Savvy/Currie/SFR KOH Stock Class Jeep Teaser - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2011, 07:47 AM   #101 (permalink)
Member # 4375
Originally Posted by lookin4fun_inca View Post
Well kinda... Technically they are Inner Fender Liners. And the rules have been overly posted that...
Rear inner and outer fenders must be complete and unmodified, with the following limitations and exceptions: outer fenders (wheelwell openings) may be trimmed for the single and exclusive purpose of allowing for tire clearance. Modifications to the outer fenders must preserve the look of the stock wheelwells, as originally manufactured, and must not be trimmed excessively (no more than a 2" gap between any part of the outer fender and the tire at full compression).
SO I would have to say that they are needed to be there and unmodified?
Otherwise, I think I have a few great ideas for my build, that do away with some inner fender items.
Ps.. They also call the front inner fenders, technically "inner fender liner". SO does that mean TTJ/LJ etc, dont need to run front inner fenders?
These are inner fender items right?
http://www.ebay.com/itm/Jeep-Wrangle...ts_Accessories
I would argue that the distinction is readily apparent and both examples are on the TJ itself. The inner fender on the front of a TJ is stamped sheet metal and is held on with weld versus a plastic dust shield in the rear held on with christmas tree clips.
If they fail anyone at tech for missing the mud shields on the front fenders which serve the same function as the rear liners, I'm going to gather up the stack of them I've removed over the years and go stand next to tech with some clips and make me some easy cash.
I am an official member of the "I saw Dave Cole get run over by a rock buggy" club.
mrblaine is offline   Reply With Quote
Old 11-11-2011, 08:12 AM   #102 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Every discussion I've been a part of, including the original meeting about this class always centered on the sheet metal inner fenders. I've never once heard mention of the plastic liner. In fact on most vehicles that plastic liner attaches to the fender lip, which the rules specifically say we can trim for tire clearance. That leaves a plastic mud flap floating in space. I know for a fact that the intent of the rule was to keep people from chopping big giant nasty holes all through the car and killing the appearance of being stock. It was also to limit the class and present a challenge that would ultimately keep the speeds down due to lack of suspension travel.
To answer your question, though this jeep didn't even have those fender liners when I got it, since they are quite flexible I'm pretty sure I could get them back in there over top of the shocks.
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 11-11-2011, 08:17 AM   #103 (permalink)
lookin4fun_inca's Avatar
Member # 16698
Originally Posted by miguelitojeep View Post
I find this to be a bit on the nit-picking side...
These plastic liners are not going to make or break a cars performance.
Sure it does. Majorly. Allows a much nicer shock angle with that long on a shock. Major advantage.
They wouldn't even allow us to remove the stock spring bucket and add in a reinforced one that is part of the inner fender.
Inner fender should be inner fender no matter what its made of or why its there?
lookin4fun_inca is offline   Reply With Quote
Old 11-11-2011, 08:22 AM   #104 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
You, unfortunately, are running a unibody car where the spring bucket IS part of the inner sheetmetal fender. That's one of the drawbacks of your choice of vehicle. IIRC you also chopped holes in your spring buckets and shoved your bumpstops through them, which is a pretty obvious rule break, sooooooo.
just sayin
Dallas Ashley
Old 11-11-2011, 08:31 AM   #105 (permalink)
Member # 16698
just sayin
Yes drawback.
And we did not penetrate the inner fender. We plated inside and outside and welded those plates to the stock inner fender. Then did a bumpstop tube on the bottom and a engine cage tie in on top. Both welded to those plates. That is not a single tube in and out.
Cause I guess u can't modify the susp how ever u want. Inner fenders trump longevity of the vehicle, safety, and all other allowed mods. Or so I was told by chris.
But he makes the call. I know were legal now. Just thought since the owner of this rig is a friend I would point out a poss miss since it likely was missing those when u got it, and maybe saving some headache in the long run.
Old 11-11-2011, 08:35 AM   #106 (permalink)
lazy bastard
ajcal225's Avatar
Member # 47629
I would think it is fine? The rules do specify 'sheetmetal'.
I havent seen the plastic fender liner for our Cherokee in years.. I'd be hard pressed to find it on 3 out of 5 stock jeeps in the junkyard, I think.
ajcal225 is offline   Reply With Quote
Old 11-11-2011, 08:38 AM   #107 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
I appreciate the heads up, and will be discussing the specifics with Chris to make sure, but in the mean time I went back to the rule book to take a look for myself. The rule you posted is 6.3.2.4, just above it is this rule which defines what the stock body is.
6.3.2.2 Stock body (body is considered to be the full cab,
including all interior and exterior sheetmetal, bed,
doors, hood, fenders, grill, etc.) required. Must be
limitations and exceptions: Holes may be cut in
any part of the body for the single and exclusive
purpose of allowing rollcage tubes and
transmission/transfer case linkage to pass-through
the body.......
I highlighted the key word. Anyways, like I said I'll double check with Chris and if it's a no-go I'll make sure the dust guards will fit. We could argue rule wording and translations til we're both old and feeble, and in the end both be wrong since we aren't the ones teching the vehicles.
/hijack
Dallas Ashley
Old 11-11-2011, 08:45 AM   #108 (permalink)
Member # 5326
Link to the rulebooks for this? I would like to read just to see what the deal is.
Mieser is offline   Reply With Quote
Old 11-11-2011, 08:59 AM   #109 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
http://ultra4racing.com/racers/rulebook/
Dallas Ashley
Old 11-11-2011, 09:54 AM   #110 (permalink)
Member # 5326
I think having to keep the stock plastic liners would be stoooopppiid but...
6.3.2.6 Rear inner and outer fenders must be complete
compression).
It doesn't specify 'sheetmetal' in this section and I would see if they would clarify.
Old 11-11-2011, 10:22 AM   #111 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Sheetmetal is the term used to define what a stock body is in the rule that precedes the one you quoted.
We're starting to beat a dead horse here though, until I hear from Chris we're going in circles.
Dallas Ashley
Old 11-11-2011, 02:18 PM   #112 (permalink)
Member # 4375
compression).
My question is how many inner fenders does one vehicle need? That big ass hump that goes over the rear tire that's made out of stamped sheetmetal is what, a picnic table? No, it's the inner fender.
The plastic piece is a dust shield and like I said, if they make folks run them, I've got a stack of them for sale.
Old 11-11-2011, 02:37 PM   #113 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
I'll let Chris post up, but I was told today we would not need them.
Dallas Ashley
Old 11-11-2011, 03:21 PM   #114 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
i find it amusing how people run to the rules anything anyone does anything outside the box. there are a lot of grey areas in the rules, which makes this class appealing.
if you can defend it, run it.
going back to the basics
Originally Posted by ZukIzzy View Post
Oh and Frequency is for radios
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote
Old 11-11-2011, 05:14 PM   #115 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
I find limited classes to be pretty interesting to build for, simply because of the grey areas. It forces you to think harder. Those who have experience with racing and rulebooks know how to read between the lines and see what is actually legal, but not specifically mentioned. Most who haven't raced much see things much more black and white. There is a difference between cheating and reading what isn't written. It just usually takes a bit of experience to recognize where the lines are.
Dallas Ashley
Old 11-11-2011, 05:26 PM   #116 (permalink)
Pirate is KING!
RedBullJeep's Avatar
Member # 12217
Luckily for this team, Dallas and the rest of his crew draw with:
Dustin Webster
Red Bull RockCrawling Team
RockHer 1 - SOLD
RedBullJeep is offline   Reply With Quote
Old 11-11-2011, 07:10 PM   #117 (permalink)
Savvy Off Road
Provelogear's Avatar
Member # 110540
Dustin,
Thanks for hooking us up with Mastercraft! Now can you go over there and pickup our seats!
Thanks,
Gerald
THE ULTIMATE LIGHTWEIGHT JEEP PROTECTION AS PROVEN AT THE KING OF THE HAMMERS. TWICE! BACK TO BACK OVERALL EMC WINNER.
Click here for: SAVVY OFF ROAD
Provelogear is offline   Reply With Quote
Old 11-11-2011, 09:47 PM   #118 (permalink)
Pirate is KING!
Member # 12217
Originally Posted by Provelogear View Post
Dustin,
Thanks,
Gerald
Will get them and take em up so I can see the progress!
Dustin Webster
RockHer 1 - SOLD
Old 11-11-2011, 10:12 PM   #119 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Did someone say progress?
Dallas Ashley
Old 11-12-2011, 08:10 PM   #120 (permalink)
International Dan
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
Well crap, you officially passed me in build progress. I better get on the ball!
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html
facebook.com/hardenedways
Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you.
binderbound is offline   Reply With Quote
Old 11-13-2011, 10:23 AM   #121 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
More from yesterday. Decided it needed a few triangles. So far the cage attaches to the frame in 14 places. I hope we dont need to test them.
Dallas Ashley
Old 11-13-2011, 07:42 PM   #122 (permalink)
Member # 16333
Send a message via AIM to RedNeckRea Send a message via MSN to RedNeckRea
As Dallas has said, the plastic pieces wont be considered the inner fender. if anyone would like more clarity please feel free to email me.
~Chris, retired US Navy Sailor
RedNeckRea is offline   Reply With Quote
Old 11-14-2011, 08:56 AM   #123 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
I hate mounting seats. That is all.
Dallas Ashley
Old 11-14-2011, 09:02 AM   #124 (permalink)
jwag's Avatar
Member # 7638
Send a message via AIM to jwag
x2
www.westcoastfabworks.com
jwag is offline   Reply With Quote
Old 11-14-2011, 09:05 AM   #125 (permalink)
hurleygo3's Avatar
Member # 80862
I think I spent more time on the seat mounts than I did on the rest of the cage.
Looking fast.
www.facebook.com/EckoMotorsports
www.partsmike.com
www.savvyoffroad.com
www.trail-gear.com
hurleygo3 is offline   Reply With Quote
