Krush Buggy - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-21-2012, 08:32 PM   #1 (permalink)
Member # 55444
Krush Buggy
Been working on a design for a long time, building a pair of them side by side.
Both identical chassis, so figured I'd make one build thread.
The one on the left is going to be mine,
22re, w56, Duals,
Toy front double triangulated 4 link, longs, air shocks, etc. Full hydro
IFS toy rear, double triangulated 4 link, air shocks,
38s, weld on beadlocks,
The one on the right is going to a good friend of mine
Turbocharged 305 on propane, sm465, Black box, np205
Dodge 60 front, double triangulated 4 link, grizzly locker, RCVs ORIs, double ended full hydro, 4.56s
14ff rear, ddetroit, 4.56s double triangulated 4 link, ORIs
39.5 Rockers with weld on beadlocks
Chassis looks like this bare........
Modeled everything in 3d first and we're kind of working backwards at the moment.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 01-21-2012, 08:34 PM   #2 (permalink)
Member # 55444
Started with the sub frames. Identical front and rear, and between the buggies.
Trussed the front toy for mine
Cycled it some
Ride height-ish
Welded it out and added some tie-down points for on the trailer.
Old 01-21-2012, 08:39 PM   #3 (permalink)
Member # 55444
60 gets a similar treatment.
Lower link is a bit of a bitch, but got something figured.
Room for 50* of steering, we'll limit it to 45*
And got it all welded out too, and the same tie-downs
Old 01-21-2012, 08:41 PM   #4 (permalink)
Member # 134589
looks like a good start, really cool with the yota axles.
If you can't fix it with a hammer, it must be an electrical problem.
toyossan is offline   Reply With Quote Quick reply to this message
Old 01-21-2012, 08:45 PM   #5 (permalink)
87JeepWrangler's Avatar
Member # 13959
Send a message via AIM to 87JeepWrangler
i like the general direction you went with the lower link mount on the pumpkin side of the 60. cool.
rob
87JeepWrangler is offline   Reply With Quote Quick reply to this message
Old 01-21-2012, 09:33 PM   #6 (permalink)
ffdustyw's Avatar
Member # 25517
Send a message via Yahoo to ffdustyw
Damn good! I'll be watching this one.
[COLOR="Yellow"][SIZE="4"][FONT="Times New Roman"]97 Dodge 1500 Dueces, OEM spool/ARB, 54" Baja Claws, 16" Coilovers, Atlas II 3.8:1, PSC Full Hydro, Hughes Engines 408c.i. F.A.S.T/46re with 48re internals[/FONT][/SIZE][/COLOR]
[COLOR="Olive"][SIZE="4"]Kodiak Dodge Build:[/SIZE][/COLOR][COLOR="YellowGreen"][SIZE="3"]http://pirate4x4.com/forum/showthread.php?t=702415
[/SIZE][/COLOR]
[COLOR="Red"][SIZE="4"]Dodge,Duck, Dip, Dive, & Dodge[/SIZE][/COLOR]
ffdustyw is offline   Reply With Quote Quick reply to this message
Old 01-21-2012, 09:45 PM   #7 (permalink)
Member # 94400
Very cool! I like the sub frames.
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 241/205 42's
03 CTD toe rig
Texas Trail Buggy
what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster
slobuild57 is offline   Reply With Quote Quick reply to this message
Old 01-21-2012, 09:55 PM   #8 (permalink)
Banned
Member # 198834
Looks great so far
97discosd is offline   Reply With Quote Quick reply to this message
Old 01-22-2012, 05:41 AM   #9 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
On the yota buggy are you planing on the engine to be over top of the front 4 link or drop down behind the front axle? I only ask because on my current build my crank pulley is 2" back from the centerline of the axle housing and with duals, the shifters are way back. Your drawing looks to be a shorter design chassis than mine whats the specs for wheelbase you are shooting for?
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 01-22-2012, 07:14 AM   #10 (permalink)
Member # 99513
Wow Spidr, you got alot of projects going on!!
Awsome looking work like always. Can't wait on the TC'd Pane motor
Swapping Front ends:
Motorcycle stuff.
[SIZE="5"][COLOR="Red"][B]NEW BEGINNINGS:[/B][/COLOR][/SIZE]
jpfrk2001 is offline   Reply With Quote Quick reply to this message
Old 01-22-2012, 09:02 AM   #11 (permalink)
Member # 157622
What did you design these in?Good job
Dickson Offroad is offline   Reply With Quote Quick reply to this message
Old 01-22-2012, 09:07 AM   #12 (permalink)
Member # 55444
Motor behind the diff is the plan. I know that its going to put the shifters back, but when I weighed out the options that was the lowest of my concerns. These will both be 106" WB, but the way I designed it I could slide the rear crossmember back and get an extra 10", might do it on the v8 one.
The biggest thing is that I wanted to keep it slammed, and a good weight balance, I should be close to 50/50
Gotta stay busy right
I'm rather looking forward to testing the motor for sure. He's having a local guy build the motor thats done a few allready, they've got some balls.
Old 01-22-2012, 09:08 AM   #13 (permalink)
Member # 55444
Rhino 3d.
Old 01-22-2012, 12:03 PM   #14 (permalink)
Member # 56899
Diggin the subframe, nice work.
Laeirocz is offline   Reply With Quote Quick reply to this message
Old 01-22-2012, 01:42 PM   #15 (permalink)
Member # 55444
Thanks. Its the first time I've ever built everything in 3d before I started, never had so much planning go into a project. Seems to be paying off though.
Steering work starts tomorrow.
Old 01-22-2012, 01:58 PM   #16 (permalink)
Trail Tampon
rajincajingt's Avatar
Member # 27333
Looks great man
05 LJ stock
1976 C30 3+3 12V/47RH
instagram: LunchBoxFab
rajincajingt is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 04:34 PM   #17 (permalink)
Member # 55444
Good and protected.
Old 01-23-2012, 07:47 PM   #18 (permalink)
ffdustyw's Avatar
Member # 25517
I love that you are putting the steering behind the axle. Its the only way to go! How much clearance on uptravel will your ram have from your upper links.
[/SIZE][/COLOR]
Old 01-23-2012, 07:55 PM   #19 (permalink)
Crawlin'BC
CanadianZuk's Avatar
Member # 21813
Not to shabby there, Mr.Spidr
Team Crawlin'BC (Pro-Mod #250)
Team Brink Fab Motorsports #312 Co-Driver
Rich Walker
Find me on
CanadianZuk is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 08:21 PM   #20 (permalink)
dr_claw's Avatar
Member # 11222
Nice work!
Can't wait to see them finished....unlike my junk
Originally Posted by 5thgear
Or for $59 you could by 2 vibrators and hold them like handlebars
Teaching Metalwork in Van City
88.5 Suzuki Samurai, Daily driver with locked toy axles.
77 FJ45 cut up with a bunch of misc crap
dr_claw is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 08:32 PM   #21 (permalink)
Member # 55444
More travel room than his shocks will have. It was always the plan to do it this way, so we modeled it out from the get go. Wish we could do the same with the toyota, but I want to be able to put a high pinion third in there later, so it just wouldnt work
Well thanks Mr. Rich. I think we're allready planning a trip or two out your way once they're together
Old 01-23-2012, 08:34 PM   #22 (permalink)
Member # 78096
can you show a non skinned rendering that shows the subframe and the chassis connected together? Cool design on the subframe stuff.
Thx.
Jeep07 is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 08:57 PM   #23 (permalink)
Member # 55444
Like this?
And just cause I like this one.
Old 01-23-2012, 09:37 PM   #24 (permalink)
Crawlin'BC
Member # 21813
Just say when.......it's awn
Rich Walker
Find me on
Old 01-23-2012, 10:11 PM   #25 (permalink)
Member # 12429
Looks a bit planned out
It must feel nice to make your drawings come to life and start moving around like they did on the computer
Todd W is offline   Reply With Quote Quick reply to this message
