#176 (permalink) |
Member # 78079
I hope Wayne sells a ton of springs and ups attendance at his tuning days for all his time in this thread
Master of the wire Wheel! Coastal Fabrication the " best damn shop in town" Poly Performance Pacific Fabrication http://www.pacificfab.net/ Last edited by Valley Auto; 07-12-2012 at 11:43 AM. |
#177 (permalink) | |
Member # 6576
![]() On a typical Rubicon weekend, I have two 60+ qt coolers, chairs, a grill, sleeping bags, a tent, clothes, a pack n play, and fishing gear either on my roof, or hanging off the back of the buggy. Maybe not 600lbs, but I'd say at least 400 more than normal.
Brian Whitford 711 Dysfunctional Rockcrawlers Rage 4th............ "safety is our #2 concern" |
#178 (permalink) | |
Member # 138167
This is again why IMO you can't apply the exact same spring choice strategy to every customer. An Ultra 4 car should be sprung differently than a daily driven TJ/CJ/YJ etc. that is going to be loaded up with a metric shit ton of gear and driven over the rubicon once a year. Many of these Jeeps are running 4-5" of up-travel. They would be sitting on the bump stops pulling out of the garage when loaded up with Wayne's spring strategy. When it comes to go-fast and Ultra 4- Wayne and I are on the same page.
AKA - Dusty Booger Jeepspeed 1749 (1719 2008 Baja 1K) ![]() www.dirt-fab.com e-mail: info@dirt-fab.com Phone: 510-502-8508 |
#179 (permalink) |
Smores!
Member # 1889
Add 600 pounds, retune for that condition. Take it off, go back to previous tune. Or split the difference and deal with that it won't be ideal anywhere. That's the life of a jack of all trades, you can tune to the nth for one thing and really kick ass at it (and probably suck at a lot of other stuff), or you can tune to the compromise and have a compromise at everything.
Personally, I'd tune for the go-fast condition, and just deal with the suck on the go-camping setup; I don't race to campsites, I just poke along and enjoy the scenery away from the city where my cell phone doesn't work, so the car working well at 60mph is irrelevant at 4mph.
#180 (permalink) |
Member # 78079
Its no different than having air shocks. My old sami ran 200# in the rear normally for Rubicon and such I had to run up to 350 psi. Not really any harder to add nitrogen as it is to add preload. Just remember where you started.
Master of the wire Wheel! Coastal Fabrication the " best damn shop in town" Poly Performance Pacific Fabrication http://www.pacificfab.net/ |
#181 (permalink) |
Member # 138167
If you are running 100/150 on TJ with a combined spring rate of 60#s and you add 600# of crap on the rear. Let's just say you added 300# corner weight. You just compressed your shock 5". Are you going to adjust the collar down and add 5" of pre-load and run it? Is that what you are suggesting?
#182 (permalink) | |
Member # 6576
But I agree, if I had a street driven TJ, thats not what I would want to do.
#183 (permalink) |
"Chip Ninja"
For me, I will be doing more camping/hauling 600 extra lbs then I will be hauling ass through the desert so I don't really want to have to set my shocks up with 6 inches of preload. I'd prefer to set them up and then when I go light for the dez I can back off the top adjuster nut to lower my height. So for me, it seems to make sense to use shorter upper springs and let my triple rates take up some of the last few inches on extension. I do understand what is generally being suggested however.....
#184 (permalink) |
Member # 217997
This is just an awesome thread. No tech to add, but i'm suscribed. This has helped out a ton tuning my coilovers on the JK. I have been working on tuning for the past two months almost every weekend, but now with this thread I should be done in another week or so. This has been very helpful and very interesting information!
I apprecaite the time that everyone is putting into this.
#185 (permalink) | |
FroBot
. My spring tuning knowledge is only what pirate has told me). It seems like being anywhere in that range might have a tender spring fully compressed anyways.How much weight does it take to fully compress your average tender spring to block height?
Dovenosed 5 speed WJ on 9"s and an ongoing won-ton 5.9 ZJ build
#186 (permalink) |
Member # 18614
The flat coil tenders take almost nothing to compress.
#187 (permalink) |
Member # 20631
Yes, they're referred to as "zero rate".
Buy my buggy. |
#188 (permalink) | |
"Chip Ninja"
#189 (permalink) |
Member # 28177
Using Wayne's system you wouldn't run a zero rate or tender coil to begin with. That is only to keep the springs from coming loose when they are too heavy a rate and you have to run no preload. Or the spring combo is way to short. By running the "light" springs Wayne is suggesting and adding preload to achieve the right ride height and other benefits you eliminate the zero rates. That in conjunction with the lower being shock travel plus 2" and the right length upper.
Smiley Racing 609 1st Place KOH class Badlands UMC race Oct 2nd 10 11th and 8th place 1st and 2nd RCrocs 10 New buggy http://www.facebook.com/TeamSmileyRacing Thanks to: Crane Clayton Offroad BFGoodrich Bilstein Tom Woods Driveshafts Tom Guaraldo RIP! Last edited by whypave; 07-13-2012 at 03:30 PM. |
#190 (permalink) |
Member # 138167
Again, I get where Wayne is coming from- especially on an Ultra 4 rig with good up vs. down-travel, a shock package to compensate for the soft springs, and a racer willing to put in the time to tune etc. My point is that you need to consider shock package, vehicle use, customer expectations etc. when choosing springs.
Let's say you have a TJ w/750# rear corner weight and they want 4" of up-travel on a 14" travel shock. (Not uncommon) That means you need the shock to compress 10" plus another 2-3" of pre-load if you follow Wayne's 100% spring choice strategy. You would need to run a 100# x 14" over a 150# 16" with a combined spring rate of 60#. At ride height with normal weight, the top spring would compress 7.5". An Eibach 14" x 100# coil has 9.61" of travel before blocking out. (Eibach's are typically higher travel for the same length and rate vs. other manufactures.) This leaves you just over 2" left of travel in the top coil. Now you load up the Jeep with bitches, beer, & steak. Another 210# or rear corner weight and you just blocked out the top coil.
#191 (permalink) |
Member # 50632
Softest spring that will do The job.... If you add 600# the softest spring is not the same any more.
Plus a jack of all trades is a master of none. Just another compromise we make when building a rig. Consider all tasks or as many as you can! |
#192 (permalink) | |
Member # 138167
You have to make compromises based on planned use of the vehicle.I expect most customers do not want to re-valve and change springs depending upon that day's use of the vehicle.
#193 (permalink) |
crawler
Member # 167647
I am just setting up my coil overs to your advice but it has a good amount of body roll. some of my buddies say i need to just go with a higher spring rate. so should body roll not neccessarilly be controlled by the springs? mainly by sway bars and slider stops and valving?
1989 f-150 dana 60 front, 10.25 rear. 3 link with coil overs out front. chevy 63s double shackled out back. bobbed bed. rollin on 37s the build up of ^ truck /forum/ford/1015047-project-89-f-150-a.html |
#194 (permalink) | |
Piggin' Ain't Easy
Nick Cooper StockRunner build (stock height link suspension) turned firewall buggy Gremlin build - small ugly linked beater truck |
#195 (permalink) | |
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger Last edited by Wilson; 07-13-2012 at 10:47 PM. |
#196 (permalink) |
Member # 136758
Wayne thanks for all the good info!
if you run a softer spring setup (how you would set something up) and have the right valving/weep hole adjustment are you able to have a 'street-able' rig without needing sway bars?
Bro-coma Last edited by -Matt-; 07-13-2012 at 11:00 PM. |
#197 (permalink) |
Member # 50632
Not much time this morning but yes springs help with sway, that's thats dual rates job.
I have never disagreed with you dirt-fab just want people to look at a different way to do it. Softest spring for the job and re read the very first line in the very first post. Theory works on go slow/streetable too but you have to consider more or different info. Springs won't fix a tall poorly designed floopy jaloopy and most all coil sprung cars come stock with a bent bar sway bar so I would say a sway bar is a good idea for the street if you go tall and all that. Sway bars are not a band aid but an aid to be used appropriately. We do have several cars that are drivavle on the street with no sway bar but are better with a small one. |
#198 (permalink) |
Member # 94026
Great Thread. And I don't think it was intended for multiple use rigs, but:
My Flatfender has a IRS, similar to a older Corvette with swing arms. Built many years ago (40+) and wayyy before by-passes. To solve the "go-fast"/ Rubicon load problem, there are two shocks with coil overs on each arm. One is sprung for go-fast, and the other is nothing more than a BIG helper spring that I can crank up into play when loading it up. The second coil-over shock could have been an air shock, or even an air bag, but they wouldn't fit...or look cool. Is an "elegant solution" to multiple use, a coil overed, stop nut, ORI? King makes a top bagged shock for a dune buggy manufacturer and pressure changed depending on # of passengers. Thanks for helping us with ideas for go-fast with minimal body roll. I think many are not realizing the value of the slider stop nut. I am thinking that the sway bar would still be necessary or very helpful to prevent roll near the top of the stroke (like after a unweighted jump) and if the stop nuts had to be adjusted so "tight" near ride height preventing good soft compression. Is that on the right track? How you guys feel all of that, and to know what to do...is awesome! |
#199 (permalink) |
Member # 11145
so here is a ? I know you are setting up to go fast but when u get in the rocks or dirt here on the east cost for a short steep climb are most of the guys using the winch to suck the front down? I know my buggy (not u4) doesn't like to go up hills with no suck down, or is that taking out in the valving. I see a lot of u4 cars with suck down hooked up just want to know if it is a trade off for going fast with this set up. Thanks for the great info.
TTC 2010 Competitor #48 Thanks for the votes it was a great time. Thanks to Micky Thompson Tires,King Shocks,Warn,RCV axles,ARB,Viking Winchline, OMF Wheels for the help to make my junk run. |
#200 (permalink) | |
Member # 50632
AllTech Motorsports Fuel systems, shock work, custom fiberglass and more (951) 970-3399 www.alltechmotorsports.com wayne@alltechmotorsports.com new e-mail address! Congratulations to Alltech customers Erik Miller, 2012 KING of the Hammers Rick Mooneyham 2012 2nd place John Currie/Gerald Lee 1st place EMC Derek West for 4 pole positions in 2012 And all our customers who finished or took the green flag! |
