#29 (permalink) |
Member # 38773
torque mount on 205
how did you do the torque mount on the drivers side of the 205? Did you make new engine mounts? Put a 351w c6 np205 in my 70 and the tcase torque mount landed below the top of the frame and is almost tight against.
#31 (permalink) | |
Member # 36795
I will try to post a pic in a couple of days.
Derek: '69 bronco crawler/ 5.0 HO EFI/ 1 tons & 42''s |
#33 (permalink) | |
Member # 36795
frame side; back side;
#34 (permalink) |
Member # 36795
Decided after my trip to GOLD MT TN that the front 3link was not strong enough & decided to go with a 4link.
the only way I could get it to work was to move the front axle up another 9" & shorten the links. (118" wb) ![]() That meant new stronger frame mounts; ![]() ![]() Beefier axle mounts; ![]()
#35 (permalink) |
Member # 36795
Four links;
![]() Test flex; ![]() After test flexin it was apparent that the tube fenders needed to be moved up 2'' & the front bumper & grill needed some trimming. ![]() I was able to save the factory headlights. However the bezels will require some trimming.
#36 (permalink) |
Member # 36795
Turned out nice & it still needs a test ride, but I probably wont be able to go wheeling until the fall. Way too much to do on my sons '70 FJ40.
#38 (permalink) |
Member # 36795
Thanks,
still have to make a front drive shaft & extend my front ARB air line. Also ditched my RAMSEY 8000 industrial winch because the worm drive gearbox hung down too low & the steering ram could smack the bottom of it @ full compression. So I will probably get a RAMSEY 8500 & have to fab a new mount for it in the front.
Derek: '69 bronco crawler/ 5.0 HO EFI/ 1 tons & 42''s Last edited by bronco69drp; 07-17-2012 at 11:51 AM. |
#39 (permalink) |
Member # 177573
You've wheeled with Mark Rau and Semper Phil, right? I think I saw this rig in a couple of Mark's pics, loooooved it. Heard it was for sale not too long ago?
_____________________________________________ I don't roll on Shabbas, dude. Ranger truggy, 4.0, np435/205, spooled D44/9", Duff arms & 4-link, Bilstein coilovers, full hydro steer, and 37" Iroks My build: /forum/ford/991042-rockstar-ranger-build.html |
#42 (permalink) |
Member # 64440
Looks really good man!!
Keep it up and dont let the thread die out
ROCK LIGHTs http://www.horsepowerjuice.com/led-lights.html R.I.P Big Brother - (8-16-1987 - 8-12-2012) All Sales will go to the his memorial and to his son Tyler Aidan Willison |
#43 (permalink) |
Member # 127283
very nice bronco.
was there a reason for cutting the front of your hood like that?
70bronco,built 351w,c6,205,1tons,tbird EFI,4linked,44's PLEASE VOTE FOR ME #1 FOR TTC 2013! |
#44 (permalink) |
Member # 36795
Decided with the axle way forward of the oil pan I could get a little more oil capacity. So I modified the oil pan
![]() ![]() ![]() Installed. ![]() ![]() I'm at 7.5 qts & still not on the dipstick. Ran out of AMSOIL & need to order more before I find out just how much it will hold. I'm guessing 12-14 qts
#46 (permalink) | |
Parts shopping...
Member # 208624
BOMB'd - Better Off Modified, Baby! |
