#26 (permalink) | |
BSW
Member # 42436
#27 (permalink) |
i would have let those tires sit out side all day in the sun and then had at it with some soapy water.
why the strange offset? i would think that on most axles that would be bad for scrub radius. just wondering?
74k20 with 6bt nv4500, 203/205, d60, 14bolt, lots of metal and booger welds... one of these days. |
#28 (permalink) |
Fistful of Boomstick
You are going to ask raceline what after using steel spoons and posting pics of your hackness ?
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#29 (permalink) |
Member # 132057
I doubt raceline will take the wheels back since they are custom. If they do, the OP will have to eat the one he tore up, definitely wont take that one back.
corey d |
#30 (permalink) | |
Member # 3007
Let us know what Raceline says about returning them
#31 (permalink) |
Member # 18248
It can be done. First, I would call Raceline and ask them to have all the tires and wheels picked up, taken to their place, have them mounted and shipped back to you, at their cost. I suspect they would be happy to do it rather than read about it here.
or, 2nd, you need to have the inside flange cut down to about .25" to .375". trust me, the beadlock function will still work and you'll be able to get the tire on. If you've ever seen an old Eaton beadlock, they only had about 1/8" of flange behind the bead. After cutting down the od of the inside flange, I always recomend mounting the tire from the front as it allows your to attack it at an angle to start. Lots of soap behind the inside flange so it wont fight you as much. Small tire irons only. Good Luck. Finally, wear the tires out and sell the wheels with them.
Larry TrailReady Products www.trailready.com www.trailreadymotorsports.com www.youtube.com/trailready TNC Machine, BFGoodrich Tires, KING Shocks, K&N Filters, MastercraftSafety, F&L Fuel, Weldon Pumps, Vision X Lighting, Discount Signs, Kincaid Racing Engines Last edited by trailready; 01-23-2012 at 06:40 AM. |
#32 (permalink) |
Pedal Junkie
Member # 8649
Lube the drop center with tire lube or dawn, the tires will make awful noise but will mount as i've mounted several sets of reverse drop wheels.
They have to be mounted properly, from the back, then dismount the bead to be used as a beadlock. Your main problem is alu is thicker than steel and you have 9" wide wheels. you may need to grind a notch in one part of the wheel that would allow the bead to sink further into the drop. The other problem youll learn, is that most reverse drop wheels lose inner beads. Ship them to my shop and i'll mount them, free of charge, you pay freight both ways.
-Steve 43" SX, h1's, ori's, ord magnum/np205, D60/D70, lq4, th400, bentfab chassis ....some assembly required. |
#33 (permalink) |
BIGELOW MOTORSPORTS
Its the same issue I have with my 17" monster double beadlocks and that large safety bead. Its damn near impossible to mount them. Harder than hell and it takes 2 or 3 people 2 hours a wheel to do it. It can be done. You will be wore out. I've cussed more mounting and taking apart those wheels than any thing else. Good luck but it can be done.
TEAM YUKON GEAR and AXLE #4413 Bulldog Winch, Raceline, Maxxis, FOA, Tom Woods, Everlast Welders, Ruffstuff Specialities, Cool Shirt, Stage 8, Baja Designs, PSC Steering, AJIK Overland Exchange, Reid Racing, Artec, Powertank, DynoMax, Hinchman Racewear, DJ Safety |
#34 (permalink) |
Karnage
Member # 55444
I didnt see it, maybe I just missed it.
Did Raceline tell you they would have to be a reverse center wheel when you ordered the,? And if they did, did you ask them what that meant?
Thanks to BAILEIGH INDUSTRIAL
![]() Krush RT IFS/IRS Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color] https://www.facebook.com/KrushRacing |
#35 (permalink) |
Member # 157622
I've never mounted a wheel like that BUT you need some real tire irons or someone is going to get their back hurt. That's the size we use on dirt bike tires.If you know someone that does semi work they should be able to help, they usually have a large set. I hate the wheels got hurt they look sweet!
#36 (permalink) | |
Member # 73963
Im not a wheel guru. i told them what i needed to accomplish and this is the solution i was given. I agreed to it. Im sure everything will work out fine.
IFS build http://www.pirate4x4.com/forum/showt...ht=starfighter turbod the Lexus http://forum.ih8mud.com/80-series-te...rbo-build.html Tons and 42's on the Lexus http://forum.ih8mud.com/hardcore-cor...j80-build.html |
#37 (permalink) |
Karnage
Member # 55444
I wasnt saying they wherent.
I like racelines too. One of the nicest wheels we've mounted in the shop. Was just curious.
#38 (permalink) | |
DD/Tow-rig: '06 GMC Sierra 2500HD Duramax Classic Rig: '88 FJ62, 100% stock In the weeds waiting for resurrection: '94 FZJ80, 33s, locked |
#39 (permalink) |
Pedal Junkie
Member # 8649
Your local big rig shop should be able to tell you who they order their tire bars through, get two of these baby bars
Take small "bites" and worry about dressing the wheel edge with a file when your done. http://www.31inc.com/node/11475 It WILL sound like shit as the beads stretch, just take your time and use a ton of tire lube or pure dawn, you want it slippery!!!
#40 (permalink) |
BIGELOW MOTORSPORTS
I've done it both ways. It just takes forever to do it.
#41 (permalink) | |
BIGELOW MOTORSPORTS
#43 (permalink) |
Member # 73963
ya for the ifs car. in retrospect it would have been wise to build the ifs assembly around common wheels instead of making the wheels around the IFS. i had the custom deep offset 18" wheels made so i could stuff the ifs assembly deeper into the wheel to net us more travel. a lot of time, money, and hassle for very little gain.
raceline is cool. they suggested to try this: 1. round off the beadlock edge with a flapper so the wheel slides on easier 2. lube it good 3 mount the wheel from the outside like i did the first time but dont use a tire iron at all. they said to have a couple guys hold a starting lip of the tire over the beadlock face and up against the weld. then use a real long 3/8 extension and a hammer and carefully use the extension to tap the tire lip over the rounded off beadlock lip. need to have a mounting BBq at my house. ill take pics and report back
#44 (permalink) | |
74k20 with 6bt nv4500, 203/205, d60, 14bolt, lots of metal and booger welds... one of these days. Last edited by g-wizz; 01-23-2012 at 02:59 PM. |
#45 (permalink) |
Member # 73963
#46 (permalink) |
Member # 66684
i just mounted some very similar 17's i was an idiot and fought one for about 2 hours over the outside of the rim before i realized how much easier it was to so from the other side first and then over the front. i spent $150 on three very nice 32" long tire irons and without them there in no way i could have done it. i also ground down the inside sharp lip of the bead of the tire so it would slide over a little smoother. good luck
#47 (permalink) |
Member # 13467
What are the diameters of the two flanges?
[QUOTE=Willyswanter's Dad;8398776]I'm trying to find spinner caps that will fit the wheels so when I'm stuck it will look as though I'm still wheeling[/QUOTE] |
#48 (permalink) |
Member # 73963
the outside of the beadlock ring is a tad over 18.5'
We ground off the edge and attacked it from the outside with some skinnier spoons and lots of lube. Made a special 5/8" dowel and tried to hammer the tire over the lip as suggested. This method seems useless. see the pics of the skinny spoons we used. these 18" wheels are not letting it over. sighh
#49 (permalink) |
Member # 73963
would make a cool set of fake beadlocks. they mount fine to the wheel if you dont want to use the lock ring. the part that i have gouged on this wheel cleaned up nice with a flapper and with the beadlock ring on it looks perfect. Ill bet you all want them?
Nobody else makes an 18" beadlock do they?
