Clocking a Dana 20? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2012, 02:14 PM   #1 (permalink)
Member # 29
Clocking a Dana 20?
I know I am going to get beat on for this, but, I ahve a TH400 at home with a fresh rebuild as well as a Dana 20. I know the 20 is considered pretty strong (besides the output shaft). I can't swing the cost of the Atlas or any other high end t-case. I DO want to clock the Dana 20 though. In all my searching, I see people have tried this by redrilling the case, and I have seen others that made a makeshirt adapter. My biggest question with the adapters, and those that made it is:
When you make the 1/2" adapter, i know oyu lose 1/2" of contact on the gears. is this an issue at all?
Any advice you guys that have built these can give me?
dima
1974 FJ40 in the works
2006 F250 crew cab longbed powerstroke for towing duties
Flatty is offline   Reply With Quote
Old 07-10-2012, 03:16 PM   #2 (permalink)
no_bs's Avatar
Member # 114256
I assume you are talking about a Bronco Dana 20? Clocking a texas pattern seems ridiculous. I personally have broken a rear output (26 spline jeep), and cracked 3/4 of the teeth on the rear output (1/2 of those nearly broken off). This is all with a 4.7 stroker, 40" treps and T18. Beings as the 20 is a bull gear input, you cannot put a spacer in there unless I am missing something.
Trail rig, '77 CJ5, 4.7 stroker, 60/14B 40" Treps/Racelines, Broken frame
no_bs is offline   Reply With Quote
Old 07-10-2012, 03:22 PM   #3 (permalink)
Member # 5326
It would be a little odd, but if the 6-bolt pattern on the Th400 is symmetrical you might be able to clock the factory adapter there? It would mess up the angle of the transmission mount but I think working around that would be fairly easy.
It's a 6 bolt pattern so that would be a big jump in case angle. Depending on the shape of the adapter maybe you could redrill the bolt pattern at the transmission instead of the transfer case?
Mieser is offline   Reply With Quote
Old 07-10-2012, 03:39 PM   #4 (permalink)
77k5's Avatar
Member # 35786
The TH400 bolt pattern is not centered around the transmission output i.e. the bolt pattern is below center, can't clock that piece.
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call!
chrish@offroaddesign.com
offroaddesign.com
970-945-7777
77k5 is offline   Reply With Quote
