SRM
Member # 87853
1.5 sch 40 pipe
Is 1.5 schedule 40 pipe considered welded hot rolled or something else.it measures 1.87 diameter would pipe in spots pass tech for koh?
Beat-It Fab chassis,tons,atlas,kings,347 ford powered! Beat-It Fab Dave's Off-road Outlet Torchmate X 5x10 powermax 85, plate marker always burnin! |
SRM
Member # 87853
No fuckwad,another guy asked me the same question and I could not answer him mine is getting all built from 1.75 dom, I am wondering what the correct terminology for poo pipe is and if infact would pass tech.
#6 (permalink) | |
Stock Rock Racer
Member # 195725
From what I have seen the technical inspection for KOH has not yet evolved to the point of taking sonic-wall measurements and hardness measurements, etc. That being said, I would not run poop-pipe in my cage. Tell your friend to cut out the offending tubing and replace it. It will be a small part of the overall budget; trust me.
Jason Kaminsky - Ultra4 Stock Class #4678 - Four Corners 4x4, Superchips, M.O.R.E., Durango Custom Works, Associations Direct, Clayton Offroad Manufacturing, Bigelow Motorsports, Savvy Offroad, Yukon Gear & Axle, Tom Wood's Custom Driveshafts, Metal Cloak, Bilstein, Grandview Land Holdings |
www.patparts.com
Member # 4821
Why trust your life to anything within your control? If you valued your life above all else like you are saying you wouldn't be driving a vehicle in a fashion in which a roll over was likely.
So all you are really saying is that you value your life at a couple more dollars/foot than someone else. Is that such a surprise? 99.9% of the population value their life greater than you in that they think risking it to drive over some rocks or through some sand is dumb / not worth it. Personally, I think they're more sane than you or I. J. J.
www.patparts.com
Member # 4821
Why is there even a question anyway? Shouldn't the official KOH rules be posted online somewhere for all potential competitors to access? And should not the rules makers have anticipated the poop pipe debate? People aren't honestly saying that this is totally out of left field, completely unexpected? They could easily just say, "poop pipe not allowed." So do they or do they not? We don't need another poop pipe debate thread. The OP was not asking "Is poop pipe strong?" The OP is just asking if poop pipe is legal in KOH. The answer should be, "Look at the rules dumbass," and if the rules aren't readily available the answer should be, "WTF aren't they?" and if they are and poop pipe isn't covered the answer should be, "WTF isn't it?" The dude shouldn't be crucified just for asking. The only dumb question is the one not asked.
J. J.
#9 (permalink) | |
SRM
Member # 87853
www.patparts.com
Member # 4821
http://ultra4racing.com/wp-content/u...H_rules_V2.pdf
See section 6.2.5.2 .So I guess his question is whether or not poop pipe falls in those definitions since I see nothing directly saying "no poop pipe." J. J.
Piggin' Ain't Easy
most rules just list "round steel tubing" or "structural steel tubing" with a minimum diameter and wall thickness per total vehicle weight...
According to what type of pipe you get, it can be just as strong or stronger than HREW. Normally not as strong or nicely finished as DOM, but can/is still plenty strong. I've used cheap threaded water pipe, high pressure gas pipe, handrail pipe, HREW, and DOM over the years on various rigs/projects. I like working with DOM the best, just like I like cold rolled steel plate the best too. Funds do not always allow the "best" to be used. And some projects don't require the "best".
Nick Cooper StockRunner build (stock height link suspension) turned firewall buggy Gremlin build - small ugly linked beater truck Last edited by TBItoy; 03-05-2012 at 03:14 PM. |
#12 (permalink) |
Karnage
Member # 55444
My heeps cage is made from 1.9"OD seamless(no interior flash) with a .145 wall. My rig is around 4000lbs. My "poo pipe" says ERW on it and had a niver finish on it that the last ERW I bought.
So by the rules.......I'd be legal?
Thanks to BAILEIGH INDUSTRIAL
![]() Krush RT IFS/IRS Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color] https://www.facebook.com/KrushRacing |
#13 (permalink) |
Member # 84991
Pipe and tube are just ways differnet ways of dimensioning round cylindrical bars with holes through the middle.
You can buy Drawn Over Mandrel (DOM) pipe or tube.... You can get seamed tube/pipe that has been drawn over a mandrel, you can get seamless tube/pipe that has been drawn over a mandrel....... They are just manufacturing process. After you have decided on the manufacturing process you like - you can then chose the material you want to use. Not all combinations of materials/manufacturing process are available based on whats worth manufacturing. Unless you quote a spec that defines the manufacturing process and the material being used you are comparing items that 'might' be the same, or 'might' not. I think your talking bollocks when you dismiss pipe....... Adrian Last edited by Breg90; 03-05-2012 at 03:28 PM. |
#14 (permalink) | |
XJ on 42's |
#15 (permalink) | |
Karnage
Member # 55444
I've done side by side comparisons on the two and people cant tell them apart.
#17 (permalink) | |
www.patparts.com
Member # 4821
J. J.
#18 (permalink) |
Member # 53528
do you guys think this chassis would pass koh tech?(with the other safety items added of course) its 1-1/4" sched 40, that would be way cool to enter just for fun
![]() /forum/toyota-truck-4runner/1031724-eyetri-poop-pipe-mostly-toy-buggy-build.html |
#19 (permalink) |
IDIot!
Member # 44480
Depends on your definition of "in spots".
A foot or two here or there where it's appropriate, sure. A sleeve somewhere or maybe for coolant (although it's too thick for either of these applications). In my A- or B- pillars or halo or door bars or x-bars? I'd go with something with a certification I needed. What Breg90 said.
Motive Gear Land Use Team http://www.tenfactory.com http://www.motivegear.com http://www.nationaldrivetrain.com http://www.davezoffroadperformance.com http://www.mastercraftsafety.com FToy 086 - UHaul Toterhome |
#20 (permalink) |
Member # 17870
I think the simple answer is that it is "Pipe". Looks like the rules require "Tube".
Arguing with a inspector is like wrestling with a pig in the mud. After a while you realize the PIG is enjoying himself! |
#21 (permalink) | |
IDIot!
Member # 44480
Tube is certified for its flexural and stiffness properties. It is entirely possible that a round cylinder with a hole through its length could be certified for both. Structural properties are published for what you refer to as "pipe", as well as "tube". If pipe is only for carrying poop, then why did ASTM publish standard # A53?
#23 (permalink) |
Member # 17870
I do agree that pipe and tube are not the best terminology to use here. It would be best if it was specified as a list of acceptable ASTM specifications.
#24 (permalink) | |
Member # 17870
I see the word "tube" a lot in that MTR. What do I win?
#25 (permalink) |
Karnage
Member # 55444
It also says Boiler and pressure vessel.
