Grandma's boy Hairdo part 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-15-2012, 02:55 PM   #1 (permalink)
Member # 18997
We started making some progress on it after talking about it for a while so here we go.rig will be built for trail wheeling along with a few comps here and across the border, plan's are to run a couple dirt riot sports and some track race's around here and WA,OR.Has a bit of everything thrown into it so here are some specs and of course some picture's.....enjoy..
-fully built bcc chassis
-built 3rz allot of goodies
-full spider 9s f/r, yukon component drop out's,300m engagment airlocker gears, 50* steering..
-300m inners/outers from spidertrax
-yukon super joints,drive slugs
-evolution EMF joints
- alum links
-hughe's built t350
-atlas 2spd
-hci motorsports full taco skins
-rear trailing arms going to build in house
-radflo coilovers,and bypass shocks
-custom fuel cell
-39's with some kmc wheels that we like
-dual battery's,gps,all the goodies
-prp seats hippy seat's..list go's on will post specs tomorrow belly,roof height,w.b,approx weight goal..here are a couple pics...
54" wide chassis, will have a big botty on her, big cell and spare room..the start of it..
kinda built around the fiberglass for tube map.
about 110" w.b will be very roomy...
mock up motor trans,t-case..
new trans showed up
start of the belly pan
frame horn's
If you build it they will come.
the-t-man is offline   Reply With Quote Quick reply to this message
Old 02-15-2012, 02:56 PM   #2 (permalink)
Member # 18997
start of mock up
measuring up rear diff
bum
rear mock up
setting up upper's
trailing arm mount's
belly
start of front link suspension
Old 02-15-2012, 02:59 PM   #3 (permalink)
Member # 18997
building the front link mounts
more tube's
some alum spacers to build bracket's
after we had it all tacked up we took them off fully welded them and re installed them.
random's
Old 02-15-2012, 03:00 PM   #4 (permalink)
Member # 18997
mocked up dual battery tray to work also as a x-member in the front, winch tray will tie into it later and front rad skid..
not finished yet but you get the idea..
seat mounts are next..
Old 02-15-2012, 03:02 PM   #5 (permalink)
Member # 18997
rear suspension mounts for trailing arms and upper links.
front bling.
seats mocked up
all double shear mounts
some griffen product to keep things cool..trans,steering,engine oil
Old 02-15-2012, 03:13 PM   #6 (permalink)
MattyB4x4's Avatar
Member # 32726
Looks good.
Any Info on the front skins?
Toyota buggy - duals + 4.7, 40's, linked rear/fox airs, shift knob
ΜΟΛΩΝ ΛΑΒΕ
MattyB4x4 is offline   Reply With Quote Quick reply to this message
Old 02-15-2012, 03:28 PM   #7 (permalink)
Member # 18997
Originally Posted by MattyB4x4 View Post
Looks good.
hazardous concepts joey a can't remember last name? good people to deal with...
Old 02-16-2012, 07:07 AM   #8 (permalink)
MattyB4x4's Avatar
Member # 32726
Exactly what I thought they were....
Didn't know if there was a new company ou tthere.
Thanks and keep up the good work
ΜΟΛΩΝ ΛΑΒΕ
Old 02-16-2012, 01:47 PM   #9 (permalink)
Member # 18997
atlas and front taco grill
playing with rear mounts
making the glass fit.
grill fitment
smoker bars
rocker bars to protect the glass a little
accusump
front radflo c/o's and triple bypass shocks for all corners
shifter placement
Old 02-16-2012, 01:48 PM   #10 (permalink)
Member # 18997
more play
first pedal
link material is here yea! evo hiems for everything
2 coolers semi mounted.
front bumper
revised lower shock mounts to clear steering better
bumper led bar soft mounted looks pimp will be a amber led for final
more links see how much rear steer we can get.
upper shock mounts, would have been nice to have 14s and not stick through as much but it can use up all of the 16 in the front so meh..
Old 02-16-2012, 01:57 PM   #11 (permalink)
so call me maybe?
]4RunnerKid['s Avatar
Member # 45812
Send a message via AIM to ]4RunnerKid[ Send a message via MSN to ]4RunnerKid[ Send a message via Yahoo to ]4RunnerKid[
curious to see the specs on the motor... looking
-Mikey-
Party Wagon
locked, geared, caged, topless, dents
Jeff Goldblum
LBZ, Allison, 4WD, TV, towing duties
4 doors for more whores
]4RunnerKid[ is offline   Reply With Quote Quick reply to this message
Old 02-16-2012, 02:47 PM   #12 (permalink)
Member # 18997
came out of our shop 2wd 1450 race truck. mainly built from paradise racing components and assembled here was low 300hp..
Old 02-16-2012, 06:12 PM   #13 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Fawkin sweet.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 02-17-2012, 11:33 AM   #14 (permalink)
Member # 18997
rear mounted rad and trans cooler finding there home, building some swing mounts so trans cooler can swing down for more viewing for trail wheeling also.
rad also came out of race truck that wont be used anymore.
cooler swung down just need to build some more mounts off the top of fuel cell mounts.
start of rad lines.
sorting out suspension limits, figured out steering,and where the hell the airbumps are going to go.
Old 02-17-2012, 11:37 AM   #15 (permalink)
Member # 18997
little bumper arms will get cut down after
so today's goal build new header,engine skid,rear belly t-case skid finished off, build lip for steering and installed,and maybe start on front bumps....
Old 02-17-2012, 04:23 PM   #16 (permalink)
Member # 21320
Looks great tman. Matt must be so stoked
TDI swapped lwb Samurai
BCzuk is offline   Reply With Quote Quick reply to this message
Old 02-17-2012, 04:59 PM   #17 (permalink)
Scooterloo's Avatar
Member # 26149
Can you tell me what engine/trans adapter you used? What stall is the converter?
Car looks great!
Edit: Also what did you do for a flex plate? Thanks
Scooterloo is offline   Reply With Quote Quick reply to this message
Old 02-17-2012, 05:17 PM   #18 (permalink)
Member # 110135
All I can say is "holy chit, bling-bling, cha-ching". Lookin' good.
Power Giant is offline   Reply With Quote Quick reply to this message
Old 02-18-2012, 09:42 AM   #19 (permalink)
Member # 47304
Using this plate adapter from LC http://www.lceperformance.com/Trans-...-p/1033034.htm
running the stock tacoma flexplate, waiting on Rusty from TCS to finish up the custom Torque Converter
and i am pumped I cant seem to keep the parts coming in fast enough
Car looks great!
#4487 ENTITE MOTORSPORTS
mdogg is offline   Reply With Quote Quick reply to this message
Old 02-28-2012, 09:52 AM   #20 (permalink)
Member # 18997
steering sorted out
bumps will limit on the lip
just need to add some bump pads on the lip.
engine skid started
the right quad tube bypass from the race truck are in it now for mock up.
start of the upper mounts..
have not been able to spend as much time on it latley but now that other projects are clearing up we can focus more time on it shortly....
Old 02-28-2012, 01:50 PM   #21 (permalink)
Member # 21320
Old 02-28-2012, 08:12 PM   #22 (permalink)
shoes optional
drewp's Avatar
Member # 142117
um...awesome, look forward to seeing this on some oregon trails some day
I NEED A HARLEY SS175 PISTON!!!!!!!!!!!!!!!!Found and now its time to build a bobber
drewp is offline   Reply With Quote Quick reply to this message
Old 02-29-2012, 08:41 AM   #23 (permalink)
Member # 45239
did i miss it how you gettin 300hp? turbo?
02 2500HD 6L tow rig
2010 GMC grilled 4 seat buggy 6.0LQ4 th400 203/205 60/14 42icants 114Wb
240hp kids buggy
www.KJMmotorsports.com
camarokid94 is offline   Reply With Quote Quick reply to this message
Old 02-29-2012, 09:24 AM   #24 (permalink)
Member # 18997
it is a very well built up 3rz no turbo has a full motec system also. it hauled the mail pretty good in the last rig it was in..
Old 02-29-2012, 09:45 AM   #25 (permalink)
Member # 208882
"It has a full Motec Exhaust..."
Sorry, I just hear that in my head anytime someone talks about Motec
1989 Toyota Landcruiser FJ62
Sirennet is offline   Reply With Quote Quick reply to this message
