Campfire Info -Tahoe National Forest Fire Restrictions are in affect July 11, 2016 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Fordyce Creek
Old 06-11-2008, 05:18 PM   #1 (permalink)
Moderator
Tinman's Avatar
Member # 21358
Exclamation Campfire Info -Tahoe National Forest Fire Restrictions are in affect July 11, 2016
Fire Restrictions on the Tahoe National Forest Effective July 11, 2016
PLEASE PASS THIS ON TO YOUR FELLOW WHEELERS AND OUTDOOR USERS
http://www.fs.usda.gov/detail/tahoe/...d=FSEPRD508901
Tinman is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 03:24 PM   #2 (permalink)
Moderator
Tinman's Avatar
Member # 21358
Got this today:
"Although the fire season is progressing on the Tahoe NF in a fashion that we used
to call "normal", the typical indices that we use to restrict fires to "safe" areas,
have not been reached yet. The public, however, is used to us implementing
fire restrictions annually. In some years, the number of fire restrictions increases
have had significant impacts on the public mostly related to "internal combustion
engine use on NFS trails and roads"... (limiting OHV use).
In that last ten years, we have implemented fire restrictions any where from the end of May
to early July.
* In 5 of the 10 years, we increased the restrictions by the end of July.
* In one of those years, we increased the restrictions a third time.
* Only once in the last ten years...2003?...we did not have any fire restrictions.
Given the late snow/rains, the less than stellar heat and cool nights to-date, there is a
strong possibility we may not need to implement fire restrictions this year. The type of circumstances
which we would cause us to seriously consider implementing fire restrictions would be situations
such as an aggressive drying trends (for example, several days of strong E-NE winds), or have a
significant lightning/multiple large wildfires that depletes our initial attack capability.
So, the answer is the we may not go into fire restrictions this year, unless weather patterns change."
Hope for continued cool weather and no E-NE winds but still be careful with the fires!
Bret Preble
California 4 Wheel Drive Association
American Motorcyclist Association
Old 08-10-2010, 10:41 AM   #3 (permalink)
Member # 347
Thanks for all the good relationship maintenance work that is behind this communication, Bret -- Friends of Fordyce rawks!
Randii
randii is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 06:35 PM   #4 (permalink)
H Rated
jethrodeg's Avatar
Member # 36099
This is no time for campfires. It’s even more imperative that abandoned campfire should be 100% extinguished and not just 80%. This holds true thoughout out the year. It seems obvious but apparently not between Friday evening and Saturday 6am just above the water tank during Trek. Just saying….don’t be a dumbfawkstick.
Friends of Fordyce
jethrodeg is offline   Reply With Quote Quick reply to this message
Old 10-21-2012, 08:40 PM   #5 (permalink)
Member # 149343
Put Your Fires Out
Went for some easy wheeling today 21st to check out the lake and falls. While driving past camping spots on the way to the dam, saw 2 fire rings with smoldering logs, went on to below dam. On the way back 20min later, saw the logs in full flame with sparks blowing from incoming storm, and pine needles everywhere. Got out the shovel and did a complete bury of rings. Seems to me, if a person can light a fire they can also put it out. Plus I think it's still no campfires, as it's dry as hell out there.
Rocky Bar is offline   Reply With Quote Quick reply to this message
Old 10-21-2012, 08:55 PM   #6 (permalink)
FOF
pepe's Avatar
Member # 17870
I hate finding fires not put out. Hopefully after tomorrow it will be a non issue. Thanks for taking the time to do what others should have.
Arguing with a inspector is like wrestling with a pig in the mud.
After a while you realize the PIG is enjoying himself
Friends Of Fordyce
pepe is offline   Reply With Quote Quick reply to this message
Old 06-23-2015, 03:31 PM   #7 (permalink)
H Rated
jethrodeg's Avatar
Member # 36099
Fire restriction go into effect July 1st 2015. Please spread the word and don't be "that guy" that burns the place down.
Edit for more info:
Fire Restrictions
• No open fires, campfires or charcoal fires are allowed on Tahoe National Forest lands outside of designated areas, even with a valid California Campfire Permit, except within the oven at Wheeler Sheep Camp.
• Lanterns and portable stoves using gas, jellied petroleum or pressurized liquid fuel are allowed, unless otherwise restricted, with a valid California Campfire Permit available from Forest Service offices during business hours and at www.preventwildfireca.org/Campfire-Permit.
• No possessing or using any kind of firework or other pyrotechnic device, including explosives.
• No smoking, except within an enclosed vehicle, building, or designated recreation site.
• Internal combustion engines are restricted to National Forest System roads, trails, and areas, as identified on the Tahoe National Forest Motor Vehicle Use Map (including the Prosser Pits Developed Off-Highway Vehicle Area). Motorized cross-country travel between roads, trails, and areas is prohibited.
Friends of Fordyce
Old 06-23-2015, 09:10 PM   #8 (permalink)
Wilson's Avatar
Member # 7233
Is that for all of the Tahoe NF?
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger
Old 06-23-2015, 09:28 PM   #9 (permalink)
H Rated
jethrodeg's Avatar
Member # 36099
It is for all of TNF.
Friends of Fordyce
Old 07-21-2015, 02:21 PM   #10 (permalink)
H Rated
jethrodeg's Avatar
Member # 36099
Please pass the word along about campfire restrictions. If you see someone on the trail that has a campfire....it's bad.
TNF is on the trail and has been issuing citations for illegal campfires.
Friends of Fordyce
Old 09-27-2015, 07:45 PM   #11 (permalink)
H Rated
jethrodeg's Avatar
Member # 36099
Reminder...the illegal campfire tickets are $375 and can be issued to EACH person there.
Friends of Fordyce
Old 10-05-2015, 04:38 PM   #12 (permalink)
H Rated
jethrodeg's Avatar
Member # 36099
Please remember you still need a valid campfire permit and to drown out your fires when unattended.
Tahoe National Forest Lifting Fire Restrictions
NEVADA CITY, Calif. Forest Supervisor Tom Quinn announced that fire restrictions in the Tahoe National Forest will be lifted October 6, 2015.
Friends of Fordyce
Old 09-21-2016, 02:39 PM   #13 (permalink)
dirtyjed's Avatar
Member # 39436
Can you have a fire in the rings at Meadow?
section8krawlers.com
dirtyjed is offline   Reply With Quote Quick reply to this message
Old 09-21-2016, 04:16 PM   #14 (permalink)
FOF
pepe's Avatar
Member # 17870
In the designated camping spots at Meadow Lake with campfire rings, yes with a valid campfire permit.
Friends Of Fordyce
Old 09-21-2016, 04:40 PM   #15 (permalink)
Member # 232324
That is just in the PG&E campground correct? I know the fire pit next to the concrete slab is on private property and they DO NOT WANT FIRES.
jeepyjca is offline   Reply With Quote Quick reply to this message
Old 09-21-2016, 05:03 PM   #16 (permalink)
dirtyjed's Avatar
Member # 39436
Thanks.
And yes I mean the pge sites with the nice metal rings and shitters.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
