Specs
*1979 F250 frame/1990 Ranger ext cab
*393 Windsor, Coast High Performance rotating assembly, Ford Racing Performance heads, FRP roller rockers, Megasquirt injection with 460 injectors, Duraspark ignition, E2000 pump, OBA
*C6, 203/205 with Jeds adapter, ORD triple sticks
*1/2 ton rear springs up front
*XJ or TJ coils and four link rear - Actually went with ZJ fronts
*Full hydro with PSC 6.0 steering valve, Surplus Center double ended ram, PSC saginaw pump with custom ammo can reservoir
*39.5x16.5x16.5 Pitbull Rockers on 12 bolt H1s, recentered with pressed centers
*78/79 Dana 60 front with Reid knuckles welded, 14 bolt welded
All this running gear was in my Jeep; I was going to back half it and buggy it out but the frame was trashed. Had the 79 F250 sitting in the back yard so I decided to build a new rig.
My old wore out Jeep Wagonner
Frame was patched and fixed multiple times
Torque mount for doubler was tearing the frame
Cutin up and getting all the good parts out
Main motivation for a full cab, wife and kids need to be warm.
