Ford Bronco Solid Axle Swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-02-2012, 01:45 PM   #1 (permalink)
Member # 215765
1990 Ford Bronco Solid Axle Swap
Dana 44 and Ford 9 axles from a 1979 Bronco were selected for this project. Being a Yukon dealer, we installed Yukon 4.88:1 ring and pinion with a Detroit locker in the rear. A custom disc brake conversion was built using stock Ford D44 front rotors and GM calipers. Settling for nothing but the best, Deaver springs were used all the way around. For simplicity, a set of James Duff control arms were purchased with the understanding they would bolt right in. Unfortunately the frame rail width was much different. It could have been forced but would have lead to premature bushing wear, so the brand new control arms were cut up. The main body of the arm was flipped for ground clearance. A custom set of coil buckets were cut on the CNC machine for a total of 6.5 lift. We were able to maintain parallel and equal length panhard/drag link so the suspension system will oscillate in unison. The panhard bar was constructed out of 1.5 x .250 DOM Tube with four strategically placed bends allowing 4.5 of up travel. Stock front driveshaft was retained with a conversion U-joint but the rear is custom.
End result: a firm, stable ride on the street and more than ample articulation on the trail.
Black Hat Fabrications
Justice Racing and Performance
Frederick, MD
301-624-1000
Black Hat is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 02:39 PM   #2 (permalink)
Member # 215765
this was a really fun project. i dont get to work on full size rigs very often!
Frederick, MD
301-624-1000
Old 08-14-2012, 03:32 PM   #3 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Does the diff hit the TTB crossmember under the engine at stuff?
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 08:57 PM   #4 (permalink)
Member # 130300
X2 from the looks of it that cross member needs to go on a major diet...
Looks good though
Mikes79bronco is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 12:19 AM   #5 (permalink)
Alaskan Wheeler
nkldrgr's Avatar
Member # 44053
Not the worst that we've seen. Ream the knuckles and flip the tie rod to the top. Trust me, it will help problem that you don't even know you have yet.
It only take two things to fly: airspeed and money.
nkldrgr is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 12:51 AM   #6 (permalink)
skullver's Avatar
Member # 60364
I think that is the bumstop haha. I don't see any elsewhere.
:flipoff2::flipoff2::flipoff2::flipoff2::flipoff2:
skullver is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 02:24 AM   #7 (permalink)
Member # 170546
thats what the shocks are for! they also act as limit straps.
SkooledMedic is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 06:33 AM   #8 (permalink)
KyleQ's Avatar
Member # 83837
Looks like those arms are on upside down as well... You get better clearance if you flip them over from where you have them currently mounted. The entire length of the arm would be higher off the ground compared how your currently have them and the end doesn't matter as the tire is right there...
Looks good though - Duff looking buckets, Deaver superflex coils and Duff arms. Makes for a good combo - probably don't need to hack much out of that TTB x-member with the BGTL style lift...
Got any further shots?
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60, Powr-Lok 70U - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 43" TSL SX on H1 Beadlocks
KyleQ is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 08:49 AM   #9 (permalink)
Member # 91895
On the duff arms everything can be fabbed except for the rear C bracket, is there a vendor that offers just that piece with mount holes as shown?
Not a welded up stock one.
bigcrunch is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 10:06 AM   #10 (permalink)
lol
IEATRKS84's Avatar
Member # 118035
x2 on this
IEATRKS84 is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 10:29 AM   #11 (permalink)
Member # 215765
The shocks are the bump stops and the limit straps....
if i flipped the tie rod to help minimize the torsional action i would have had to cut up the engine crossmember and as of right now everything clears
Frederick, MD
301-624-1000
Old 08-15-2012, 10:40 AM   #12 (permalink)
Member # 170546
Old 08-15-2012, 10:42 AM   #13 (permalink)
Member # 43587
Send a message via AIM to TBItoy
Hmmm... Probably OK if the truck is just a mall cruiser...
Not so much on limit straps (not a big deal on htat suspension imo), but some bumpstops would be good idea to keep from fucking up something...
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 10:50 AM   #14 (permalink)
Member # 215765
i will not disagree with any of this. im well aware of the disadvantages. this is a very lightly used vehicle (not that that makes it any more okay)
Frederick, MD
301-624-1000
Old 08-15-2012, 02:47 PM   #15 (permalink)
Member # 10063
All that work and you still have a D44
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 02:50 PM   #16 (permalink)
skullver's Avatar
Member # 60364
yikes, single shear trackbar mount to boot, ouch.
