King Pin Dana 60 Death Wobble Fix!! - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-11-2011, 08:02 AM   #76 (permalink)
onetoncv's Avatar
Member # 2160
I ran a steering assist like others and Hit 105 with no death wobble- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 08:58 AM   #77 (permalink)
Member # 99590
Wow, this is an awesome thread! I will do this before I put the Chevy back on the road! I experienced DW only a couple times but it freaked the crap out of me!
ChevyTurk is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 09:59 AM   #78 (permalink)
P&T Jeeps's Avatar
Member # 3916
Smith; what does your caster look like? If you don't have enough angle there you're going to have a hard time getting the DW under control.
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
P&T Jeeps is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 06:06 PM   #79 (permalink)
Member # 182886
i'm not sure what the angle is. Everything is in the stock form or should be. I was told to replace my steering damper thought i might give it a try
smith.5316 is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 06:17 PM   #80 (permalink)
justscoutin's Avatar
Member # 32053
are your tires in good shape? my scout will DW if I swap the tires side to side on the front. swapped them back it quit. is there any play in your steering box? that'll do it too.
88 chevy crewcab 6bt nv4500
72 scout 4bt on tons
justscoutin is offline   Reply With Quote Quick reply to this message
Old 02-12-2011, 04:58 AM   #81 (permalink)
Member # 182886
the tires are probably junk. they were round and had some tread so i just threw them on there until this spring when i get a new set. I could always put 2 of the nice ones off the rear on and see what happens
Old 02-12-2011, 04:23 PM   #82 (permalink)
Member # 67278
I tried the OP's fix with washers yesterday afternoon. Before, had unbelievable DW between 30 and 40 MPH, now its gone.
Thanks for some good tech!!!
Marshall
brownms is offline   Reply With Quote Quick reply to this message
Old 02-17-2011, 04:55 AM   #83 (permalink)
Member # 182886
had you replaced the old spring before shimming it or did you just need to add more tension
Old 02-17-2011, 06:33 AM   #84 (permalink)
Member # 82745
Smith - How worn are your TRE's and DLE's? Steering box tight? Frame cracked around box? Leaf spring bushings worn? Ubolts loose?
Something is shot. Take a look at all of the steering components while you have someone turn the wheel back and forth..
90K5, STAK3, 60/80, 44" PBR's
96Z40 is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 10:27 AM   #85 (permalink)
yoder man's Avatar
Member # 123895
Dana 60 knuckles too tight
I just assembled my ford dana 60 (78') with chevy style deaden bear knuckles, chromo 35's inner/outters yukons, grizz locker, 5.13's, 1350 yoke, rock stomper flat hi steer arms with caps cut off and welded on for a smooth botttom with 5 studs. Rebuild kits on both sides and now it's so hard to turn the knuckle when fully tightened. This is with or with out axles installed. The caps are maybe 1/16" shorter than a stock one now, but didn't think I could f this up. Goes to prove I can f up anything. I know this is opposite of this thread but I searched for a place to get some input and this is the best place I found. Thanks in advance.
yoder man is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 11:41 AM   #86 (permalink)
Member # 24859
did you get the nylon bushing indexed correctly ? So the rib went in the groove ?
You say smooth bottom then you say the caps are within a 1/16 of stock.
Is the steering arm flat with a preload nut for the bushing or is there a spring in there ?
Also, beware, not all springs are the exact same size, if you are running springs.
You may have to get shorter spring or fix the cap depth to get preload set properly.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 07:52 PM   #87 (permalink)
yoder man's Avatar
Member # 123895
fixed it thanks
Yea I cut 1/8" off of the top of the plastic bushing and it all seams great now.
Old 11-16-2012, 08:38 PM   #88 (permalink)
Granit Technician
lil,yota's Avatar
Member # 102395
Glad I came across this thread. I'm gonna be doing some work on my DD next week and was hoping that new tires were gonna cure the DW. Looks like I'll be adding some shims at the same time. Thanks for bringing this thread back.
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 05:41 AM   #89 (permalink)
Member # 149861
Originally Posted by geberhard View Post
Well this is a heck of old thread, but I was just thinking about something like this recently. I have had to add pinion shims on my springless kingping arms to deal with DW, but was thinking, why the heck not just create a hole through the arm, over the nylon bushing with a big ol' stud or socket that could be tightened and adjusted as neeeded. seems likea simple enough solution?
Gui
Old thread yet again but has anyone done something like GUI mentioned? I know they make arms with set screws already but for as easy as it would be why not try. My arms still have spring caps and I still use springs. I'm gonna fab something up today and I'll try and post it. Gonna weld a washer to the stud and weld a bolt to the top of the cap. In theory turn bolt and washer will put tension on the spring as needed!?
Any input before I have at it?
:flipoff2: [COLOR="DarkOrange"]99tj / d60's / CO's / 40" mtrs / atlas / 104" WB[/COLOR]
GSEnick is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 08:48 AM   #90 (permalink)
Member # 94400
Been using these with great success.
se60
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 241/205 42's
03 CTD toe rig
Texas Trail Buggy
what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster
slobuild57 is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 12:38 PM   #91 (permalink)
Member # 149861
Used an 1/8" solid flat washer under the cap, drilled 1/2 hole in the cap. Welded a locking nut (not nylon) and used a set screw. Seems to work good. Of and drilled and tapped a new grease fitting. Now it's fully adjustable! I must have had the caps off 20 times trying to find the right shim that got rid of the shimmy and didnt kill my steering left to right. Now u can dial it in just right. Will update if it doesn't work out over time. This could be used with the solid springless bushing as well. Cost was about 6 bucks and an hour of my time.
Old 06-03-2013, 12:48 PM   #92 (permalink)
Member # 215352
A machined springless cap is 50$
Dana 60 Spring Eliminator Cap (Pair)
"You had fun wrong, here is a list of everything you did wrong."
ringding is offline   Reply With Quote Quick reply to this message
