#401 (permalink) | |
Member # 5969
When you draw a part, you just select the material you are making it out of to give it the correct density and that gives you the weight, which is mostly done for all the parts I designed and make. The hard part is all the components like engine, trans, T-case, axles. The engine and trans are probably 1000 separate parts, so you would have to go thru each part, and select the appropriate material, plus its missing the engine internals, crank, cam piston, rods etc. I drew the axles and they are very rough, what I do sometimes is weigh a real part, then by trial and error give the model a density that will give you the part weight that you want. Problem is the center of mass will be off slightly. |
#403 (permalink) | |||
Member # 8540
![]() I think this is the most common front clip I've seen on buggies. Quote:
![]() The WJ is my favorite.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB Nothing is stronger than stupid... |
#404 (permalink) |
Member # 5969
Getting the floor and firewall fitted. This is all .080 aluminum, all Laser cut and CNC formed. It bolts together and you weld some tabs to the chassis tubes. I added an extra piece for the Atlas Shifter, Im going to revise the trans tunnel to not taper it front to back so you wont have to do that, just simply cut a hole for the shifters.
There is a center piece between the seats that welds in, the seat belts can attach to that and your shifter,cutting brakes or what ever. |
#406 (permalink) |
Moderator
Member # 10249
The WJ hood will fit a 49in OD dash bar, the nose tube would be 42in from the dash bar.
Dave, 2013 KOH "Got, Some of it" #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
#407 (permalink) |
Super Willie
Member # 19067
The sheetmetal looks awesome Drew! This buggy in kit form is the coolest idea to come out in a long time.
Tim Lund Yeah, I wear a Kilt... what you're not man enough?! Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market! Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363 |
#408 (permalink) |
4x4 Consultant
Member # 227
Love the progress!
Method Motorsports Follow Me Here: /forum/competitions-events/1057582-md-ca-ina-jk-america-get-trip.html Email: kevin@methodmotorsports.net WWW.METHODMOTORSPORTS.NET |
#410 (permalink) |
Savvy Off Road
Member # 110540
Drew,
It really looks good. Is the orbital going to reside in outside or inside the firewall? The reason I ask is Tech likes the hoses outside of the firewall or shielded. Is there a way to adjust the seat as a couple of people will be driving and I'm short! Oil and trans cooler possible locations?
THE ULTIMATE LIGHTWEIGHT JEEP PROTECTION AS PROVEN AT THE KING OF THE HAMMERS. TWICE! BACK TO BACK OVERALL EMC WINNER. Click here for: SAVVY OFF ROAD |
#411 (permalink) | |
Member # 5969
The seats have multiple mounting positions, but at this point you would have to unbolt and move the seat. |
#412 (permalink) | |
fishingwithdynamite
Member # 30721
#413 (permalink) |
Member # 40846
Its very easy, changed my life when I figured this one out
![]() Just open the mass properties Tools>Mass Properties(or hoteky it!) Then at the top there are three check boxes, the third one down says "Assigned mass properties". Check that box, then you can enter your own weight value and define your COG by X,Y, & Z. This also works for assemblies as well as single parts. Hope this helps. |
#414 (permalink) | |
Member # 5969
#415 (permalink) | |
Member # 3775
I wheeled twice this year, that might be a personal record. |
#416 (permalink) |
Member # 138167
Looking really good Drew!
AKA - Dusty Booger Jeepspeed 1749 (1719 2008 Baja 1K) ![]() www.dirt-fab.com e-mail: info@dirt-fab.com Phone: 510-502-8508 |
#417 (permalink) |
Member # 149176
I don't know how I missed this thread.
You have some really nice designing and fabrication skills You have just a tad bit more detail in your design than mine or a lot more. I've always wanted to start a chassis shop. Still long ways away. Good luck Subscribed. ~Justin
RCrocs #123 Brown CJ-5 www.offroadcustomcreations.com Custom Creations Go Fast Buggy Build Sponsors: Corbeau, Tom Wood, PSC, Polyperformance, Inner Air Lock, Miller Welds, Heavymetal Concepts, Clayton Offroad, Baileigh Last edited by customcreationsllc; 08-10-2012 at 10:00 AM. |
#418 (permalink) |
In Thx for chance
Awesome product! Gives a garage hack like myself hope that I can one day have a cool, working buggy. If I ever built my own it'd look like a cobbled together pile of crap!
Quick question... Is there a completed one yet, WITH SKINS? Either 2 or 4 seater?
...Sometimes nothing can be a real cool hand... |
#419 (permalink) |
Member # 133593
^ I agree, I'm totally interested in picking one of these up.
Quick question though, on the 4 seater how well would a 5.0, AOD, Atlas combo fit? And is the fuel tank area large enough for a propane tank or two?
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf" 2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons 1948 Willys CJ2a: stock for now 2000 Audi S4 Stage II |
#421 (permalink) |
Member # 5969
Spent the day working on the power steering pump bracket. I needed to relocate the pump up to clear the upper links. This is what I've come up with so far. Alternator is in the stock location, mounts a CBR/1800 pump from PSC up and out a bit. Its all 1/4" Laser cut steel and spacers. By my rough measurements it also retains the stock belt. Might have to fine tune it by moving the idlers a bit.
#423 (permalink) | |
GoFastJunkie
Member # 183796
If your thinking about getting one of these let me know, i really like the look of them but don't have any idea how to import one.
96 ZJ, stripped, caged, locked F&R and long armed Ausie go fast jeep. |
#425 (permalink) |
Member # 133593
Any chance you'll be doing a 302 version of the engine mount cradle?
Also, I looked over the website to try and figure out dimensions but couldn't quit figure it out. Will a 40# forklift propane tank fit in the area where your fuel cell goes?
