14 bolt crush sleeve eliminator - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-29-2012, 10:27 AM   #1 (permalink)
THE VOICE OF REASON
imagineer's Avatar
Member # 50419
This may be a gratuitous promotion of a product, however anyone who has ever setup a 14bolt or needed to replace a pinion yoke on a gm 14 bolt can appreciate this.
Back in November I was introduced to Randy Lyman, of Randy's Ring & Pinion at SEMA. Among the things we talked about was making a kit to replace the crush sleeve in the 14 bolt axle. I had been making this kit for years for my own use, and just a few months after I made the suggestion of the product it is available to the public.
http://www.ringpinion.com/b2c/Produc..._Gear_and_Axle
Murphy's Law Motorsports #816
Check us out on
OPTIMA BATTERIES, YUKON GEAR, RACELINE WHEELS, GRIFFIN , FLEXCON, BAJA DESIGNS, FOX RACING SHOX, HOWE PERFORMANCE, B.F. GOODRICH, MITCHELL DIFFERENTIAL, PRP SEATS, FIREBALL HEAT TREATING, JET LUBE, PAC RACING SPRINGS, KESSLER MACHINE.
imagineer is offline   Reply With Quote Quick reply to this message
Old 07-29-2012, 11:57 AM   #2 (permalink)
Horsepower Junkie
huff75's Avatar
Member # 173427
Been done for a while. http://eastcoastgearsupply.com/i-669...id-spacer.html
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's
The Making of a Turd:
huff75 is offline   Reply With Quote Quick reply to this message
Old 07-29-2012, 04:34 PM   #3 (permalink)
Wilson's Avatar
Member # 7233
Got mine from EZ, still need to return my unused shims
Old 01-18-2013, 12:33 PM   #4 (permalink)
Master Tinkerer
oldtimingman's Avatar
Member # 75774
Why will it not work on 14bts before 88? I'm confused? listings only say 89 and up? whats the difference? this has nothing to do with the straddle bearing on the pinion .
oldtimingman is offline   Reply With Quote Quick reply to this message
Old 01-18-2013, 07:32 PM   #5 (permalink)
mj
Member # 1919
"assembled in USA" wow
mj is offline   Reply With Quote Quick reply to this message
Old 01-18-2013, 09:09 PM   #6 (permalink)
Member # 53528
thanks for bringing this back up and reminding me i need to order two of them
Old 01-18-2013, 09:10 PM   #7 (permalink)
Member # 53528
wtf are you talking about?
GM 14 BOLT SOLID SPACER. DESIGNED FOR 88 AND DOWN WILL INSTALL IN 89 AND UP WITH EXTRA SHIMS PROVIDED
works fine with extra shims
Old 01-18-2013, 09:11 PM   #8 (permalink)
Wilson's Avatar
Member # 7233
Rick told me the same, not sure why, but something must be different in the pinion support.
Old 01-18-2013, 09:19 PM   #9 (permalink)
Member # 53528
east coast one works fine in all 14bolts according to their link
Old 01-19-2013, 09:39 PM   #10 (permalink)
Master Tinkerer
Member # 75774
According to the Yukon site it only lists 88 and up? That's what had me confused?
Old 06-01-2013, 05:49 PM   #11 (permalink)
Member # 215156
Does anyone make solid spacers for the 9.5" 14 bolt or do I need to make my own?
Spyder78 is offline   Reply With Quote Quick reply to this message
