Important access info please read!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Fordyce Creek
Old 06-20-2012, 10:48 AM   #1 (permalink)
Moderator
Tinman's Avatar
Member # 21358
The bridge at the top of the road to Fordyce Lake at Furnace Flat will be replaced by PG&E this summer. Please read the info below and make your plans accordingly.
"All,
I’m hearing PG&E’s schedule to replace the bridge is now 8/13 through mid-September.
FYI, the August 13th is immediately following the Sierra Trek Event.
The bridge will be out of service for approximately a one month period.
It’s recognized that there will be some impacts to the informal recreation that occurs beyond the bridge, but this is necessary work and delaying the project until after Labor Day is seen as unnecessarily risky, (weather related), and also creates resource conflicts with Hydro’s canal outage work that begins in late September.
Once confirmed, notification signs will be posted at several locations along Rattlesnake Road in early July.
Any other suggested methods of notifying the public will also be utilized.
A location exhibit and the title sheet to the 90% design drawings are attached here which include location and vicinity maps.
Please share this information within your group and reply with comments and suggestions.
Thanks,"
Bret Preble
President
Friends of Fordyce
Friends of Fordyce
KJ6NQN
BLUE RIBBON COALITION, CALIFORNIA 4WD ASSOCIATION, AMA LIFE MEMBER
Tinman is offline   Reply With Quote
Old 06-20-2012, 11:00 AM   #2 (permalink)
H Rated
Member # 36099
I blame the JK for this inconvenience
Friends of Fordyce
jethrodeg is offline   Reply With Quote
Old 06-20-2012, 12:04 PM   #3 (permalink)
WeBilt 4x4
JDunn's Avatar
Member # 33065
Nice to see them fixing the road. This just means they plan on having it open for a long time!
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
JDunn is offline   Reply With Quote
Old 06-20-2012, 12:23 PM   #4 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
I wonder how much of a dent in trail usage this will cause? I know I use the road almost every time I'm up there.
Opinions are like assholes.Everybody has one,and most stink!
DEER TICK is offline   Reply With Quote
Old 06-20-2012, 02:53 PM   #5 (permalink)
flamethrower
Bebe's Avatar
Member # 75270
Send a message via Yahoo to Bebe
So the bottom line is we will need to access the trail via Eagle Lakes Staging Area or Meadow Lake and there will be no "In" or "Out" on the committee Route for a few weeks?
What's all the Hub-bub about Blue Stars??? Click Here
Haulin the Groceries AND Haulin the MAIL
Bebe is offline   Reply With Quote
Old 06-20-2012, 02:54 PM   #6 (permalink)
flamethrower
Bebe's Avatar
Member # 75270
Can someone explain to me "informal recreation" so I don't get offended
Old 06-20-2012, 03:04 PM   #7 (permalink)
ssic off road shop's Avatar
Member # 105212
dam JK strikes already, There is a bit of a bump entering that bridge from the low side
ssic off road shop is offline   Reply With Quote
Old 06-20-2012, 03:48 PM   #8 (permalink)
pepe's Avatar
Member # 17870
Arguing with a inspector is like wrestling with a pig in the mud.
After a while you realize the PIG is enjoying himself!
pepe is offline   Reply With Quote
Old 06-20-2012, 07:28 PM   #9 (permalink)
Moderator
Tinman's Avatar
Member # 21358
I saw that too and wondered what they meant but wasn't going to worry about it. I figured the PIC (people in charge) thought of Trek as Organized and everything else as Informal.
Bret Preble
President
Friends of Fordyce
Friends of Fordyce
KJ6NQN
Old 06-27-2012, 11:46 AM   #10 (permalink)
Member # 95253
My Jk has no problem going over the bump.
chevyjepp is offline   Reply With Quote
Old 07-15-2012, 01:39 PM   #11 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
Was there on Friday 7/13/12 and didn't notice any signs...
Bryan 'Opie' Bennett
JV Rally Post #175 Tellico Rally post #531
Originally Posted by asp87 View Post
I think our friend GreatWhiteXJ is forgetting a zero in his pulled-from-rectume tolerance. That's the only way it could possibly make sense. If that's the case, a refresher of 4th grade math is in order.
XJ_ranger is offline   Reply With Quote
Old 07-25-2012, 10:07 AM   #12 (permalink)
SpineTx's Avatar
Member # 1499
anyone know if it will be open this weekend (7/28-7/29)?
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote
Old 07-25-2012, 10:35 AM   #13 (permalink)
Member # 2485
Send a message via Yahoo to RCKRATZ
Not scheduled to be worked on until after Sierra Trek. August 13
Keith Ratzburg aka "El Rolo"
Friends of Fordyce-Director
RCKRATZ is offline   Reply With Quote
Old 07-25-2012, 01:58 PM   #14 (permalink)
SpineTx's Avatar
Member # 1499
Thanks
Old 08-05-2012, 04:37 PM   #15 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
Just got back from up there,and I saw this.Different from the dates posted in this thread.Sorry,coudnt rotate for some reason .
Old 08-29-2012, 08:37 PM   #16 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Now you will not get "Taco neck"!!!!!
Remember:
Amateurs ... Built the ark.
Professionals ... Built the Titanic
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/
OOP'S is offline   Reply With Quote
Old 08-30-2012, 08:25 AM   #17 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Is it closed or is it not going to be closed until Sept. 4th?
Remember:
Old 08-30-2012, 09:12 AM   #18 (permalink)
WeBilt 4x4
JDunn's Avatar
Member # 33065
It will be colsed Sept. 4th - Sept. 29th. You will be good until Monday night.
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
Old 08-30-2012, 09:47 AM   #19 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Thank you!!!!
Remember:
Old 09-04-2012, 12:50 PM   #20 (permalink)
Member # 940
Good to know. I was putting plans together to go there the 22nd so it looks like it will be the 6th I guess.
I forgot about the re-route down by WH1 and why it was done. Just to get the trail away for the creek?
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 09-04-2012, 01:02 PM   #21 (permalink)
Member # 2485
It had turned into a ginormous mudhole.
Old 09-26-2012, 08:43 AM   #22 (permalink)
Grocery Getter
ErikB's Avatar
Member # 59
Any word on if it will be opened on schedule or not?
Committee cutout makes for a pretty easy day trip, which I might like to do this weekend.
ErikB is offline   Reply With Quote
Old 09-26-2012, 10:32 AM   #23 (permalink)
Trailbusters4x4 club
FuzzyZ's Avatar
Member # 117547
x2. planning on heading up in a couple weekends and was wondering the same thing.
83 toy pickup, 02 TJ, 02 GMC 2500HD
Trailbusters4x4 club Solano County
Dont blame me i voted Republican!
ECV 1004
FuzzyZ is offline   Reply With Quote
Old 09-26-2012, 09:50 PM   #24 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
I was going to call Cisco campground.Maybe PG&E is keeping them posted??Or maybe someone here has a contact that works for PG&E??
Old 09-26-2012, 10:09 PM   #25 (permalink)
Member # 53528
read the sign in the picture
rockyota83 is offline   Reply With Quote
