Member # 31211
Lokar-Shift Gate Modification
I recently picked up a TF 999 to swap into my CJ. I'm trying to decide shich shifter to go with. I have no room for a center console mounted shifter and I really like the fit and finish of the Lokar shifters. Plus, I've heard good things about them.
I searched but couldn't find much info on this... My question is whether you can modify the shift gates like you can a B&M pro stick shifter. Billavista's article was very insightful and I like the way he was able to modify the gates to his first to reverse, etc. So, can you make similar modifications to the lokar gates? For reference: http://www.pirate4x4.com/tech/billavista/shifter/ Thanks, Charlie
79 CJ-5, D44/9", 4 link F&R, 37's...and such. Disclaimer: My useless ramblings should in no way be taken as fact, and I will not be held liable for any carnage inflicted because of said ramblings.
Member # 31211
I read somewhere that you can grind a spot on the shift gate to skip neutral and go to reverse. This made me wonder if it had gates you could modify.
Member # 52376
I’ve never installed a Lokar shifter so I may not be the best guy for info on them but I have modified 2 B&M's per the Billavista article.
Sure doesn’t look like it has a gate. ![]() I’m going to ASSume that the button on the top is to go from drive gears to neutral/reverse gears. So there has to be some sort of detent that you could grind to make it go from drive to reverse without the button but it would have NO lockout anymore making it pretty dangerous at anything over a crawl speed. Think of a duffle bag or lunch box sliding forward causing the trans to shift into reverse at speed = ![]() The thing I love about my B&M is that in order to go to reverse I have to grab the handle and stuff it forward, seems safer to me.. Beside my doubler the B&M was the best Mod Ive done to my crawler, Love it for trail wheeling. My .02 |
Member # 87361
It has gates that can be modified, that's what the push button on the top is selecting and getting stopped on. Check out Jesse Haines 2010 promod build on here and there is a good picture in there somewhere of the gate where you can see all the stops and clearly see were you need to grind out a couple of them. The gate is located at the bottom of the shifter handle, you can kinda see it on the picture posted above, it's the middle zinc plated plate that's in the center of the zinc plated triangular mounts, it kinda looks like slice of pie.
#6 (permalink) | |
Member # 87361
Here's the post I was talking about from Jesse's thread,
Member # 31211
Awesome! Thanks for the info. It would be awesome if we could get some folks to thow in some tips and tricks to modifying the gate.
![]() I'll check out Jesse Haines' build. Thanks again!
Newbie
Member # 203043
I had a Lokar shifter and changed it out for an Art Carr. It lacked the positive feel I want for wheelin'. There are times you want reverse NOW with no guessing and, for me, the Lokar didn't have that feel. I didn't do any shifter plate mods to it before is was swapped out. It's a beautiful piece that looks very classy and I'd install one in a hot rod in a flash, but as a wheelin' shifter it wasn't the right fit for me.
#10 (permalink) | |
Member # 16561
I wouldnt put a winters shifter in a hot rod either.
4 seat FJ40 buggy. Alum 5.3 - Th400 - Atlas 4 speed - 60/14 - 42" stickies...etc...[url]http://www.pirate4x4.com/forum/showthread.php?t=660786[/url] Gone but not forgotten: 81 toyota truggy - LT1 - Th400+203+atlas3.0 - 60 / 14 - 42s. [url]http://www.pirate4x4.com/forum/showthread.php?t=520948[/url]. |
Member # 31211
Thanks for the feedback. I don't think I would want it without a modded shift gate. That's why I am wondering how that mod has worked out over time.
I don't really care about the look, but the packaging works better for me because my interior was set up around a manual. Thanks again.
#12 (permalink) |
Member # 87361
I've had both the lokar and art carr/winters shifters. The lokar was in a Toyota truggy with a swapped in 350/th400 that originally had a toy 5 speed in it so the lokar was a much better fit since it was in the exact same spot as the manual shifter and functioned pretty similar. I absolutely hated that shifter though! You never knew what gear you were in and since the lever arm is so large you can barely tell when you are in the detent in the tranny so with the gates removed it was dang near impossible to tell where you were at, at all. It sucked. As mentioned above too, it's kinda easy to pass reverse and go all the way to park, I did that several times. My lock button on the top would also get stuck down occasionally causing it to not stop on any gates which will let it go all the way to park with out you even touching anything which can get interesting.
All in all I don't care how well it fits and how much easier it will be to install that thing is not worth it and sucks for a wheeler, it's perfect for a hot rod though.
#13 (permalink) | |
Tough Line Toys
Member # 113892
The thing I didn't like about the shifter before I modded it was that 1st to 2nd would easily skip up to 3rd. (I like to chirp 2nd gear sometimes and this cramped my style ) So I added a stop there that only worked when I held the detent all the way down. I also added a reverse stop. In an emergency I just have to hold the button and slam it forward.To determine exactly where to put the stops I just used a small bar that was the exact same thickness as the detent and transferred the mark down to the lower side. ![]()
ToughLineToys.com Vectran® Winch Rope Toyota E-Locker to Air Locker Conversion Kits. Upcoming Products: 1.45:1/3.06:1 Gear Reduction Drive Shafts! Will be available for all makes & models.![]() Water Jetting: 12x6 table, cuts anything up to 8" thick. CAD work too, we can cut anything you can draw!
#14 (permalink) |
Member # 31211
Thanks for the tech red-gt'r!
I wonder if anyone has a CAD drawing of shift gate pattern options (like Billavista had a couple options). I've always ran a manual, so I won't pretend to know anything about auto shifters. Hoever, it seems that with a properly modded shift gate and a selector pin, it should be possible to have a successful crawler setup. I'd love to see more pics, drawings, tech regarding the shift gate mods. If Jesse Haines ran a modded Lokar in his Pro Mod build, I have to belive it can work well if done right. Something to think about... What would the pattern need to look like with a RMVB? Seems like if someone nailed down a good shift gate pattern for the Lokar and had it CNC cut, there might be a market of it. Just a thought. Keep the tech coming! Thanks!
#15 (permalink) |
I looked at doing this and found some pics on here a while ago. I think these were posted by "Chris" and show a modded Ford gate:
![]() I drew up the 700r4 gate and was going to have have Dallas cut me ones to play with but I never did. Here's the file: http://www.kordatron.com/temp/lokar/...hifterGate.dxf Found anther from a discussion on a different board this is what LAME said he did with his:
Josh Last edited by korda; 06-17-2012 at 07:17 PM. |
#16 (permalink) |
Member # 8937
Mine worked well after modified. I've got the same thing in my new buggy as well. I used a die grinder with a pointy bit to get in there all the way. It may take a couple tries to get it perfect.
Jesse Haines Fabrication #199/4499 - Maxxis, PSC, Superior Axle and Gear, Trail Gear, Branik Machine Shop, Valley Transmission, High Angle Driveline, Warn, Sway-a-way. |
#17 (permalink) | |
Member # 31211
Thanks!
#18 (permalink) |
Member # 8937
I don't. Sorry.
#19 (permalink) |
Member # 31211
No worries. I appreciate the feedback.
