FJ80-based 4-seater truggy build at Pacific Fabrication - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-29-2011, 10:05 PM   #101 (permalink)
Member # 30721
Then took some measurements and cut some plates to box-in those sections.
Daniel just joined the pacfab crew recently, and he does most of the welding now. So I asked him to weld-up all the joints that would be hidden by the plate work.
gatosbros.com cruxstudio.com trailslesstraveled.com
JESSE_at_TLT is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 10:09 PM   #102 (permalink)
Member # 30721
Posted in that thread I started about tolerances in chassis-building about how I make fairly accurate marks to take measurements from with sharpies. Since even the fine-tip sharpies make marks about an 1/8" wide, it's difficult to make marks to take accurate measurements from. So I got in the habit of measuring from one side of a mark or the other, and I indicate which one with an arrow. I use bits of angle-iron to make marks lengthwise, and wrap paper around the tube to get a sharp line around a tube. Might be better off using something like the silver pencils that some of the other guys recommend, I just never knew any better, and everything else I tried rubbed-off too easily.
Old 09-29-2011, 10:15 PM   #103 (permalink)
Member # 30721
Figured I might as well reinforce the upper coilover mount and the outer portion of the fender/shockmount crossmember while I was at it. Tack-welded the front and back plates into place, and then hand-bent the side plates - pre-bending and then tack-welding and making adjustments as I went. Cutting the tubes on the other side was a lot easier because I was able to use the sheetmetal as templates.
Old 09-29-2011, 10:21 PM   #104 (permalink)
Member # 30721
The 1/2" Bilstein shock-eyes only allow about 20-degrees of articulation, and that was all we could allow before I cut into those tubes, so I made the shock mounts parallel to the axle. So after I fixed that I had to cut off the lower coilover mounts and turn the shock mounts 90-degrees. Made some nice boxed lower mounts.
Old 09-29-2011, 10:24 PM   #105 (permalink)
Member # 30721
The pacfab guys are all up at the Rubicon right now, so the owner decided to take the rig over to his shop, where he's going to do some wiring and sort-out some of the smaller details over the weekend.
Old 09-29-2011, 10:52 PM   #106 (permalink)
Member # 107137
Sweet build!
OldGold3VZE is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 09:07 AM   #107 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
Send a message via AIM to foley
After you make your mark with a sharpie, go back with a sharp scribe or a scrap of tungsten and scratch your "actual" measuring mark into the sharpie mark. I do that frequently as it's a lot cleaner than getting Dykem overspray all over a chassis while getting marks laid out.
I swear hell is full of cedar, scorpions and flat hot non-alcoholic beer.
foley is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 11:24 AM   #108 (permalink)
Member # 83301
Woo i think it would have been easier to just cut tubes out and redo them.....I wouldnt want to know what that cost, given what shop rates are.....
'79 chevy k30 vortec 350/sm465/205/205/5.13's with big tars and toob
Old 09-30-2011, 11:30 AM   #109 (permalink)
Member # 118665
LOL. I wasn't gonna say it.... but yeah.
Eric Hagan - Greenbo, ALABAMA
Stop the banjos a minute, I think I hear paddlers.
LandSpeeder is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 11:58 AM   #110 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
Look way cleaner too. Use a rolled tube instead.
I swear sometimes this place should be called "Autism on bath salts".
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 09-30-2011, 04:46 PM   #111 (permalink)
Member # 30721
Did that work on my own time over the last weekend. Obviously would have been faster/easier to use bent/rolled tubes, but I chose to do it this way because I thought it was better/cleaner, and wanted to do the best job I could of fixing a mistake that I had made.
Old 09-30-2011, 04:55 PM   #112 (permalink)
Member # 30721
Took a couple more pics today while we were checking clearances, and a few more of some other little details that we've been working on.
Old 09-30-2011, 05:01 PM   #113 (permalink)
Member # 30721
Originally Posted by mrboyle View Post
Couple things you might want to address on the cruiser platform. First, with as tight of tolerance as you have on the engine cage it would be wise to chain or limit the motor mounts in some way as they are a common failure on LC's.
Look what I found. haha. Owner had told us the engine mounts were bad, so we replaced them before we mounted the radiator in order to make sure the fan shroud would line up properly. Was kinda surprised that they're not captured mounts. Took your advice and chained the motormounts. At least the pass-side. Haven't gotten around to the driver's-side yet...
Old 10-01-2011, 09:30 PM   #114 (permalink)
Member # 15257
Are you working at pacfab now ?
1984 CUCV K30
"it went bang" means "its fucked".
My Build Thread.
BurbanFreek is offline   Reply With Quote Quick reply to this message
Old 10-02-2011, 11:48 AM   #115 (permalink)
Member # 30721
No, just helped them out with a few projects since I've been back in town.
Old 10-02-2011, 04:17 PM   #116 (permalink)
Member # 15257
cool man they are a good shop.
1984 CUCV K30
My Build Thread.
Old 10-02-2011, 04:47 PM   #117 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
Those things are fun to change aren't they?
"Those who hammer their guns into plows will plow for those who do not..." - Thomas Jefferson.
mrboyle is offline   Reply With Quote Quick reply to this message
Old 10-02-2011, 07:11 PM   #118 (permalink)
Penetrode Offroad's Avatar
Member # 72479
Attention to detail is amazing, kudos!
A lie is just a really good story someone ruined with the truth...-Barney Stinson
Penetrode Offroad is offline   Reply With Quote Quick reply to this message
Old 10-02-2011, 07:36 PM   #119 (permalink)
Member # 118665
Are you saying they're hard?
I've pulled half a dozen drivers side 80's motor mounts (usually always broken). drilled/pounded out the studs and drilled out a line and just run a grade 10 bolt straight through the existing holes. Nary a problem.
Old 10-30-2011, 11:57 AM   #120 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
Updates?
:tank:
Old 10-30-2011, 01:36 PM   #121 (permalink)
Wilson's Avatar
Member # 7233
I do the same thing on mini trucks. Chains look tacky, IMO especially on a shop build.
Old 10-30-2011, 07:42 PM   #122 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
Originally Posted by Beat95YJ View Post
Updates?
Owner has it at his shop to finish up all the little things. Seeing that he has been out of town for the past 3 weeks I dont think he has gotten anything done.
Current build-2002 Chevy truck buggy, 06 front clip tube-coilovers,bypasses-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
2006 dodge 3500 dually tow rig
1967 chevy K10, d60 14bff detroit, 37 mtrs, lq4, sm465, np205
jays68yak is offline   Reply With Quote Quick reply to this message
Old 10-31-2011, 08:42 AM   #123 (permalink)
Member # 41764
Zero.
It is getting a bit of mileage though as the machinists roll it in and out of the shop just about every day
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 11-01-2011, 02:03 PM   #124 (permalink)
Member # 130014
i like how the majority of the tube work is straight, few bends but lots of tube gives it the "race" look, like a skinless ProTruck or something. i like it, but i'm different.
i should move farther west someday and really see some fabbed rigs.
:D
SKULLYOTA is offline   Reply With Quote Quick reply to this message
Old 11-05-2011, 12:26 PM   #125 (permalink)
Member # 108345
Well I am now doing this as I rolled my 98 4Runner last Saturday. I have all of the body cut off pretty much the same as you have, let me tell you it's a lot of fun. One place I am curious about is the rocker panel area and how you have attached the "slider" potion of the cage to the body and frame. If you have pictures they would be appreciated. Trying to find a good starting point and not totally sure how to attack the rocker. It's going to get linked in the front with a HP60 and maybe leafs in the rear with a 14B. Just trying to get a little advice.
matt.
too many toyotas and not enough time. 84 86 93 96 99
hellataco is offline   Reply With Quote Quick reply to this message
