blowing beads. Last edited by cdawall; 04-12-2012 at 01:11 PM. |
#100 (permalink) |
Member # 46318
Do you have, or do you plan to beef up the front cover? Beadlocks, beadlocks, beadlocks. Like Axleater said, you should put some sliders on it, even before the 4 rated trails. Do this BEFORE you bash up the rockers. With it sitting that low and long, you will be kissing alot of stuff with your belly.
Project Ol' Skool '37 Chevy: /forum/ford/1049898-project-old-skool.html 1979 F-350 build: /forum/ford/855113-79-f-150-build.html |
