#51 (permalink) | |
1) You requested the wheels be built this way 2) Raceline told you that they'd be a bitch to mount 3) You botched the install job 4) Started a bitch thread on Pirate including the obligatory, half truth, inflammatory title 5) Expect your money back when it all goes exactly like the vendor said it would You're building a cutting edge car, shit is going to go wrong. This industry is too small to be blasting the vendors that are willing to try something out of the box for a customer even though conventional wisdom says it's not the right solution. Sorry if I offend kinda
Ultra4 and King of the Hammers |
#53 (permalink) |
Loud Dumb Officer
Member # 25397
Get one of those big ass propane torches that kidjethro heated his TSLs up with before groovin them. I have seen them for starting big fires and stuff.
Heat that tire up so it is nice and soft and then give it a go. Dik
JV post #87 Tellico Post #385 |
#54 (permalink) | |
Member # 73963
No offense...kinda. This is still tech I just want a set of deepset 18" beadlocks that have tires on them so I can put them on my race car and get on with my build.
IFS build http://www.pirate4x4.com/forum/showt...ht=starfighter turbod the Lexus http://forum.ih8mud.com/80-series-te...rbo-build.html Tons and 42's on the Lexus http://forum.ih8mud.com/hardcore-cor...j80-build.html |
#55 (permalink) |
Newbie
Member # 152379
Size 9 foot & size 7 shoe
The bead of a tire is actually a steel cable that does not stretch. The only give is a very small amount of squish of the rubber around that cable. The cable is necessary to assure that the tire stays on the rim.
Since the tire bead (steel cable) can't stretch there has to be a way for the bead to go over the larger diameter rim. That's why the recessed area (usually toward the pretty side) is there; a smaller diameter that allows one side of the bead to drop in toward the wheel center while the opposite side slips out and over the larger diameter rim. In your case the recessed area is too far from the beadlock side so the tire will never shift enough to slip pver the rim edge. You might get it on but the tire and/or rim will be trashed.
1948 Willys w 289 Ford, 1997 TJ w 302 Ford, My first "car" was a 1947 Willys and that's when my addiction started., |
#56 (permalink) |
Member # 137977
Its a reverse mount wheel. You need to mount it the opposite way you've been trying to. That's the only way your going to get it. And you'll just have to pull the top bead over to get the beadlock on. And I can already tell you raceline will not take those back. There is a sticker on the wheel or box that says "test fit wheel first, wheels that have been mounted will not be returned. " your best bet will be to take it to a mom and pop tire store and see if they will mount it for you. Discount won't mount them and im almost positive none of the other big name tire stores will either. Good luck.
#57 (permalink) | ||
Fume Sniffer
Member # 122979
![]() Op: could be a stretch, but what about getting a tire mounted from the back as you had it, then use a combination of low heat (from a propane torch or like) to the bead, and a pile of ice (or dry ice) in the face of the wheel. Then try to pull the outer bead over. |
#58 (permalink) |
Member # 3007
I'd bet you need to take more off the diameter of the beadlock side and mount them from back to front over the bead lock lip. Sure looks like a total PITA and I don't envy you one bit.
#59 (permalink) | |
Member # 28177
Dave I think you are going soft
42" krawlers on 20s woulda worked and been cooler ![]() Quote:
Smiley Racing 609 1st Place KOH class Badlands UMC race Oct 2nd 10 11th and 8th place 1st and 2nd RCrocs 10 New buggy http://www.facebook.com/TeamSmileyRacing Thanks to: Crane Clayton Offroad BFGoodrich Bilstein Tom Woods Driveshafts Tom Guaraldo RIP! |
#60 (permalink) | |
Super Willie
Member # 19067
Larry from Trailready had some great input:
Tim Lund Yeah, I wear a Kilt... what you're not man enough?! Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market! Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363 |
#61 (permalink) |
Newbie
Member # 152379
Stretch
[QUOTE=rocklobster87;13910614]Perhaps it either of you had taken the time to read through the thread instead of just flipping to the last page and clicking reply you would know that you are bringing nothing new to the table.
Just pointing out that a bead (steel cable) does not stretch. Noticed from the pics that the wheel diameter inside the lip is larger than the shoulder that the bead rests against. No stretch + No room = No go.
#62 (permalink) | |
Metallurgy = truth
Member # 132449
100% I hate it when people custom order something and are told form the beginning, YOU ARE GOING TO HAVE A MFT TRYING TO MOUTH THEM!!!!!! Then your BBBEEEPPPP BBBEEEEPPPP comes on here and tries to make the Vendor look bad what a pud
swapping Paint is racing....... if you want the last word.......... try Apologizeing |
#63 (permalink) |
Rocks R Nice
Member # 206041
Shoulda just had Trailready do your wheels. I'd be shocked if they couldn't have provided a high quality AND 'user-friendly' set-up.
#64 (permalink) |
Member # 3511
Should have just bought double beadlocks. Don't understand shelling out huge $$$$ for the equivilant of a weld on ring.
Chuck P The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in! www.oldjeep.com |
#65 (permalink) | |
Member # 73963
Are you the guy I spoke with when I ordered these wheels? Are you the guy who took all the money? And are you the guy I have been talking to on multiple occasions? Then what are you talking about? Today Raceline told me they would turn the lip down. Thanks
#66 (permalink) | |
Member # 20394
BUCK Wild Racing Team 911 Thank you all for your support Widia Cutting Tools www.widia.com PSC www.pscmotorsports.com/ Ruffstuff Specialties www.ruffstuffspecialties.com Artec Industries www.artecindustries.com Tom Woods Drive Shafts www.4xshaft.com www.facebook.com/buckwildracing |
#67 (permalink) | |
Karnage
Member # 55444
Good to hear they're gonna help you out though.
Thanks to BAILEIGH INDUSTRIAL
![]() Krush RT IFS/IRS Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color] https://www.facebook.com/KrushRacing |
#68 (permalink) | |
Member # 73963
#71 (permalink) | |
Member # 12695
Dan
"We live in the Land of the Free because of the brave." Please remember our Troops! |
#72 (permalink) | |
US NAVY
Member # 46071
#73 (permalink) |
Member # 51984
I second that. Apparently you've never used tire irons on a dirt bike tire in the winter. Yeah I done it a few times. It sucks. I'd take the tires in the house and heat um up with the blow dryer. But that wasnt so fun so then I discovered if I did a funny car burnout till I thought it was gonna pop. The tire would come off like butter after it was crazy hot.
#75 (permalink) |
Metallurgy = truth
Member # 132449
No your not that lucky,
if you would have called me i would have told you to go pound sand when you called the first time. Then would have been on the floor laughing my butt off when you had the balls to call back crying that you could not mount them. And sorry im not greg m. He would not even waist his time with your lame ass
