99 F250 No 4x4 Electrical problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-22-2011, 05:42 PM   #1 (permalink)
BdB5180's Avatar
Member # 109917
99 Super duty. When I turn the switch to engage the 4x4 no light no noise nothing happens. one wire has 4.5 volts on it at 2wd. 4 high has 2.2 volts on the same wire and 4 low has 1.1 volts on that wire. there is no other power at the switch. is this correct? Also is Fuse #15 the fuse for the 4x4 switch? There is no power on fuse 15 with the key on.
Junkyard Junkie
BdB5180 is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 07:40 AM   #2 (permalink)
BdB5180's Avatar
Member # 109917
help!
Junkyard Junkie
Old 05-24-2011, 11:03 AM   #3 (permalink)
Member # 46175
Are you able to scan it?
Where in "upstate"?
I have never had the switch be the problem on a Ford.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 05:22 PM   #4 (permalink)
BdB5180's Avatar
Member # 109917
the best I can do is have autozone read the codes. I'm near Elmira, NY. I don't think it's the switch. I think it's not getting power to the switch for some reason. I need a schematic or something to know which wires should have power on them and when.
Junkyard Junkie
Old 05-24-2011, 06:43 PM   #5 (permalink)
Member # 46175
You really do need to have it scanned with a good scanner. I am doubtful that Vatozone has the ability to read that module.
Alldatadiy.com is a great resource when you need documentation, and for 16.95 a year is well worth it.
I wouldn't waste any time until you scan it. When you turn the key to the run position, does the 4x4 light illuminate temporarily? This is referred to as "prove out" in diagnostic procedures. If it doesn't prove out, it is usually a sign that the module is missing a power or ground input.
The most common problems I see with the Superdutys in NY is corrosion at the high/low and low/high relays under the hood. They do the job of switching polarity to control the shift motor in each direction.
Too bad I am a few hours away, I fix this stuff all of the time.
