Hornblower
Member # 8524
Spring loaded side mirrors
Thinking about making some spring loaded side mirrors. Sounds simple, but to do it elegantly, the spring should be an internal torsion type spring.
Looking for ideas. Anybody have any examples of spring loaded mirrors they have made or bought? I saw one on RDC a while back, but can't seem to find the car it was on now. It would be like the example here only with some kind of spring and henge mechanism where it attaches to the chassis. |
Member # 80664
maybe copy a set of dirt bike foot pegs with the spring/pin action. Plus, you could find them for cheap used. $.02
"Even if you get to the line first are you really "winning" if you do it in a Toyota?"-raceanything |
Member # 80862
You could use a spring loaded cam action. You wouldn't see the spring.
www.facebook.com/EckoMotorsports www.partsmike.com www.savvyoffroad.com www.trail-gear.com |
Member # 81232
Not sure what it's called, but could you make a hinge like "bar doors" use.
Run a spring down the inside and have the bottom run up some ramps as it swings back and forth. The spring would be hidden. Just have to keep it tight. |
I like the spring idea but will it ever return to where your line of sight needs it? I know some guys have a small handle on them so they can return them to the proper location and adjust them as needed. With our east coast racing, trees tend to knock them back very often.
RCrocs/Line Mt. - Route 63 Motorsports #736 Ultra4 #4343 Co-driver - Molten Motorsports |
International Dan
You wont need mirrors...
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html facebook.com/hardenedways Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you. |
#11 (permalink) | |
Hornblower
Member # 8524
Reaching through window nets, it might be hard to bring the mirror back into alignment. Especially racing. This is why I wasn't crazy about the hose clamped on version we can buy. Another problem with the spring loaded mirror is that like a fingernail, it only works one way. Backing up is going to be bad for the mirror bracket's health. The spring loaded door hinge might work. Maybe a way to soften the stop would help keep the mirror from going out of adjustment. I really like the cam idea like what's on the Volvo. |
#12 (permalink) |
Member # 73963
mount it solid for the codawg and be done
IFS build http://www.pirate4x4.com/forum/showt...ht=starfighter turbod the Lexus http://forum.ih8mud.com/80-series-te...rbo-build.html Tons and 42's on the Lexus http://forum.ih8mud.com/hardcore-cor...j80-build.html |
#13 (permalink) |
Fistful of Boomstick
radius into a radius (think saddle joint) on the arms with a good spring in the middle will always return to about the same spot and will bend both ways
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#14 (permalink) |
figured a simple better way but i have nothing here to draw it with so bare with me
![]() Find steel "ball" or dome the same size as the ID of the mirror arms, drill a hole big enough to run a wire cable though it. Weld the ball/dome in one half of the mirror arm. Run and secure the wire to the spring and each end to each half of the arm respecively. So INSIDE the arm it would go: Securing pin attached to wire, wire goes through the hole in the ball, ball is welded to one half of arm, wire then connects to spring that is secured in other half of arm. What this does is allows the arm to be pushed front or back, the cable allows it to bend much more than a spring being in that "joint", the flat surface of the tube when pulled back in place will always be in the same location. If confused i can draw it later
#15 (permalink) |
Member # 8540
Having a spring loaded mirror will make it much more susceptible to vibrations, reducing it's effectiveness. Take that into consideration with your spring selection. A stiffer spring will allow it to move under a high load, but will keep it isolated under engine and terrain vibrations.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB Nothing is stronger than stupid... |
#16 (permalink) |
You have now taken 'overthinking' to a whole new level JR
![]() If you have found a way to hit a tree with your mirror in that car...something else has gone terribly wrong. Hose clamp them on (with chromoly hose clamps of course)... or... drive faster. If you drive faster than everyone else, you don't need mirrors.
Ultra4 and King of the Hammers |
#18 (permalink) |
Hornblower
Member # 8524
My first attempt with mild steel.
I like the single tooth cam because it can be folded out of the way it needed. It also folds backward. It seems if the car is that tight against rocks, there is always a little backward movement. The spring is .081" and is too light. Maybe .120" or thicker springs. Learned a lot on this practice run about ramp degree. It would be nice to have it done in a computer program then laser cut instead of doing it by hand. |
#19 (permalink) |
Is the "valley" wide enough that it actually returns to position after being jacked say 90 degrees from standard position or does it just sit where it is?
In vino veritas 70 turbocharged 351w fastback mustang 73 linked 5.8efi Bronco 99 QCLB 4x4 twin'd cummins on meth. |
#20 (permalink) |
Member # 65066
Magnets with a hinged at an angle that allows gravity to drop the mirror and relock magnets.
A mini a arm with a swinging magnet that contacts a rigid tab. The swinging magnets will allow bidirectional hits and relocks.
Amsoil GotPropane HydraForce Hydraulics Master Pull Mickey Thompson Optima PSC Rigid Industries SPAL |
#21 (permalink) | ||
Hornblower
Member # 8524
![]() Quote:
I ordered a couple different kinds of springs today. Below is the mongo stiff one. We'll see after it's all done whether it goes into the round file or not. |
#22 (permalink) |
Member # 6569
Jr you rock, I'll take the second pair for christmas
Team FOH# 321 Thanks to the people making it happen Weathertight,Polyperformance,CTM Racing Products,Levrett Transmission,BFGoodrich Tires,Kickass Offroad,Reid Racing,West Coast Differentials,Wide Open Design |
#23 (permalink) |
I still think mine will work better and be less complicated
![]() But I am trying to goad you into making it so if it works I can copy it because then I know it works
#24 (permalink) |
Member # 22748
i like that idea, but with a u-shaped saddle and reciever for a positive return.
R.I.P. DOZER ![]() R.I.P. Jason ![]() GREAT SPIRITS HAVE ALWAYS ENCOUNTERED VIOLENT OPPOSITION FROM MEDIOCRE MINDS -ALBERT EINSTEIN- #472tellico rally xtrm-s10 is a bad hauler dont let him haul your stuff ![]() Buy my mega cab KJ6IYH |
