PCM, ECU, Reflashing/Engine Wiring Harness customizing help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-20-2011, 01:34 PM   #1 (permalink)
Member # 108915
Talking PCM, ECU, Reflashing/Engine Wiring Harness customizing help
Ok,
So here is the deal I’m looking at putting a 5.4L 3v in my trail buggie. I’m trying to find some one that can get the 5.4L to run with out trannie or diff censers, so basicly ecu and engine only. i would like to get the wiring harness reworked and lengthened about 4ft to get it as high in my buggie in order to keep it out of the muck. Yes the 5.4 is a ford, and yes i know about the LS engines but i want to do it with The FORD 5.4L. Thanks for your help.
Des
desmvp is offline   Reply With Quote
Old 04-20-2011, 05:31 PM   #2 (permalink)
Member # 93013
Honestly, your best bet might be to just go with an aftermarket stand alone computer and harness. You get what you want and are not spending forever eleminating stuff you don't want.
Stretching a harness isn't exactly as simple as it sounds. 2 ways of doing it, a whole bunch of spliced wires inside the harness (not the best idea), or replace every wire going to the computer with a new one that is longer (a complete custom built harness with almost not orignial wires).
broncobowsher is offline   Reply With Quote
Old 04-20-2011, 06:59 PM   #3 (permalink)
mj
Member # 1919
sniper seems the best deal
I am needing one for a 5 speed swap into my P71 crownvic
http://www.snipertuningforums.com/index.php
mj is offline   Reply With Quote
Old 04-20-2011, 07:50 PM   #4 (permalink)
Member # 152532
http://www.google.com/search?hl=en&s...aqi=&aql=f&oq= is your answer to keeping the PCM out of danger.
f350n4.6ranger is offline   Reply With Quote
Old 04-20-2011, 08:57 PM   #5 (permalink)
Member # 17313
dude! why even bother! a 350 with a rv cam, and those panties will drop! i promise! maybe even get crazy with a 3/4 race cam... no need to do the ls swap like all the other sheep out there..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 04-21-2011, 04:34 AM   #6 (permalink)
redpitbull44's Avatar
Member # 68844
Going with this line of thinking.... Why not mount the engine higher up in the buggy too. I mean, mount it too the roof and use a bunch of drain snakes taped together in lieu of a driveshaft, and your rig will be UNSTOPPABLE!!!!
ΜΟΛΩΝ ΛΑΒΕ
.308 Winchester: Turning cover into concealment since 1952.
Originally Posted by Texas97 View Post
dont know why... unless its some new hippie tree hugger brady campaign sissy ass bedwetter gun control nanny state facist orwellian barbara streisand law that just passed....
redpitbull44 is offline   Reply With Quote
Old 04-21-2011, 10:09 AM   #7 (permalink)
Member # 108915
Unhappy
Originally Posted by broncobowsher View Post
Honestly, your best bet might be to just go with an aftermarket stand alone computer and harness. You get what you want and are not spending forever eliminating stuff you don't want.
OK that’s a great idea but what / who makes the stuff to go with my ford 5.4L for the standalone ECU and wiring harness? There was a guy at one of the 4X4 competitions that had an ls1 he got out of a rolled truck. he sent it off to a "tuner" and got the wiring thinned out and the ecu re-flashed to eliminate all the sensors he didn't need, and to get the anti-theft taken off. The ECU/PCM re-flash is really what I’m after. is there a place that can do all that for me?
Des
Old 04-21-2011, 12:23 PM   #8 (permalink)
master lurker
FORDTECHGURU's Avatar
Member # 104639
delta force tuning, goggle it
GOT 99-04 UNIT BEARING HI-STEER??
check out the super ranger
86' RANGER-39.5'S-4.0L-M50D-9"-DETROIT-5.14'S
90' RANGER-42'S-BLOWN 302-E4OD-60/10.5-5.38'S-12 BOLT H1'S
FORDTECHGURU is offline   Reply With Quote
Old 04-21-2011, 05:29 PM   #9 (permalink)
1sicbronconut's Avatar
Member # 37866
Des
I do understand that it's the enigne you want to use but if you haven't done a EFI swap before you might want to start with something that has a little more support out there. my $.02
RIP Ein the wheeling Corgi
1sicbronconut is offline   Reply With Quote
Old 04-22-2011, 06:40 PM   #10 (permalink)
winch operator
bobbywalter's Avatar
Member # 15473
Send a message via AIM to bobbywalter
2001? 2010?
whats it worth to you? where are you located?
didnt find anything on google?
if only
88 ranger ext cab pos hackjob powered by a 6.5 diesel clattering against a 4l80 thats punishing a f208 that is turning ford 60's rolling on 33-44 in tires depending on the mission at hand
how ya like me now??
bobbywalter is offline   Reply With Quote
Old 04-24-2011, 10:26 PM   #11 (permalink)
Member # 108915
ya i did find some flashing software thanks to this thread but I thought i saw a place that would do the ecu and wiring for "end users". i had seen it on the net when i Googled the project be for but now im having trouble finding it. IT was a good price too something like $300 or so ........... a good deal in my book.
Im in bozeman mt and ya nothing here will/ can do the ecu flash and wiring its BFE out here as fare as electronics go.
Ya i have done other swaps be for just this is my first EFI and need the ecu done that’s the only hang up for this project. but i can do the DIY thing now too, i just want to have the ease of "it went to the shop" but it may just be the next new thing i have to learn. Thanks for all your help guys.
