front hangers on front leaf setup hang too low - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2011, 11:50 PM   #1 (permalink)
1976 F100 project's Avatar
Member # 88251
Send a message via AIM to 1976 F100 project
so im doing the front suspension right now on my 76 frame. ive decided to use 52" IH pickup rear springs. ive already made the rear shackle hangers, which sucks because after doing some simple mock up, the front hangers are going to need to sit a good 13" under the bottom of the frame, for the spring eyes to be at the same height. i definitely do not want my front hangers to sit this low. the rear hanger shackle bolt is only 1 1/2" under the frame with the brackets i made. how do i make up for this since the front of the fords 70's frame rises up a good 6" from where the rear spring mounting is. anyone have any pictures of there custom front leaf spring setup? id like to just move my rear shackle mounting into the frame so the front hanger will not hang down so low. im running a d60 37" perch eye to perch eye. the leaves are not going to be completely outboarded of the frame and are also not completely inboarded directly centered to the frame, it is about 1" in the frame and 1 1/2" outside the frame. chevy guys have it easy, they just throw longer shackles n theyre done. give me some ideas. my goal is to have the frt spring hangers mounting holes within 7" of the bottom of the frame, because it gets janky when they hang down si much and im definitely not going that route
76 F100 390/435/203/205/60/10.25/52s/63s
03 silverado 1500HD 6" on 35s locked, winch, tube bumpers
1976 F100 project is offline   Reply With Quote
Old 06-08-2011, 12:57 AM   #2 (permalink)
Member # 88251
here are some mock up pics... just to show how low they would roughly hang in front if i was to run this setup.. notice the offset under the frame..
that is a 1" ruler between the top of the spring to the bottom of the frame
Old 06-08-2011, 07:25 AM   #3 (permalink)
Member # 152532
Cut down the shackles as much as you can, then make due with what you can get away with on the front hanger. Then use a degree shim or cut and turn the pumpkin
f350n4.6ranger is offline   Reply With Quote
Old 06-08-2011, 07:33 AM   #4 (permalink)
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Yup... shorten those rear shackles some and rotate the housing up to make it work. I'm guessing you'd like to have your front hangers maybe about 6" under the frame?
billybob_81067 is offline   Reply With Quote
Old 06-08-2011, 09:52 AM   #5 (permalink)
Member # 88251
what about how the stock toyotas/chevys are, with the shackle mounting inside the frame rails. anyone done something like that? pics?
Old 06-08-2011, 11:39 AM   #6 (permalink)
Member # 88251
if anyone has done a good setup with leaves and has some pics/advise that would help.. but in the mean time ive put a lot of thought into just 4-linking it..i have never done this, definitely capable, but i basically dont know where to start. can anyone guide me in the right direction on a 4-link susp?
Old 06-08-2011, 05:53 PM   #7 (permalink)
Member # 49744
front hanger. 57" stock ford rears
[FONT="Franklin Gothic Medium"][SIZE="2"][COLOR="SeaGreen"]after monday and tuesday even the calendar says WTF!!!!!!!!!
96 f350 powerstroke.[/COLOR][/SIZE][/FONT]
gfbgreaser289 is offline   Reply With Quote
Old 06-08-2011, 06:44 PM   #8 (permalink)
Member # 104943
My buddy did this to a 78 bronco with an 80s model d60 front. His shackle hanger is completely outside the frame. Are you sure you measure right? You should be outboard of the frame 2.5" on either side. Ill see if i can get him to take pics of his.
crazyredneckanyhow is offline   Reply With Quote
Old 06-08-2011, 06:49 PM   #9 (permalink)
Member # 104943
offset shackle idea
http://www.ford-trucks.com/forums/75...highboy-3.html
Old 06-08-2011, 11:40 PM   #10 (permalink)
Member # 88251
cant do that just look at the pics. perch center bolt to perch center bolt is exactly 37". its out of a 89 F250. i just decided to 4 link it..anyone done a 4 link front with a 435/203/205 combo. need to figure out where my center links are going to be, under the trans, im thinking. need to make sure the driver side link doesnt hit driveshaft during compression. any pics would help
Old 06-09-2011, 06:54 AM   #11 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
60 out of an 89 F250? That was swapped in.
Also, look at the angle on the perches on that axle, if you springs are sitting level you will have the pinion rolled up far too much, and you'll need to turn the knuckles to correct caster. In order to work with the stock perches on that axle, your springs must be higher at the front than the rear.
You can see what I mean here:
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is online now   Reply With Quote
Old 06-09-2011, 10:20 AM   #12 (permalink)
Member # 88251
ya i see what you mean. that doesnt even look like itd have barely any travel anyways. im just going to link it. still not sure if i want to 4 link or 3 link with panhard. what easier to do without link hitting driveshaft?
