Newbie
Member # 138492
Ford Axle Help please!
Hey guys
Getting the front of the rig together with a Kingpin d60 from 78 camper special. Only problem is that the wheel hubs have vanished. Need a solution quick. Havent been able to find anything local... I can get rotors all day but no wheel hubs, what gives? No one reman'd these things?? Any help is GREATLY appreciated. PS Im not talking about the locking hubs. Im talking about the bearing housings, aka: the wheel hubs. Thanks Andrew
Andrew Rouser 1981 Jeep Cherokee Chief -SOA+3"springs 39.5 locked on 60s**Rock swap in progress** |
Fawkin Fordhead
Ford 60 internal hubs are easy to find. any 84-97 F250 extended cab with the TTB D50 has SRW hubs that will interchange.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
Member # 157211
Been down that road before. The only difference between the 78/79 hubs and the newer ford 60/50TTB hubs is the size of the wheel mounting studs. The 78/79 uses a 1/2" stud, and the newer stuff uses a 9/16" stud. Rockauto.com has new 78/79 style with the smaller hole, but they are pricey. I already had 9/16" studs on my rear sterling axle, so I just drilled my one good hub to match the one newer hub I found in the boneyard.
-Jared |
skullfuckery
Member # 29016
highonda / www.extremeaxlesales.com
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
