#27 (permalink) | |
Member # 39
Eric Parts for Sale --> D44 shafts, 6 lug rims, air tank |
#29 (permalink) |
Member # 347
I've seen rock buggies with the spring removed and a machined plate that takes up all the slack. I guess for a rig that doesn't see much driving you don't have to worry about the wear on cone causing slop. But having no give at the kingpin seems counter productive.
As long as you can set the bearing preload with shim packs, how would this be any different than wheel bearings, Toyota closed-knuckle trunion bearings, or heavy equipment trunion bearings? Why did Dana elect to use a consumable puck of plastic for this application, anyway? Is the theory that it is better to smash the plastic insert instead of bending a tube? Wouldn't you wind up just smashing, THEN bending? Yeah, I know, this only becomes an issue with bigger tires and increased leverage, but it seems like it would be nearly as cheap to insert a bearing and shims instead of plastic and spring. I guess the latter lends itself to production more easily... ![]() Maybe some engineer bought the rights to turning out those bushings, intending to fund his retirement with future sales. ![]() Randii
Pack it *ALL* out... you pick up after your dog, so clean up after YOU, too. - VIRTUAL RALLY for the HAMMER TRAILS in JOHNSON VALLEY Post 1349 - VIRTUAL RALLY for TELLICO Post 716 and Post 924 - KOH Pledge Drive: for 4405 KOH Pledge #4 |
#30 (permalink) | |
Member # 3749
CB |
#31 (permalink) |
Member # 14018
This is great stuff. I'm assembling my D60 right now. I plan on doing this before its even installed. But won't be able to comment on it for a another month or so because of vacation plans. Thanks for the great tech.
'74 bronco 302/np435/d20, Gotpropane kit, full width d60's front and rear, 5.38's, detroit front welded rear, hydro assisted toyota steering, 42" tsl's, 5.5" lift w/ extended radius arms, and a lot of body damage, OOPS! |
#32 (permalink) | |
Ford Forum Moderator
Member # 421
76 F250 Supercab 2wd, undergoing Cummins/ZF5/D80 swap 78 F250 Supercab, 60/70 Doubler & dry rotted 42" TSLs. Waiting yet another rebuild. 3 more 70s supercabs, because you can never have too many spare parts around... |
#33 (permalink) |
Member # 3694
I have found on all my other 60's in the past when the death wobble shows up I just put a new spring in and it's fixed. I am doing hydro on my newest 60 now so I'll see if that acts like a "shock" to eliminate the Death Wobble.....
Might wanna check caster specs too....
#34 (permalink) | |
Member # 3654
A Dodge guy...yep, weirdo for sure. |
#35 (permalink) |
Member # 39
Sweet. I am glad you fixed your DW. I have had it and I have fixed it as well. Oh what a feeling to finally get it fixed.
#36 (permalink) | |
Member # 3654
WTF, i guess i gotta dive back in there.................the guy i got these tires from also had a DW problem. gonna try to switch the tires around and then check everything over again.
#37 (permalink) | |
Member # 538
I'll try the $5 for new springs first. A couple of people have posted that this cured their DW. IF there is a persistent DW problem with the new springs, then I may shim it - I'm sure that 44" square boggers on bent beadlocks was not a design consideration when the spring preload was determined. If I do use a shim, it won't be more than 1/8" thick. My 0.002 on D60 kingpin spring shims. |
#38 (permalink) |
Member # 39
Good info Lloyd.
The original post on ColoradoK5.com states...... "So we take the caps off, add 3ea 1/2" fender washers above the spring on each side (this is just under 1/4" of thickness). " I think some people have taken that to mean a 1/4" spacer is close enough. Does anyone know the spring rate of the king pin spring?
Eric Parts for Sale --> D44 shafts, 6 lug rims, air tank Last edited by Eric; 07-23-2003 at 08:40 AM. |
#39 (permalink) |
Member # 6425
hey guys,so what is the fix here slap some washers on top of the spring to make up for bigger tires ,or do what camo did and get a kinpin bearing on top.
i am in the midst or rebuilding the kingpins myself and putting all new shit in.should i just go ahead and slap washers in since ill be running 39.5's with full hydro or just keep it all stock and see what happens.... ya bastards got me all confused.....
THERE'S ONLY ONE TJ-7 |
#42 (permalink) |
Member # 12729
I had serious DW above 25mph just after my 60 install. Tossed on a steering stabilizer and shimmed the kinpin springs with 1/4" worth of washers, and so far no death wobble up to 55mph (haven't gone faster yet).
Guns don't kill people, bullets do. Guns just make bullets go really fast. |
#43 (permalink) | |
Member # 421
I'd still spend the $20 or whatever on new springs just because. I honestly don't see the point in bearings on the upper king pin. it's not like there's a hell of alot of load on that bushing/spring, the only reason I see it there is #1, to provide a pivot point (no shit huh? ) & to stablize the knuckle during any high speed vibration. Looking at the typical passenger side cap should tell you there's not a whole hell of alot of load on it (due to the barely above sheetmetal cap that typically exists) & the fact that I've pulled that cap off, full weight of the truck on the ground, & nothing moved. This leads me to belive the spring is there to absorb vibration, even of a stock 235/85-16... now you want to shim it, put a bearing in it, & run a tire that don't have a prayer of running as smooth as the worst 235.... to me I'm going to say that energy is going somewhere...fuck, I just read that... weird rant, but I'm drinking... please forgive me, but hopefully it'll make sense to someone.
#44 (permalink) |
Member # 2092
I'm with the "don't fix it till it's broke" crowd. Obviously, shimming the spring too much is bad, shimming around 1/8th instead of 1/4" shouldn't hurt anything.
My K5 has always had a bit of a "bump" at DW speed (30 or so) but with the assist ram it's no big deal. With the motor not running, like if I'm being flat towed, it's violent. So due to recent airborne stupidness, I take the springs and bushings out and find one side has a multi piece bushing and both springs are about 1/4" shorter than a new one. I "fixed" it by putting in new springs, new bushings and new spring cups. I actually used 2 spring cups to shim it a bit tighter, one top and one bottom. Result: a little hard to tell since I haven't run it without the ram but it doesn't have the bump that I could feel before. And it corrected about 1/2 of the 2" of toe out that appeared suddenly. So, we're putting together a spring and bushing kit, it should be about $18.00 or so for spring bushing and cup for both sides. It should be a good start on every quest to end DW.
Stephen Watson www.offroaddesign.com #4488 KOH '12 12th overall KOH11 28th. It's a finish! KOH11 Sportsmanship Award. Friends & partners who helped: Offroad Design, Pacific Fab, King, Baja Designs, TrailReady, Amsoil, PSC, Tom Woods, Bighorn Graphics, Superior, Optima |
#45 (permalink) | |
Member # 421
#46 (permalink) | |
Member # 15646
New kingpin parts are available, as well as any other dana 60 parts, from HERE
Peter |
#47 (permalink) | |
Member # 538
#48 (permalink) |
Member # 12247
Im surprised you guys are so far behind, the Collingwood boys were onto this shit 15 years ago. Very surprising considering they spend more time on the dogsled than in thier 4x4......
Keep the rubber side down ! |
#49 (permalink) |
I tried this today on my HP60. Used a pitman arm washer from a spare box I have. Torqued down the steering arm bolts, test drove, no DW.
The thickness of the washer in question was 3/16" for future reference...
www.ujointoffroad.com |
#50 (permalink) | |
Member # 39
Did you have DW before you did this, or did you just do it to make sure you don't get it?
