14 bolt R&P install NOW - need help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-28-2012, 04:33 PM   #1 (permalink)
OnTheRocks's Avatar
Member # 891
Just heated up my Thick 5.38 ring to install on 4.11 down carrier and think I have the wrong ring gear bolts. I'm holding off on my expletive laced rant until I know for sure, but do the thick gears require the longer 2.1" ring bolts or the standard 1.8" for the smaller gear set/carrier. I ordered new 1.8 bolts from Randy's and I'll be a Mother F if I needed the longer ones. Need this POS together by the weekend. Anybody?
Infrastructure is overrated
OnTheRocks is offline   Reply With Quote
Old 06-28-2012, 04:52 PM   #2 (permalink)
Newbie
Member # 112171
I never thought about needing longer bolts, but I recenty set up thick cut 5.38s on arbs (f/r) and the stock length bolts worked fine. I didn't heat the ring gear, just eased it on with a dead blow. Maybe someone else can chime in if maybe I did mine wrong?!?!
TPD_53 is offline   Reply With Quote
Old 06-28-2012, 05:17 PM   #3 (permalink)
OnTheRocks's Avatar
Member # 891
I'm liking where this is going...
Old 06-28-2012, 06:11 PM   #4 (permalink)
Member # 46175
In my experience, the longer bolts are for the 4.56 and up carrier. The 4.10 and down carrier uses the short bolts.
You have heated the ring gear, but is it flush with the flange? Are you asking about longer bolts to draw it on the carrier? Or do the bolts you have not seem long enough even with the gear flush against the flange? Are you sure it is a 4.10 and down carrier?
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote
Old 06-28-2012, 06:39 PM   #5 (permalink)
jpcrawleram's Avatar
Member # 18734
2x on the longer bolts with the 4.56up
Also double checking your not pulling thd gear up on the face.
Lastly they are 1/2 -20 grade 8 bolts you can buy at any parts store for cheap enough it wont hurt your weekend
good luck
LetzRoll Offroad / LetzRoll offroad Racing 4493
www.letzrolloffroad.com
480 797-0469
All your Hardcore Crawling / Racing needs!
PSC Motorsports, 4340 Axle shafts (many brands) Custom or factory, Gears, Lockers, Yukon, Reid racing, Trail Ready, Advance Adapters, TeraFlex, Ballistic Fab, RuffStuff, 7075 t-6 links, Custom axles, 9'' 3rd members, Mads Smarty, Solid (spintec)
jpcrawleram is offline   Reply With Quote
Old 06-28-2012, 08:35 PM   #6 (permalink)
Member # 53528
when i put my first set of thick gears in i had the same question, what i was told is you use the shorter bolts with the thick gears, i ordered new ones but was told there is no problem re using the old ones.
rockyota83 is offline   Reply With Quote
Old 06-28-2012, 08:56 PM   #7 (permalink)
OnTheRocks's Avatar
Member # 891
I'm with you fellas on the shorter bolts for the 4:11 & down carrier. That's why I ordered them from Randy's. However, the dilemma is with the thick gears. Obviously, on the thinner stock ring gear, I can't use the longer bolts as they would bottom out. But these thick 5:38's are deep as fuk and I was curious if I should have used the larger carrier ring bolts as they would surely fit. The heated ring gear is not in the equasion. I should not have even mentioned it. I heated it because the thick mother chucker ring gear was not motivated to get past the carrier lip. Voila! Heater up and it slid right on. I will go with the 1.8 bolts and dare it to come apart. Again, if anybody has used the thick gear with 4.11 & down carrier and think I should use the longer ring bolts, please chime in
Old 06-28-2012, 08:58 PM   #8 (permalink)
OnTheRocks's Avatar
Member # 891
btw...Thanks for the input. I hadn't even realized you answered my question.
Old 06-29-2012, 08:58 PM   #9 (permalink)
Member # 53528
no problem, scott (aka machinewave) sent me this in a pm when asking about the bolts
You dont need other bolts for the thick gear...I can get you new bolts if you want them, but they are not needed...
Thanks...Scott 812-623-3473 machinewave
Old 06-30-2012, 06:41 AM   #10 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
good luck
Wouldn't you want the correct bolts that have a shoulder on them in the area that goes through the carrier? I don't think I would want a bolt with threads in this area and shorter common bolts have threads most all the way up the shank. Although I'm not certain on common 1.8" bolts.
Fistful of Steel Fab
My Rockwell Buggy Build Thread "Dirty Bastard"
Landslide is offline   Reply With Quote
Old 06-30-2012, 12:04 PM   #11 (permalink)
78stepsideUAK10's Avatar
Member # 92930
I just used the old ones with locktite, didn't even think about longer bolts
Web wheeler
78stepsideUAK10 is offline   Reply With Quote
Old 07-08-2012, 06:00 AM   #12 (permalink)
GubNi's Avatar
Member # 25927
Short bolts will be fine.
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here
Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here
Dana 60 front 3/4 ton kits $350--> click here
GubNi is offline   Reply With Quote
Old 07-08-2012, 04:30 PM   #13 (permalink)
Member # 18734
Yea correct but in a pinch you can get the longer ones with shoulder and trim them down a bit.
Just a way to get wheeling this weekend type of thing. Il
480 797-0469
