Minimum Tire Sizes - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Fordyce Creek
Old 08-17-2008, 12:20 PM   #1 (permalink)
Member # 85573
Minimum Tire Sizes
With the flows at 150 what sizes tires would be good with no doors on the rig?
harpo1 is offline   Reply With Quote
Old 08-17-2008, 01:28 PM   #2 (permalink)
Kevie Ray's Avatar
Member # 49165
I've got a buddy up there right now and he's on 36" tires and he had water in his.
I'm going next weekend on 35" tires and expect I'll take on a little myself.
"Stepping into the sound waves of Stevie Ray Vaughan's blues was like walking into the wash of a jet engine naked"
BRC MEMBER
CA4WDC MEMBER
FOTR MEMBER
Kevie Ray is offline   Reply With Quote
Old 08-17-2008, 03:53 PM   #3 (permalink)
WHITE RHINO's Avatar
Member # 71446
Send a message via AIM to WHITE RHINO
i think ill be ok with 44s hahah
(WHITE RHINO)88 Ranger, 2.9liter,1350/1354 doubler, HP 60 with Plated knuckles, chromos, PSC Hydro, 3 link, Rear Eaton 44" Pitbulls on H1's
Section8Krawlers.com
Extreme Dual Sport Tuff Lites Unbreakable Turn Signals for your Dual Sport/Adventure Bike
WHITE RHINO is offline   Reply With Quote
Old 08-17-2008, 04:34 PM   #4 (permalink)
Member # 85573
Does anyone have pics from this weekend of the river crossings?
Old 08-17-2008, 04:37 PM   #5 (permalink)
Member # 33585
Send a message via AIM to lilbuddy
Im uploading a bunch to photobucket. Ill post them in a little.
I have an 02 tacoma on 37s that sits pretty low to the ground and at comittee crossing i had a tiny bit of water go in my cab (had the doors off) but it wasnt enought to really matter.
1990 4runner, 3rz, tons, 40s, duals, and beats
FULLY GET IT!
lilbuddy is offline   Reply With Quote
Old 08-17-2008, 04:50 PM   #6 (permalink)
Member # 33585
Committee Crossing
Black Runner and white runner both on 37s. White runner is at least 2 inches lower then Black RUnner
This one is on 40s.
FULLY GET IT!
Old 08-17-2008, 10:08 PM   #7 (permalink)
ddestruel's Avatar
Member # 20999
what size rig? are you planning on coming out at comitee?
stay to the left at the first crossing and if you know what oyur doing 31's on a stock or 2" lifted flat fender can make it. i know ive done it at 200-250 cfm over the first weekend of july or last couple of june several years going i preffer my cj 7 though.
I ran 33's on my cj7 with a 3" lift and no BL last year mid june and if i remember right the releases were in the 200 range. but someone will need to correct me if im wrong anyways we came out comittee with no front wheel drive, it was top of my fenders, nothing too major, little ductape and avoiding the holes and we were through. that stream can swallow you at 50 cfm if you pick the worng path and ive seen it were guys in 39.5's were getting winched out at 100 cfm or less and little flatfender made its way across at 200 cfm +. watch your line if you dont know what you are doing run that creek at 100 cfm or less. i wouldnt hesitate to take my cj7 4" up 35's through tat creek at 200-250 cfm at 300-400 i start looking at comitee very carefully. everything else is doable but thats jsut me. i like my small tires but they hold me back sometimes
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET
But i Vote
GO UM Montana Griz
"Jeep Lurker"
KEEP REMEMBERING 9/11
Jeep with Rambler motor, SUA, front 608.9 and some bolt on stuff.
I miss my old 4bt powered chief
Support Frank the Tank
ddestruel is online now   Reply With Quote
Old 08-17-2008, 10:20 PM   #8 (permalink)
Member # 85573
35" tires, 4" lift and 11/4" body lift. I've ran it before but had electrical issues. Jeep Wrangler TJ.
Old 08-18-2008, 08:40 PM   #9 (permalink)
OakieOffroad85's Avatar
Member # 49334
37 swampers 7 inches of lift roughly. Water just barely touched my sliders. Went through yesterday.
[FONT="Century Gothic"][/FONT]89 Yota Pickup Straight Axle, 3RZ, Chromo longs, 5.29's, Arb's, Dual cases.
OakieOffroad85 is offline   Reply With Quote
Old 08-21-2008, 05:13 PM   #10 (permalink)
Member # 63183
220 CFM; 31" tires on a spring over Samy did just fine. With doors.
The advice in post #7 above seems very reasonable.
Only caveat; for Spring flows you have to take into account the added flow from all the natural creeks adding to the official dam release. So in the spring take those projected flows you find on Dreamflows and KNOW the level will be higher at the first creek crossing. This time of year no concern.
Spring is my preferred time of year to run the trail and see all the waterfalls from the canyon walls.
Sno White is offline   Reply With Quote
Old 08-25-2008, 08:50 PM   #11 (permalink)
Registurd Abuser
'71 800B's Avatar
Member # 34995
Dude! 10" on a tricycle will cross with no problems. Now 33" at 500cfm is fun as hell if you dont mind gettin wet.
'71 800b, 305 Vortec, 4L60e/241d/241c 60, 14, 37's
'71 800B is offline   Reply With Quote
