Another Roof Rack made from Harbor Freight ATV Racks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2012, 08:04 AM   #1 (permalink)
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
For those who care about stuff like this.
I know Jscherb and USMCDOC14 have both made cargo racks for vehicles out of these parts previously. But hey, always room for one more, right?
I grabbed a pair of the ATV Cargo Racks from the HF in Omaha. 67623 is the part number. Then I grabbed 4 sections of 3/4" angle iron, 4 feet long. Also picked up 3 chunks of 3/4" square tubing, also 4 feet long.
I set the sections of the ATV racks on the roof of the truck I was working on and figured out that I wanted the finished rack to be 62 inches long. I had a long piece of 1" square tube in the shop, so I started with that as the 'spine' of the roof rack.
Then, with it cut to length, I started clamping the ATV rack sections to the back bone.
And then I plug welded the sections to the back bone, through the factory bolt holes.
Of course, remove the powder coating where you will weld.
You will submit to your benevolent government and you will like it.
rustywagoneersdotcom is offline   Reply With Quote Quick reply to this message
Old 06-07-2012, 08:11 AM   #2 (permalink)
Member # 65100
I figured out that from the end of the rack, to the end of each section of angle iron I would have 7" (62" overall, minus 48" angle iron = 14" /2 = 7").
So I placed the angle iron as shown in the last photo above, at the top and bottom of both sides. Weld the ends, short welds in a few other locations.
Be very careful when welding to the HF rack tubes. They are like 26 guage. SRSLY.
Then, take the 3/4" square tube and cut six pieces 23-5/8". Space them appropriately for the floor.
Still needs cleaning, painting, and mounting tabs.
Hope it saves someone some time.
EDIT: And yes, this is a 'flux-core' project if there ever was one....
Old 06-07-2012, 08:41 AM   #3 (permalink)
Member # 8335
That's pretty slick! Makes me want a roof to rack.
Any pics of it on your ride?
Partially Erect YJ
WideJ is offline   Reply With Quote Quick reply to this message
Old 06-07-2012, 08:48 AM   #4 (permalink)
Member # 65100
Will get pics this weekend when it is installed. Glad you like it.
Old 06-07-2012, 10:30 AM   #5 (permalink)
SpineTx's Avatar
Member # 1499
How much $$$ do you have into this? Great Job
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Old 06-07-2012, 11:02 AM   #6 (permalink)
Member # 65100
The HF ATV racks are 39.99 each (32 on sale, sometimes, I think...)
So 80+tax at the HF store.
Plus 70 or 80 in steel.
So, 150/160 range. Definitely under 200 after it is painted and mounted.
Old 06-07-2012, 11:30 AM   #7 (permalink)
SpineTx's Avatar
Member # 1499
Do you have the dimensions of the stock HF rack? The website says 42x38 but it doesn't look like that is accurate.
Old 06-07-2012, 11:49 AM   #8 (permalink)
Member # 65100
I would almost guess that's the size of the box it's in.
I will get some overall dimensions for you, but just working off my memory...
The rack sections are 23-5/8" wide (I know that one, because I had to cut those tubes for the floor) and just over 19" long. The reason I guess 19"+ long is that I went with 62" overall length for this rack, and when I went to center the floor tubes, the middle one was supposed to be (iirc) 11-1/4" from either section, which means the gap between the sections would have been maybe 22-1/2".
Old 06-11-2012, 08:15 AM   #9 (permalink)
Member # 65100
The assembly is 48-3/4" wide.
I made some simple tabs and bolted the basket to the factory roof rack rails. Removed the factory cross-bars first.
I don't know why my phone occasionally re-sizes a picture and puts that damn border thing around it. But it does.
Old 06-11-2012, 10:53 AM   #10 (permalink)
Member # 94400
Very nifty! I need to make one for my fj80.
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 241/205 42's
03 CTD toe rig
Texas Trail Buggy
what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster
slobuild57 is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 12:09 PM   #11 (permalink)
dr hook's Avatar
Member # 69819
Nice job! I have built a few roof racks for people, but I have never thought of using the ATV racks as a starting point. Well done.
dr hook is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 02:40 PM   #12 (permalink)
Awesome Fab Tools
RockRogue's Avatar
Member # 84883
That's a creative use for those racks!
ROGUE FABRICATION -Portland, OR
*Now available with 2HP ELECTRIC/HYDARULIC and auto rotation stops!
Joe(at)RogueFab.c0m
RockRogue is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 02:49 PM   #13 (permalink)
Run For the Hills
Mudinyeri's Avatar
Member # 44531
Might have to go take a look at those racks. I've been trying to come up with a rack for my canoe that would mount on top of my truck camper.
Real-world Reviews of "Evil Black" Gear, Missions, Tactics, Clothing & Weapons
Mudinyeri is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 04:40 PM   #14 (permalink)
Member # 99513
Thanks for sharing. You gave me some ideas for when I do my roof rack on the buggy
Swapping Front ends:
Motorcycle stuff.
[SIZE="5"][COLOR="Red"][B]NEW BEGINNINGS:[/B][/COLOR][/SIZE]
jpfrk2001 is offline   Reply With Quote Quick reply to this message
Old 01-21-2017, 10:33 PM   #15 (permalink)
Member # 168074
I found this thread and realized there is an ultra-rare photo of me and the blue truck, pre-chop/lift/tires. Wow.
And why the heck haven't I build one of these yet??
AMC/FSJ Whisperer
1982 Wagoneer 258/727/NP219, 32/36 Weber, '85 Eagle, '96 ZJ
kyamcalvert is offline   Reply With Quote Quick reply to this message
