#152 (permalink) | |
Horsepower Junkie
Member # 173427
Got the tank brackets today. I put them on a couple of tanks and set them up to just get an idea of how I am going to mount them. So far it looks like the best way will be just far enough away from the cab to get the latch open with the front one and then the second one will have the latches facing back so the tanks can be butted up as close to each other as possible. ![]() ![]()
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress The Making of a Turd: Huff's Green Turd |
#153 (permalink) |
Member # 46318
I would mount them vertical if I were you. Run a couple tubes horizontally and build some tabs to mount the brackets. You will have more "bed" space. You can never have enough tools and beer...
Project Ol' Skool '37 Chevy: /forum/ford/1049898-project-old-skool.html 1979 F-350 build: /forum/ford/855113-79-f-150-build.html |
#154 (permalink) |
Horsepower Junkie
Member # 173427
I will set them up and see what it looks like. I kinda had in mind having them down like that then over them having a small platform using an expanded metal floor for tools, spare parts or a cooler.
#155 (permalink) |
Member # 83837
Very nice - any chance you could post some more detailed pictures of what you did with the front kickers in the cab? We are bending up a cage in a very similar truck and I'm curious on how you did it. The truck will eventually get propane, so it will probably look similar in that regards as well
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers Bronco Build Thread |
#156 (permalink) |
Member # 177573
That shit looks
_____________________________________________ I don't roll on Shabbas, dude. Ranger truggy, 4.0, np435/205, spooled D44/9", Duff arms & 4-link, Bilstein coilovers, full hydro steer, and 37" Iroks My build: /forum/ford/991042-rockstar-ranger-build.html |
#157 (permalink) | |
Horsepower Junkie
Member # 173427
![]() ![]() The thing with the cage on this truck is that the frame is so narrow. Around 34 inches. That is the reason for punching through the frame for the 4-link. Honestly it was on the verge of just getting the frame cut off and backhalved in the rear. Anyways the entire cage is based on the arms for the sliders. It will be tied directly to the frame in the rear but in the cab it was too narrow to do so. Edit: I still have to put in the dash bar and the verticle risers to the halo. And once the exhaust and other odds and ends are done I will see how feasible it is to run some tube through the firewall to the front of the frame.
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress The Making of a Turd: Huff's Green Turd Last edited by huff75; 04-27-2012 at 09:01 AM. |
#158 (permalink) |
Horsepower Junkie
Member # 173427
Got to work on the mount for the tanks today. I'm using 1 3/4 square tube. Probably overkill but I had it and it was a good size for the foot of the tank brackets.
![]() I decided to stick with the side mounting setup. The frame is big enough to allow a future storage thingy later. ![]() Measured and got my spacing right. The setup is what killed the most time. ![]() Got the feet on and its done. Just didnt have time to weld it to the frame.
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress The Making of a Turd: Huff's Green Turd Last edited by huff75; 05-03-2012 at 02:03 PM. |
#159 (permalink) |
Horsepower Junkie
Member # 173427
Got it on the frame.
![]() ![]() ![]() Waiting for the paint to dry.
#160 (permalink) |
Horsepower Junkie
Member # 173427
Got started on the bedsides.
![]() Once it was off I gutted the inside. ![]() Got it hung. The rear axle was moved forward a foot so I had to section the bedside and move the wheel well forward. ![]() ![]() Got it cut and welded. ![]() ![]() ![]() Still have to work on the gap from cab then section behind the wheel. ![]()
#163 (permalink) | |
Swag Sales
Member # 90594
![]() Good luck feeding a big block. I would go through 3 tanks in 4 hours of light wheeling with a big block.
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! |
#164 (permalink) |
Member # 171332
First time seeing this build. (I know Where the fuck have i been right??) I just read through most of it, and drooled over all the pictures. What an awesome rig man. I mean, I love my 67-72 bowties, but other than those, this body style is the best looking truck out there. This is probably one of my new favorite builds. Great job so far. Looking forward to progress
#165 (permalink) |
Horsepower Junkie
Member # 173427
Thanks for the props guys! The sheetmetal work blows but I think makes the truck look a lot better. I will have quite a bit of work in them when they are done. Too bad they will get smashed.
#166 (permalink) |
Member # 46318
Looks good
Project Ol' Skool '37 Chevy: http://www.pirate4x4.com/forum/showthread.php?t=1049898 1979 F-350 build: http://www.pirate4x4.com/forum/showthread.php?t=855113 |
#167 (permalink) |
Horsepower Junkie
Member # 173427
Just had a little time today so all I really got done was to measure for my next section behind the wheel well. I was trying to lay out my cut lines but damn its hard to get a perfect straight line with all the curves of the body lines. I know where the cut needs to be but the front of the bedside is not straight so I cant measure off of it. And the same problem with the rear. The front splice wasnt bad because the bottom of the panel is even but the rear of the bedside the bottom angles up from front to rear. I guess I could measure from the previous splice seam and see how it ends up.
What I have been doing is marking the bottom of the panel. Then taking a plumb line from the top and trying to get a line that way but the panel has enough curve to it that it dosent work that well. I will keep at it but If anybody smarter has a better idea of how to reference the top and bottom of my line help me out. ![]() Edit: I guess I could reference off of the straight body line by the side marker light. Measure straight down in a couple of places to get a straight horizontal line then use a square.
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress The Making of a Turd: Huff's Green Turd Last edited by huff75; 05-12-2012 at 05:35 PM. |
#169 (permalink) |
Member # 177573
You don't need to reference off of anything. Just run a tape line down, then measure _ _" from the edge of the tape all the way down, in about 3" intervals, and then play connect the dots. You'll have it match up all the way down that way. But man that's looking nice!
_____________________________________________ I don't roll on Shabbas, dude. Ranger truggy, 4.0, np435/205, spooled D44/9", Duff arms & 4-link, Bilstein coilovers, full hydro steer, and 37" Iroks My build: http://www.pirate4x4.com/forum/showthread.php?t=991042 |
#170 (permalink) | |
Vanilla Face
Member # 93989
#171 (permalink) | ||
Horsepower Junkie
Member # 173427
#172 (permalink) |
Member # 86041
Don't wanna be a prick or anything, but it would have been less work if you cut the section out where the wheel arch was, and splice it to the length you want then cut a new wheel arch where you needed it. That way you only have 1 splice, and you put the wheel arch in fresh metal.
Thats what we did when we redid the bed a few years ago. My wheel arches were fubared anyways. ![]() Cool ride BTW. I'm digging the 4 link.
1994 F350 IDI Turbo Diesel, 43's, 4:88's, BW1356, ARB's F&R, Propane, 16.5 F Winch, 12K R Winch. |
#173 (permalink) |
Horsepower Junkie
Member # 173427
Nah, not being a prick. Just throwing out another idea. I guess that would work too. Just didnt think of it. I was just taking it one step at a time. I got the basic shape of the wheel opening I wanted just based off of the factory one and just moved it forward.
#174 (permalink) |
Member # 86041
I used the inside of the cutout flares as a mold to cut the wheel arch cause i was planning to make them out of fiberglass and bolting them on. The fiberglass flares really gave the bedsides some good Ñstrength. They get floppy when you cut the inner fenders out.
I've even leaned them on hill sides, and managed to crack them with out denting the sheetmetal. ![]() Without the flares i couldn't see out the mirrors after trail rides.
#175 (permalink) |
Horsepower Junkie
Member # 173427
Got the back sectioned. Now I'm just working on actual mounts for the side.
