'75 f250 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-12-2011, 08:18 PM   #1 (permalink)
02
Member # 193352
'75 f250
Im posting for a friend but will answer any questions as best as i can until i can get him on here...
Heres the problem:
He's got the 390 recently rebuilt, prison break kit... blah blah
The other day the truck started running really bad, we found it it was a bad lifter on the #5 cylinder, the end of the lifter had hole worn on it ( a little bigger than a pin hole) anyways replaced it today. Truck is still running rough, blowing smoke out the drivers side exhuast pretty bad. Cant figure out whats wrong...
Maybe that lobe on the cam is gone..?
Timing is off?
Thanks in advance for any help!!!
Here's a pic. Haven't seen any old 4 doors on here.
02 is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 08:55 PM   #2 (permalink)
Member # 38200
If it destroyed the lifter, the lobe is likely toast as well.
Was proper cam break in procedure followed?
What oil was used? Most new oil doesn't have enough zinc for flat lifters, especially at break in. Need to find a high zinc oil or additive for the cam break in.
If it ate a cam lobe it would be best to pull the engine and inspect the bearings and cylinder walls. The lobe breaking up will put bits of hard metal into the oil system.
Quick & Dirty is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 09:34 PM   #3 (permalink)
Member # 140580
Spend 30 minutes and yank the oil pan off and see how much trash is in the pan...
1996 DODGE 2500, 4X4, CUMMINS, 370'S, 5GSK, MACK PLUG, STUDS, SFI FLEX PLATE, DERALE DEEP PAN, EMS HUB KIT WITH 35 SPLINE INNER AND OUTTER MOSER AXLES, WARN GOLD LOCK-OUTS, 3 IN. LEVELING KIT, DUAL EDELBROCK REMOTE RESERVOIR SHOCKS, ROUGH COUNTRY STEERING STABILIZER, STEERING BOX BRACE.
LOGANSTANFORTH is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 10:40 PM   #4 (permalink)
02
Member # 193352
he has 2 drain plugs with magnets, they both had a fair amount of shavings but didnt seem like enough to equal the missing metal from the lifter and cam... I'll tell him to drop the pan to see if there is more! It was smoking the same amount before we replaced the lifter could the smoke he is getting now just be oil or water that didnt get burned before and it's still clearing that shit out?
