Measuring caster on a d60 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-01-2011, 08:06 PM   #1 (permalink)
Member # 9381
getting ready to swap a king pin 60 into my bronco, and wanting to get the caster somewhere close.. LOL
I am going to run stock radius arms, so i know that i can get degreed bushing to get it dialed in, but I just need a starting point.
My question is.................. Is measuring across the top of the upper king pin a good measurement? I read a few places where guys described using the upper king pin bolts as a reference point. How does this sound?
Coors is offline   Reply With Quote
Old 03-01-2011, 08:25 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
use the tin cap if possible.
you can also remove the grease zirk from the lower cap and tha twill give you a good flat surface as well.
Old 03-01-2011, 08:37 PM   #3 (permalink)
Member # 9381
I was just outside looking at it, and the bottom did look like a better idea.
So the flat surface of the cap IS a good representation of the caster then?
Just wanted to make sure the little ideas floating around in me head were somewhat factual!!!
Old 03-01-2011, 08:59 PM   #4 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
yes.
Old 03-01-2011, 10:02 PM   #5 (permalink)
Member # 87058
Measurements should be made at normal ride height with radius arms as they roll the axle quite a bit as they squat.
JGVABronco78 is offline   Reply With Quote
Old 03-01-2011, 10:12 PM   #6 (permalink)
Andy351's Avatar
Member # 22290
Send a message via AIM to Andy351
easiest way i've found is to use a swanson speed square and a level on the lower kingpin cap. takes under 30 seconds to measure either side.
www.PolyPerformance.com
WE GOT WHAT YOU NEED
When people in the Taliban are riding around in better trucks than you, you might have a problem.
Andy351 is offline   Reply With Quote
Old 03-02-2011, 07:31 AM   #7 (permalink)
Member # 9381
I do understand this, I am actually going to get my caster reading the way the bronco sits now for a comparison, since it does ride and handle good now.
not sure i quite follow u here, can u explain
been thinking this over and i think i got it now, u put the square on there and then put the level up against it and level it to see there it lines up on the square..... CORRECT?
