Bronze spindle bushing problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-15-2012, 09:28 PM   #1 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
I have a set of the bronze spindle bushings. I had to replace one that was making noise with a stock needle bearing. The bushing ended up sizing on the shaft and started to spin inside the spindle. I had to torch the bushing to get it to "expand" enough to drop off. I thought it was a fluke, I noticed that side was a little tight. Today I went to pull both shafts out to replace the inners and the joints, and discovered that the other side was also spinning inside the spindle.
I got another set, but I want to know what should the measurements be? How much difference should there be between the OD of the shaft and ID of the bushing? The bushings are not a slip fit they require to be "push" to get them on, and they are not easy to spin, but will spin without tools.
Has anyone else had problems with the bronze spindle bushings? What did you do?
Ultra4 Blazer
Looking for 1(one) 43/17 SX DOT for a spare
Detroit parts D60 70 14b 2.5rock
Crewcab MDT Box Truck and Toybox camper for sale
Offroad Design ♦ Atomic MC ♦ DynoMax ♦ Raceline ♦ A1 Graphics ♦ Trans-Action ♦ Jantz Engineering ♦ Poly Performance
K5runner@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 06-15-2012, 10:39 PM   #2 (permalink)
Member # 76809
Ditch the bronze and get a set of Longfields UHMW bushings.
OKMudn is offline   Reply With Quote Quick reply to this message
Old 06-15-2012, 10:49 PM   #3 (permalink)
Corey Young's Avatar
Member # 21622
My guess would be they are too loose in the spindle and too tight on the stubs. I could take some measurements tomorrow. Rockwells and Toy axles dont have problems. Do you have one of those Longfield spindle grease tools?
Old 06-16-2012, 07:50 AM   #4 (permalink)
Member # 96153
No I do not. But I did grease it up real good. There was still grease in it when I got them out.
But like you said real tight. The new ones are from MadMac and the axles are USA Superiors. I'm going to install the CTM joints today and hopefully install everything else too. I was thinking of using some Green Loctite in the spindle.
Ultra4 Blazer
Old 06-16-2012, 09:44 AM   #5 (permalink)
Member # 34639
If it were me I would be inclined to knurl the outside and remove .002-.003 on the inside. Got access to a lathe?
Just trying to keep my sanity in modern america
oddcarma is offline   Reply With Quote Quick reply to this message
Old 06-16-2012, 10:05 AM   #6 (permalink)
Member # 96153
The new ones are 1.506 ID, the old ones were 1.500. The shaft is 1.500. I think I'll be okay. Green loctite will be the bushings friend.
Ultra4 Blazer
Old 06-17-2012, 06:11 AM   #7 (permalink)
Member # 6494
Use #641 green loc tite. It's a bearing retention compound. I'd also use copper anti sieze (the high temp stuff) on the id of the bushing.
#914 Pampered Chef Buggy
Companies we're proud to work with
East Coast Gear Supply
Reid Racing
RCV Performance Axles
Rose Grinding & MFG
Single Source Welding
Northern member of MUD DEVILS
EasyXJ is offline   Reply With Quote Quick reply to this message
Old 06-17-2012, 09:13 AM   #8 (permalink)
Member # 96153
Well I put it all together, I used some red loctite. It went together well. I greased it up well. I will take it out next weekend and see what happens. I have some of that green bearing retaining compound on my desk at work but didn't have time to go and get it. And its not available everywhere.
Ultra4 Blazer
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
