Savvy/Currie/SFR KOH Stock Class Jeep Teaser - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-14-2011, 09:22 AM   #126 (permalink)
Member # 118721
What tranny are you guys running? 42RLE?
titleguy is offline   Reply With Quote
Old 11-14-2011, 09:38 AM   #127 (permalink)
Member # 4375
It's either that or the POS six speed manual and that ain't gonna work, so, it's the 42RLE.
I am an official member of the "I saw Dave Cole get run over by a rock buggy" club.
mrblaine is offline   Reply With Quote
Old 11-14-2011, 09:49 AM   #128 (permalink)
jsawduste's Avatar
Member # 77571
No AW4 ?
jsawduste is offline   Reply With Quote
Old 11-14-2011, 09:51 AM   #129 (permalink)
Member # 165988
Originally Posted by jsawduste View Post
No AW4 ?
That didn't come in TJs.
hustler905 is offline   Reply With Quote
Old 11-14-2011, 09:59 AM   #130 (permalink)
hurleygo3's Avatar
Member # 80862
Couldn't you run the 3 speed or ax-15, NV3500. Or does the trans have to be an option for that year?
www.facebook.com/EckoMotorsports
www.partsmike.com
www.savvyoffroad.com
hurleygo3 is offline   Reply With Quote
Old 11-14-2011, 10:10 AM   #131 (permalink)
jsawduste's Avatar
Member # 77571
OK, not up to speed with the rule book.
But the AW4 should have came in TJ`s
Old 11-14-2011, 10:17 AM   #132 (permalink)
Savvy Off Road
Provelogear's Avatar
Member # 110540
Only option for an auto is 42RLE.
THE ULTIMATE LIGHTWEIGHT JEEP PROTECTION AS PROVEN AT THE KING OF THE HAMMERS. TWICE! BACK TO BACK OVERALL EMC WINNER.
Click here for: SAVVY OFF ROAD
Provelogear is offline   Reply With Quote
Old 11-14-2011, 10:23 AM   #133 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Rule book says any trans that came in that year/make/model so we only have one auto choice.
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 11-14-2011, 10:26 AM   #134 (permalink)
Member # 4375
Should have as in they should have offered it, or should have as in I think they did but I'm not sure?
It was never an option likely due to it's slightly longer length which would make the rear driveshaft very short in the stock configuration.
But, yes, I agree that it should have been adapted into the TJ from Day 1 and they should have made a shorter tailshaft adapter to shorten it up enough to work.
Old 11-14-2011, 10:31 AM   #135 (permalink)
jsawduste's Avatar
Member # 77571
As in it should have been a factory OEM offering instead of an 42. Even if it was limited to the LJ.
In fact I recall one SOB who made that swap with his wife's TJ.
Old 11-14-2011, 10:33 AM   #136 (permalink)
Member # 118721
Wow, that's not much of a choice. Any build plans for the 42RLE? I think I saw an Atlas behind it, correct?
Any reason you all aren't running the Savvy Under Armor?
Old 11-14-2011, 10:39 AM   #137 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
I think I spent more time on the seat mounts than I did on the rest of the cage.
Looking fast.
Looking back at your thread I actually like yours better than what I just built, but since our cages are a bit different your design wont work for me
Right now I'm working on mounting my seat. Johns will be on a slider which may or may not be easier to mount. Adding to the challenge is our choice of belts. We're using Hooker Harnesses with the ratcheting adjusters, which IMO is hands down the best thing you can have holding your ass in. The difficult part is that you have to mount the ratchet end of the lap belt where you can get at it, and operate the ratchet. I've used these belts in both Dustins TJ, and Roger Lovells buggy, and though they worked in both, it was a bit awkward to get to the ratchet while driving. My goal is to make these ones a bit more accessible.
Dallas Ashley
Old 11-14-2011, 10:41 AM   #138 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
It's not in there right now, but we will be running a slightly modified version.
Dallas Ashley
Old 11-14-2011, 11:17 AM   #139 (permalink)
Savvy Off Road
Member # 110540
The 42rle has been completely gone thru but there is not much after market support for it. Any plastic parts have been repalced. It is a electronically controlled OD so we are using the OEM computer to control it.
The torque converter is were we spent money to make it last. All of the plastic has been removed and the fins brazed so they don't detonate at speed. Then balanced and tested.
Atlas 3.0 behind the tranny.
Old 11-14-2011, 12:16 PM   #140 (permalink)
jsawduste's Avatar
Member # 77571
Gerald, coming from the OEM transmission industry. The TQ convertor work was money well spent. All to often folks "beef" the transmission internals and then cheap out on properly preparing a convertor for abuse.
By chance did you get to raise the stall speed any ?
Incoming call to Blaine on the TCM.
Old 11-14-2011, 02:27 PM   #141 (permalink)
Member # 118721
Gerald, the lack of aftermarket support is surprising. I've got the same tranny in my LJ, and when AA came out with the Rubicrawler, I thought that would prompt other companies to come out with some additional pieces, but there hasn't been much. I think there is a guy on JF who has had excellent success with some different valve bodies. I haven't paid much attention as I plan to put an LS motor and GM tranny in my LJ when the driveline grenades.
Old 11-14-2011, 02:58 PM   #142 (permalink)
Savvy Off Road
Member # 110540
LS motor in the LJ is what is in my future as well!
Old 11-14-2011, 07:02 PM   #143 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Oh how I love the feeling of red hot metal goobers raining down on me as I weld the inside of a cage, especially when I'm in an awkward position and cant move enough to shake out the one that lands on the inside of my thigh and sticks.
Dallas Ashley
Old 11-14-2011, 07:17 PM   #144 (permalink)
Scooterloo's Avatar
Member # 26149
Better than down the ear, that'll send you into convulsions!
Scooterloo is offline   Reply With Quote
Old 11-14-2011, 07:30 PM   #145 (permalink)
Bones's Avatar
Member # 3007
Pull up your black socks farther
Jeep is looking fantastic as usual
Today is the tomorrow you worried about yesterday
Bones is online now   Reply With Quote
Old 11-14-2011, 07:40 PM   #146 (permalink)
jsawduste's Avatar
Member # 77571
Maybe have Amber rub it out for you ?
Old 11-14-2011, 10:37 PM   #147 (permalink)
russellmn's Avatar
Member # 98189
Ear plugs are wonderful... just sayin.
Dallas, lookin badass!
Originally Posted by Proeliator View Post
One Roxy to rule them all, One Roxy to find them,
One Roxy to mod them all and in the PBB bind them. [/COLOR]
russellmn is offline   Reply With Quote
Old 11-15-2011, 09:54 AM   #148 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Hey now, just because I live in So-Cal doesn't mean I'm a damn flatbiller
Amber will tell you, I'm weird about socks. I have lots of them, but they are all white Unfortunately none of them are molten metal retardant
Dallas Ashley
Old 11-15-2011, 10:07 AM   #149 (permalink)
Low Range Drifter
JohnnyJ's Avatar
Member # 7903
Less pictures of your socks, more of the seat mounts. (or Amber)
I like the cage with the b-pillar pushed back some for head & seat clearance, but it also pushes the rear seat bar back and up for extra headache with the rear seat tabs. I've been watchin this thread to see how you end up pulling it off.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig
Thanks to Drivetrain Specialists and PAC Racing Springs for your support
JohnnyJ is offline   Reply With Quote
Old 11-15-2011, 10:25 AM   #150 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Yeah we decided to push the b-pillar back quite a bit for a few reasons, seat clearance being the biggest one. If you keep the b-pillar in the stock location you end up having to bend the shoulder bar around the back of the seats, or weld it to the horizontals going back to the C-pillar. It also makes putting the diagonal cross bracing in really difficult. You also end up with the B-pillar right next to your head if you move the seat back any, which is not so great in a hard roll. By moving ours back we are able to keep everything nice and straight and strong, with lots of room for occupants.
Here's how the passenger seat mount came out. At first I really didn't like how it was working out, but I just kinda went with it, and now that it's finished I actually like it. I also got a lot of the passenger door bars done.
Dallas Ashley
